Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old February 10th, 2008, 00:37   #1
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Default Syndiesel
Anybody running the Syndiesel yet?
I have searched, but I cant come up with anything here..
Like GTL, or the Syntroleum stuff, Sounds like good stuff..
How about 63 Cetane or 20% better BTU's..
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old February 10th, 2008, 03:30   #2
I've used it at the track, blended 50/50 with regular diesel. Getting the cetane over 49 or 50 doesn't help much as the engine is designed to run on that cetane level. At a short track (Gingerman) it was good for about 2 sec. a lap. The big problem is the expense, especially shipping. Hiperfuels is in Houston, so if you're near there and can pick it up it becomes more economical.
Given its cost I'd be inclined to run 50% bio (54 cetane) to bring the numbers up in dino diesel.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old February 10th, 2008, 11:12   #3
dhdenney
dhdenney's Avatar
Fuel Economy: 39
Yeah if I was in and around Houston I'd be all over that! Best I remember, the cost isn't much more than regular D2 if you buy a drum and don't have to ship it.
*2012 Audi A3 TDI, Premium Plus, DSG, Ibis white
*1994 Pontiac Firebird Formula, Gt47-80 turbo, 580 rwhp/700 rwtq
*2004 Jeep Liberty Sport 4X4
dhdenney is offline   Reply With Quote
Old February 11th, 2008, 01:05   #4
Mach1
You can get a good deal from HIPERfuels in Houston, especially if you pick it up your self..
IBW, did you drive around town with it, what did you notice, like smoothness, LESS FUEL Injector Noise? Better throttle response?
How about running it regularly, because of the lack of lubricates?
I like everything I am reading about it so far..
2004 6L 89000 19MPG
Old February 11th, 2008, 03:41   #5
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
Cost is aroung 7.00 a gallon. I was the second fastest TDI (documented) at the 2002 Fest. Nice fuel cost prohibitive..
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old February 11th, 2008, 03:47   #6
It didn't seem much different driving around normally. In fact, I didn't feel a big difference on the track, but the stopwatch told the story. When I was running it I was able to stay pretty close to dbLog's Golf when he has a VNT-20 and I was running a stock car except for a chip. But seat-of-the-pants didn't seem much different. I always use a lubricity additive and was only blending it 50%, so I wasn't worried about lack of lubricity.
Old February 11th, 2008, 05:55   #7
dhdenney
dhdenney's Avatar
Fuel Economy: 39
I went to their website and if you buy the drum it comes out to less than $4.10 per gallon. That's not much more than pump prices. Could you imagine if they made this everywhere? Does syndiesel already have lubricity requirements met? Are there any evaportive losses if it were bought and stored? What is the "storage life?" Does it attract water like D2?
Old February 12th, 2008, 07:03   #8
Mach1
Dh, Self life is 10 years..Minimum evaporation, 20% more BTU's, 63 cetane( I have seen over 70 cetane on other Syn diesel)
No SULFUR..
Smells sweet, pleasent smell.
Very smooth, Quiets engine noise.
The engine is much smoother...
I am listening for/watching the idle stumble and there is minimum idle stumble/miss.
The engine just runs good on it..even lugging it has minimumized the groans for it.
You can get it for less then that price as well..Less then $4 gallon if you pick it up yourself.
I need to do just a little more testing for fuel economy now.
2004 6L 89000 19MPG
Old February 12th, 2008, 14:33   #9
Lightflyer1
Lightflyer1's Avatar
Mach1 we should split a drum of this.
2015 Beetle TDI.
Old February 12th, 2008, 17:42   #10
dhdenney
dhdenney's Avatar
Fuel Economy: 39
Great info. I wish this was available everywhere.
Old February 12th, 2008, 18:01   #11
Mach1
Dh, you can get a drum shipped to your front door, but I dont think you could get it for that price.
2004 6L 89000 19MPG
Old February 12th, 2008, 20:41   #12
dhdenney
dhdenney's Avatar
Fuel Economy: 39
Shipping is what eats the deal. I mean get it from a local supplier.
Old February 13th, 2008, 00:06   #13
Mach1
Dh, make a trip to Okla, they manufacture it there. Buy a years supply of fuel, all at once, I bet you could get a smoking deal...
2004 6L 89000 19MPG
Old February 13th, 2008, 00:42   #14
1point9and1half
TDI(s): Golf, 2005
I've heard about Syndiesel, but haven't a clue what it is, does anyone have a good link to information on the stuff? Is it bio based?
2005 Golf, Born to run on B100 Biodiesel.
1point9and1half is offline   Reply With Quote
Old February 13th, 2008, 05:49   #15
dhdenney
dhdenney's Avatar
Fuel Economy: 39
Correct me if I'm wrong, but a lot of it's hydrocracked natural gas isn't it? Mach1, if I had the time and money it would probably be worth it. If you could get it in sealed drums (which I am sure you do), then getting a ton and storing it would be a very ideal situation.
Page generated in 0.29639 seconds with 9 queries
[Output: 125.67 Kb. compressed to 104.23 Kb. by saving 21.44 Kb. (17.06%)]
