sdeck
- Joined
- Aug 25, 2006
- Location
- Northern Colorado Front Range
- TDI
- 2003 Jetta, 253K, 01M, DLC520s, VNT-17(sold); 2014 Passat SE 6M, 61,000 miles (Feb 16 buyback date)
So I've been hunting around the archives and asking a few folks about cleaning intake ports. Basically, seems like 3 approaches:
1. pull the intake manifold, yank the valve cover, make sure valves are closed, go to town on the ports with scrapers, air, and vacuum. Valves can be closed by removing the cam (closes all valves) or rotating the engine by hand until one cylinder is TDC. Work on that one, then rotate again.
2. Pull the head, clean the valves. Like to avoid this one unless I need to pull the head for some other reason.
3. a couple of old threads on having the BG induction system cleaning done. This technique is done at a shop and they hook up some equipment and solvent dispensers to the intake and run the engine while spraying the cleaners into the air intake path. Supposed to clean the EGR/intake manifold/intake ports/intake and exhaust valves (I think)/exhaust side of turbo/exhaust pipes/cat. Apparently not cheap, but definitely the easiest way to go if time is more important than $.
First seems pretty straightforward but time consuming and with the potential for problems if you lose some chunks.
What are folks opinions on the BG system? We have a local shop here and I am curious. Anybody done it? Pros/Cons? How about on WVO cars (like mine)? Seems the valve deposits from WVO may be different.
Thanks,
Thanks,
