Old January 22nd, 2010, 10:30   #61
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Originally Posted by savannah996
....i will follow the wire back from the 50 amp fuse on the fire wall, to the fuse box,....
well that is what someone said here, (about the fuse) however when i looked at it the wires didnt look right.
what IS the fuse on the firewall for anyways?
There are two fuses on the firewall.
The large strip fuse on the firewall, visible from under the hood, is the coolant heater fuse.
The fuse on the firewall, but on the INSIDE of the car, barely visible when the fuse and relay block is lowered, is the combustion chamber glow plug fuse.
Because you wrote "follow the wire back ..." I presumed that you meant the one under the hood. Had you written "follow the wire down... I'd have concluded that you had the correct fuse for this problem.
If I mis-interpreted your description of your plan of action, and came to an incorrect conclusion as to which fuse you were describing, I apologize.
Svante Arrhenius 1896
Old January 22nd, 2010, 15:13   #62
savannah996
savannah996's Avatar
TDI(s): None now
on the mk3 there are no fuses on the inside of the firewall. and we also do not have coolant heaters. i will look in my bentley on tuesday or wednesday and see what i was talking about. i do however have a 50 amp blade fuse on the top of my fuse box.
savannah996 is offline   Reply With Quote
Old January 31st, 2010, 13:49   #63
Lug_Nut
Lug_Nut's Avatar
You'll be able to correct the statement in your post, but this quote will be saved for posterity.
Old January 31st, 2010, 19:37   #64
rdkern
Fuel Economy: A4 = wife drives it, don't know
Can't get away with anything around here, can you?
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old February 1st, 2010, 08:06   #65
savannah996
TDI(s): None now
yet you are right, sorry i was ignorant without the bible!!!
Old February 1st, 2010, 08:09   #66
savannah996
TDI(s): None now
now if the bentley would just have the 1Z wiring diagrams i need to diagnose glow plugs and ecu.=fail
Old February 1st, 2010, 17:28   #67
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
1) Need a helper
2) Unplug glow plug harness from the GP's.
3) Unplug the Coolant Temp sensor (fools ECM into thinking the coolant is <30F)
4) Measure voltage at GP harness
5) Have helper turn key to ON
6) You should read 12V at all 4 connectors on harness.
If 12V not present, check for 12V at GP fuse under the dash.
If 12V present, check resistance of each GP.
If ambient temps are <35F GP's should be on (GP light) for about 2+ seconds. If the GP's are not on for long, I would bet the CTS needs to be replaced.
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old February 1st, 2010, 17:40   #68
compu_85
Gadget Guy
compu_85's Avatar
Check again, unless for some reason VW didn't equip your southern car with coolant heaters... As far as I know every MK3 sold here has them.
-J
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old February 1st, 2010, 17:44   #69
savannah996
TDI(s): None now
check #65 ↑↑↑
Old February 4th, 2010, 04:49   #70
Lug_Nut
Lug_Nut's Avatar
Check #64. We are all fallible.
As pointed out, the fuse in the A3 is attached to the top of the relay block, not to the firewall as on the B4.
The B4 Bentley has the glow plug wiring schematics. My 1997 edition of the A3 does not have TDI schematics (not available at the time of printing).
I should have checked before buying that used manual...
Old February 4th, 2010, 05:55   #71
savannah996
TDI(s): None now
correct, (for my A3 1Z)
my bentley for '93-99 A3's does not have 1Z wiring diagrams. when i called bentley they said "oh let me talk to my supervisor" came back and said "the ahu should be the same" haha let hope i dont short anything!!
Old February 4th, 2010, 13:21   #72
dieseljunkie
The fuse on the firewall, but on the INSIDE of the car, barely visible when the fuse and relay block is lowered, is the combustion chamber glow plug fuse..........
"barely visible when the fuse and relay block is lowered"
A crucial piece of information, not available till now!!!! I thought I was blind or mad or both, because for the life of me could not find the glow plug fuse. If only I had x-ray vision.
96 Passat TDI wagon ~145k SOLD!
92 Ecodiesel 205k
dieseljunkie is offline   Reply With Quote
Old February 4th, 2010, 22:42   #73
Digital Corpus
Digital Corpus's Avatar
Broke down and bought a new 180 relay from idparts.com Not sure tif that description is for the B4's made in 97, but I wouldn't call the placement of the relay on the firewall. It's crammed way up top almost near the steering column on one of the 4 slots on the bracket that is hard to even see. I had to pop the relay off the bracket just to detach it and then used the socket mounted back on the bracket as something to push on to put the relay back in.
I already scoped out where the relay was last week. It still took me about 15 minutes to do the switch. If my check engine light comes back on, I swear I'm not going to be a happy camper.
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old February 7th, 2010, 05:26   #74
savannah996
TDI(s): None now
update on my issues=
my ecu and glow plug systems are working, there are just open circuits to the lights in the gauge cluster. AND the airbag ecu is not getting power, prolly also unplugged or something. wont be looking into it until monday i think. cant wait to see if its really that simple. my cruise control is not working iether, i think it is also not plugged up, so i will check that when i drop the fuse box also.
my last mpg=42 city.
Old February 7th, 2010, 12:12   #75
nuclear
nuclear's Avatar
TDI(s): B4V
this thread is a moneysaver. I already burnt money on 97 relay when I have a 96. This solved the prob
nuclear is offline   Reply With Quote
Glow Plug Relay Location woodbutcher1953 TDI 101 9 June 6th, 2015 17:50
Glow Plug Relay (A3)(B4)(Early A4) microsoot Private TDI Items for Sale/Wanted 13 September 24th, 2011 06:37
96 B4 coolant glow plug relay strip fuse shockt VW MKIII-A3/B4 TDIs 2 November 10th, 2009 10:16
Bosch Glow Plug Relay {new} A3/B4 JettaTDI98 Private TDI Items for Sale/Wanted 2 April 10th, 2009 00:53
Location of Engine Glow Plug Fuse & Relay on 1997 Jetta TDI Guy Beland TDI 101 1 April 14th, 2001 00:01
Page generated in 0.17089 seconds with 10 queries
[Output: 135.53 Kb. compressed to 113.78 Kb. by saving 21.75 Kb. (16.05%)]
