Old February 20th, 2008, 18:54   #1
SmudgePot
Fuel Economy: 40.15 ---- so far
Default Cruise Control not working ...... any ideas or suggestions
I have a 2002 Jetta automatic. The cruise control quit working. When I switch the cruise to the on position it lights up a cruise lamp on the dash but when I push the set or resume button .... nothing happens.
Any help would be appreciated.
SmudgePot
SmudgePot is offline   Reply With Quote
Old February 20th, 2008, 19:02   #2
tomo366
TDI Lifer
tomo366's Avatar
Replace the Brake light switch
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old February 20th, 2008, 19:24   #3
Cas
TDI(s): 2009jetta
i cleaned the contacts by removing slide button with small screw driver,spray electric cleaner . working fine now
Cas is offline   Reply With Quote
Old February 20th, 2008, 20:52   #4
02AutoWag
I'd like to add my cruise control problem to this thread too...
-2000 Golf with automatic trans and 123,000 miles, has never worked while in my possession (last 5K miles).
-Unlike SmudgePot, my dash light does not come on when I slide the switch.
-My brake switch was recently replaced (brake lights work, but still no cruise function).
-I checked via Vag-Com and the Cruise function is coded properly.
Now on to the proposed fix...
-How do you remove the slide button? Which way do you pry?
Russ
2002 Jetta Wagon (auto)
2000 Golf (5-speed swapped)
FOR SALE:
1998 New Beetle (minus 5-speed trans parts)
02AutoWag is offline   Reply With Quote
Old February 21st, 2008, 11:27   #5
KROUT
persona non grata
When I bought my jetta the ecu had been reflashed by the dealer and the cruise was turned off. I cant remember what I did to turn it back on but did it with vag-com. I fould the info to check it here. Sorry dont have any links.
KROUT is offline   Reply With Quote
Old February 21st, 2008, 12:24   #6
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
Did you remember... to check all of your fuses....?
They get me every time
jcrews is offline   Reply With Quote
Old February 21st, 2008, 14:01   #7
jettawreck
jettawreck's Avatar
Sometimes even if the brakelight switch is ok a burnt out taillight/brakelight bulb will do it. Odd, but....
2004 Cadillac SLS (wife's)
Old February 21st, 2008, 15:16   #8
SmudgePot
Yep, I checked all the fuses. I did have a tail light bulb out but I replaced it, didn't fix the problem. I will try the brake light switch next and clean the contacts in the on/off switch. I am not sure how to disassemble the switch tho.
Thanks for all the ideas.
2002 Jetta Automatic
130,318 miles
40 MPG Avg Highway
No mods.....yet
Old February 22nd, 2008, 04:59   #9
TDIFanatic1.9
There was a thread about the actual switch on the flicker stalk that needed cleaning. You need to carefuly remove the sliding button and spray some switch cleaner in there.
2003 Jetta4 tdi non-pd 110hp
TDIFanatic1.9 is offline   Reply With Quote
Old February 22nd, 2008, 09:33   #10
02AutoWag
I suppose I should have searched first ...
http://forums.tdiclub.com/showthread.php?p=825571
-Looks like my 2000 does not have a dash light, so that explains that.
-I'll have to give the Vag-Com another try as I don't think I went through the whole test procedure.
-Slide switch removal picture included in link above.
Russ
FOR SALE:
Old February 24th, 2008, 15:46   #11
02AutoWag
The Vag-Com testing using the link above showed that my switch wasn't working properly. As instructed, I popped the slide switch off and sprayed a little electronics cleaner...cruise now functions as expected. Thanks Wingnut for the pictorial.
If you don't have Vag-Com, I'd suggest just prying the switch and giving the cleaner a try. The switch attaches just like a snap button on a pair of pants or a jacket, so there's not much that can go wrong.
Russ
FOR SALE:
Old March 7th, 2008, 21:04   #12
SmudgePot
I checked the fuses, changed the brake light switch and cleaned the contacts as suggested with no positive results, my cruise still doesn't work. Any other suggestions would be appreciated.
PS: The VW cruise control system is different than any other I have I have seen so suggestions and hints are greatly appreciated.
130,318 miles
40 MPG Avg Highway
No mods.....yet
Old March 7th, 2008, 21:07   #13
compu_85
Gadget Guy
compu_85's Avatar
I would get a proper scan tool and ask the computer about the status of the switches.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old March 8th, 2008, 15:46   #14
SmudgePot
I have been wondering about that. What is a proper scan tool? Is there something other than the Ross that works well? It would be nice to have some kind of hand held unit if there is anything that works well.
130,318 miles
40 MPG Avg Highway
No mods.....yet
Old March 8th, 2008, 18:43   #15
02AutoWag
Only the Ross-Tech Vag-Com cable and software will give you access to the necessary test screens. Check the regional forums to see if you can meet with someone who has the cable and is willing to help you. http://forums.tdiclub.com/forumdisplay.php?f=34
Russ
FOR SALE:
Page generated in 0.14763 seconds with 9 queries
[Output: 123.47 Kb. compressed to 102.31 Kb. by saving 21.16 Kb. (17.14%)]
