Old February 8th, 2008, 14:31   #1
tomtbone
TDI(s): none
Default Airbag light on... can someone in MA help me reset it?
My inspection expired in January on my 01 Golf TDI and my airbag light is on and needs to get cleared.
Does anyone in Mass know if I can pass the inspection in the airbag light on? I know they don't do an emissions test.
Can someone nearby in MA with the new Vag-Com help me reset it?
01 Golf TDI
97 Volvo 855R
tomtbone is offline   Reply With Quote
Old February 8th, 2008, 15:58   #2
concours
concours's Avatar
No. It's safety related. Before emissions, we called it a "safety inspection". Still applies.
2006 Jetta GLS 5 speed, 125,000 miles, 2001.5 Jetta GLS TDI 5-spd, 585,000 miles, 1999 Jetta GL TDI, 222,000 miles, 2000 Jetta GLS TDI, 215,000 miles, 1983 Jetta turbo diesel, 2-dr., 5-spd, A/C(RIP)
1980 Scout Traveller SD-33T
1986 Chev K10 6.2
concours is offline   Reply With Quote
Old February 9th, 2008, 06:42   #3
tomtbone
TDI(s): none
Hmm.. that stinks. Is there anyone in/around Mass that has the new Ross-Tech connector and the new Vag-Com software? I don't want to have to go to the dealer for such a trivial thing as resetting my airbag light. I don't know how much it would cost to do that.
I believe it just came on because I was replacing a fuse.
01 Golf TDI
97 Volvo 855R
Old February 9th, 2008, 06:44   #4
dieseldorf
top post dawg
dieseldorf's Avatar
tbone, can you remove the bulb?
Old February 9th, 2008, 06:46   #5
tomtbone
TDI(s): none
....but I still won't have any Air bag functionality though. but this might be a good quick fix for inspection. I am so used to my Volvo...how easy is it to get the bulb out behind the cluster? is there a write-up?
01 Golf TDI
97 Volvo 855R
Old February 9th, 2008, 06:52   #6
compu_85
Gadget Guy
compu_85's Avatar
Not on an Mk4 car, it's a soldered LED. Can't find someone local with a vag-com and see why it's on?
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old February 9th, 2008, 06:53   #7
tomtbone
TDI(s): none
-Jason
I am trying to find someone local with the new connector but haven't been successful. Hopefully some can see this thread and help me out. I never go to the dealer, I do all work myself. If I had a laptop, I would by a Vagcom, but I don't have one.
01 Golf TDI
97 Volvo 855R
Old February 9th, 2008, 10:38   #8
concours
concours's Avatar
What do you mean "new connector"??
I've got VAG-COM.... but only come to Franklin a few times a year.
If you buy the VAG-COM... you can borrow ANY friends laptop and download the software at www.ross-tech.com then use your cable. A GREAT convenience change they did a while back.
1986 Chev K10 6.2
Old February 9th, 2008, 11:05   #9
tomtbone
TDI(s): none
I guess only the newer cables along with the new software will not screw up your airbag module when connecting to it.
I think can get the Key-USB interface for $250, that should work.
01 Golf TDI
97 Volvo 855R
Old February 9th, 2008, 14:38   #10
Phoenix42
Phoenix42's Avatar
Start a post in the Eastern USA section. You may have to travel a little bit but there are a number of vag-coms near by.
Empeg, more tunes then you can shake a stick at.
Backup your 'My Documents' for free with Mozy.
I'm a loaner.
Phoenix42 is offline   Reply With Quote
Old February 9th, 2008, 15:07   #11
tomtbone
TDI(s): none
Do you have one?
01 Golf TDI
97 Volvo 855R
Old February 9th, 2008, 15:23   #12
Phoenix42
Phoenix42's Avatar
I don't, but I know there are many helpfully people in MA/RI/NH that will help out.
I'm a loaner.
Old February 13th, 2008, 19:24   #13
SootyYellow
  1. The airbag light is on in my vehicle, am I going to fail inspection?
    No, airbags are not part of the state inspection. We do, however, recommend that you have your vehicle checked if the airbag light is on. For more information about airbags and airbag safety, CLICK HERE.
  2. My Anti-lock brake light is on, am I going to fail inspection?
    No, anti-lock brakes are not part of the state inspection. If the brake light is on, indicating a failure in the hydraulic braking system, you will be failed. This indicates a serious condition which must be checked immediately. The anti-lock brake light indicates a problem with that specific feature of your braking system. We do, however, suggest you have the brakes checked as soon as possible.
excerpted from http://www.mass.gov/rmv/faq/inspection.htm#3
SootyYellow is offline   Reply With Quote
Old February 19th, 2008, 07:27   #14
jollyGreenGiant
jollyGreenGiant's Avatar
Sarcasm?
jollyGreenGiant is offline   Reply With Quote
Old February 19th, 2008, 07:32   #15
dieseldorf
top post dawg
dieseldorf's Avatar
tbone's car is on the road and sporting a contemporary 2008-09 MA inspection sticker
Page generated in 0.19533 seconds with 9 queries
[Output: 123.19 Kb. compressed to 101.63 Kb. by saving 21.56 Kb. (17.50%)]
