yatzee
Hi Guys,
I had the cruise on 120 kph as normal. I was passing a guy in a Caravan who accelerated as I was going by him. My exit was in about 1 km, so I hit the throttle, but nothing happened. The cruise was still holding me at 120. I hit the brakes, and the cruise disengaged, but then I hit the throttle and nothing happened. I coasted off the highway and came to a stop. At this point, I noticed that my Glow Plug light was flashing, CEL light on, and the car was idling at 1200.
I crawled home in 5th gear at idle (about 55 kph or so). I tried shutting her on and off a few times with no change. When I press the throttle, nothing happens. No stumple, cough... no nothing! It does not stall....
I've checked:
- Mass Air flow and ECM connectors for water (it's been very wet around here today) but they were dry
- I checked all the connectors on my I.P.
- I checked the air filter for water
- I checked my brake lights
I do not have axcess to a VAG-COM - I am waiting for a friend with a generic scan tool to get back from work to check the codes.
Does anyone have any experience with this? I'm thinking an accelerator pedal assembly (with the electronics) - a friend of mine who works on these cars agrees with me, but I want to be sure (and he is really far away when you can only drive 55 kph!)
Thanks in advance. I will post codes as soon as I have them.
I've checked:
