So I've got an engine code coming up and Autozone says it's P0183. It says Fuel Temperature Sensor. Probable Causes: 1) Fuel temperature sensor defective or 2) Check connector and wiring to sensor.
Another thing it says on the ticket is:
"The PCM has determined that the input voltage from fuel temp sensor A is higher than the calibrated limit indicating a lower than normal temperature"
What is strange is I got an alignment today and the light was off when they were done with it. The alignment was just a checkup, nothing was adjusted. Pretty sure they aren't related. But, it was strange the light went off.
Anybody familiar with this? Anybody got any ideas? Anybody know how difficult it would be to swap this sensor?
Thanks in advance
JP
Thanks in advance
JP
