Old January 21st, 2008, 10:18   #1
RMS5150
Default replace turn signal flasher relay?
2001 Jetta GLS TDI. I've done the searches, but haven't come up with a how-to for replacing the turn signal flasher relay. I've read that it is integrated with the hazard switch?? How is this replaced? My blinkers go a few times at various speed and quit, sometimes not working at all. The hazard lights flash perfect. Are the turn and hazard flashers 2 separate parts? Autozone says there are 2, but are also the same part number. All the bulbs are good.
RMS5150 is offline   Reply With Quote
Old January 21st, 2008, 14:49   #2
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
As I recall the switch just pulls out. Note: this may not be true for all years and all models.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old January 22nd, 2008, 04:48   #3
peteman
mine did, it's an 03. it's easier to plug the new one in if you have a blank beside it to remove.
2003 Golf GLS TDI 480 000 km (original owner)
2003 Golf GLS TDI 150 000 km (third owner)
peteman is offline   Reply With Quote
Old January 23rd, 2008, 22:03   #4
TornadoRed
TornadoRed's Avatar
A replacement flasher relay is about $22 -- if you think that's it, then it's worth a try. Just use a thin knife blade to pry the old one out, careful not to damage the plastic trim around the flasher.
If that doesn't work, then it's in the turn signal housing. There's a longish thread on this, but I just squirted some WD40 in there and it actually stopped my problem... which was random clicking, so not exactly the same symptoms as yours.
'03 Golf with 703k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Pirelli Cinturato P7 AS+, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Old January 26th, 2008, 11:23   #5
alhutch
alhutch's Avatar
TDI(s): None
FYI, the hazard switch/turn signal relay was a factory recall item on my wife's 2001 GTI, so you might check with your dealer and see if your car falls within the parameters of the recall (via VIN).
alhutch is offline   Reply With Quote
Old February 7th, 2008, 07:19   #6
5string
Default 03 Jetta with turn signal clicking problem...just started.
03 Jetta with 130,000 miles. Turn signals work normally, but when I turn them OFF the clicking continues intermittently, and sometimes at a faster rate than the normal flashing rate. No lights come on when this clicking happens...just the clicks. I can sometimes stop it by signaling left or right a few times, but there's definitely something going on. I just noticed it this morning so I haven't had a chance to scan it or otherwise investigate it.
Can somebody explain where this flasher relay is located, and also can Tornado Red tell me more about squirting WD40 to fix a similar problem?
Thanks,
Steve
2003 Jetta GLS TDI, Platinum Gray w/Black leather.
5string is offline   Reply With Quote
Old February 7th, 2008, 17:47   #7
TornadoRed
TornadoRed's Avatar
The flasher relay is the hazard switch, center of the dashboard.
As for the WD40, I just sprayed some in the general direction of the turn signal switch, using the very thin tube that fits in the WD40 can's spray nozzle. Then I worked the turn signal lever up and down a half-dozen times or so. I don't think you can squirt too much WD40 in there, though I suppose eventually it will drip down on your pants' leg.
Old February 7th, 2008, 19:19   #8
5string
Thanks, I'll look at that soon. I knew the clicking was nearby but I didn't know it was the hazard switch. Makes sense though. Funny thing is the random clicking only happens after the turn signals are turned off, not while they're operating. Hazard lights are fine and do not cause the clicking when they are turned on or off. I'm betting on the turn signal switch.
Old February 7th, 2008, 23:30   #9
TornadoRed
TornadoRed's Avatar
Yep. Probably got enough gunk in there that it's creating an intermittent circuit when there shouldn't be one. That's why brake cleaner or WD40 sometimes works.
I tried it only because someone else mentioned that it worked for him, though I don't remember if the fix was permanent in his case. In mine, it's been nearly 12 months. A very cheap remedy.
Old February 8th, 2008, 16:18   #10
concours
concours's Avatar
Before the recall, I carefully opened mine up, filed the contact points, re-formed the arm for more pressure on the contacts and it went another 75K mi. and was still OK at the recall
2006 Jetta GLS 5 speed, 125,000 miles, 2001.5 Jetta GLS TDI 5-spd, 585,000 miles, 1999 Jetta GL TDI, 222,000 miles, 2000 Jetta GLS TDI, 215,000 miles, 1983 Jetta turbo diesel, 2-dr., 5-spd, A/C(RIP)
1980 Scout Traveller SD-33T
1986 Chev K10 6.2
concours is offline   Reply With Quote
Old February 8th, 2008, 19:37   #11
5string
Did you remove any of the plastic around the steering column or just spray through the hole where the turn signal arm comes out?
Steve
Old February 12th, 2008, 00:06   #12
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
I didn't use WD-40 but I sprayed electrical contact cleaner into my blinker stalk. I think it gets dirty and causes it to act funny.
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old April 23rd, 2018, 03:40   #13
jetmech54
Fuel Economy: 7.02 L / 100 Km
I know that this is an old post 10 years old in fact, I have came across this issues recently and looking for some direction, should I be looking at the turn signal switch in the steering column or should I be looking at replacing the hazard light/turn signal relay.
jetmech54 is offline   Reply With Quote
Old April 23rd, 2018, 04:18   #14
TornadoRed
TornadoRed's Avatar
If turn signals are clicking randomly then the problem is in the turn signal multifunction switch. If signals are not working at all then it's the flasher relay. If the signal is normal for either left or right but clicking rapidly on the other side, then you have a bad bulb.
I know some people say WD40 is a totally wrong product for cleaning out the multifunction switch, but it has almost always worked for me; only once did I actually have to replace the switch. The last time I used it was about six months ago and the problem has not returned. I sprayed a lot in there.
Page generated in 0.15743 seconds with 9 queries
[Output: 120.39 Kb. compressed to 100.22 Kb. by saving 20.17 Kb. (16.75%)]
