Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old January 18th, 2008, 20:27   #1
Mr. Audie Gates
Fuel Economy: 46/52
Question engine block heater
TWTC:
Does the aluminum oil pan come into consideration when installing an engine block heater, why & can you recommend one for my 04 golf tdi? Thanks, Audie
Mr. Audie Gates is offline   Reply With Quote
Old January 18th, 2008, 20:30   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Most here recommend the TDI heater, vs. traditional block heater.
http://www.frostheater.com/
I like mine so far.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old January 18th, 2008, 22:33   #3
Mr. Audie Gates
Fuel Economy: 46/52
How did you squeeze 58 MPG out of your Jetta? Looks real nice! I don't have any pics of my 04 Golf on the computer yet. Id like to get black leather seats instead of the silver-gray cloth. Audie
Old January 19th, 2008, 08:23   #4
catmandoo
i've gotten 58 with my 2000 jetta twice,believe me you have to go at it in the mindset that everything you do is to save fuel.no a/c,windows up,keep it under 2000 rpm's etc.
catmandoo is offline   Reply With Quote
Old January 19th, 2008, 14:50   #5
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
__. Your '04 has the PD engine - they don't get as good MPG as the "VE" engines (the difference is in the fuel injection). About the only reasonable way to find seats for replacement is a junkyard but they'll probably be rare because most seats would have had the airbags go off and that ruins them. Expect to pay mucho dinero!
__. There's lots of info about your car here on this website and the "search" function is really clunky. But check the FAQ's (Frequently Asked Questions), read the "stickies" at the tops of the pages, and search for topics you're interested in. You'll find a lot of help.
__. Good luck with your car!
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06; 130K mi in 4 1/2 years/~57 MPG lifetime); New car, '03 Jetta Wagon, CAT filter, .681 top gear, 350K mi. in 11 1/2 yr, ~52.
mrGutWrench is offline   Reply With Quote
Old January 21st, 2008, 16:21   #6
n8ronJ
n8ronJ's Avatar
BobFout,
Have you seen a mileage improvement at all with the heater? I would assume that there would be a little bit of an increase because you're eliminating those cold starts. I live in western NY (near Niagara Falls, north of Buffalo) and we get some real winter bitterness. The wind can be just brutal. Jetta always starts but I'd like to help it out a little on these cold days.
Is it worth the $100?
sold2003 Jetta GLS TDI, 275k, Platinum Grey, 5 Speed, SBC Stage2 Daily, Evo Atlas Skidplate, RC3
n8ronJ is offline   Reply With Quote
Old January 21st, 2008, 16:27   #7
alex97jazzblue
TDI(s): ALH, BRM
Ha ha, is it worth it.
I live in Maryland, tropical by comparison to where you live, I only use it when I know it will be less than 35F when I drive to work.
It is the weirdest thing too, having this car for 6 years u get used to how it feels when ran in this weather. Now I get in and the engine and coolant are totally warmed up and I would have no idea I was driving my car in the winter by listening to it.
In response to your question, I beleive it would make ME save fuel. When my car would be real cold I would tend to rev faster and stay in lower gears for longer in an attempt to make the engine heat faster.
Also I beleive the engine works a little harder when cold.
End of the day, the Tdiheater will give you comfort, wear your engine less, and even prevent ice buildup (remember that this heats and pumps the coolant, therefore it heats the engine block too, heat eventually radiates to the hood and windshield).
1990 Corrada 1z
2002 Jetta ALH Vnt17
1981 Rabbit Pickup 1.6TD
1997 GTI VR6 Gt35
alex97jazzblue is offline   Reply With Quote
Old January 21st, 2008, 16:31   #8
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Originally Posted by n8ronJ
BobFout,
I can't be sure, I've had a few other mods that would affect MPG also.
Old January 22nd, 2008, 23:38   #9
Bora-chiara
Bora-chiara's Avatar
Fuel Economy: 49-51
It's worth the 'hundred dollars. I like pulling into work and not just barely generating cabin heat. Starts like a warm summer day and instant cabin heat. OOOH its nice. And looks smooth under the hood too. Agreed with the ice melting. Highly recomended.
Too many diesels to list...
My daily A4-11mm R520 MALONE TUNED
Wife's daily B5.5-chainless MALONE TUNED
Bora-chiara is offline   Reply With Quote
Old January 31st, 2008, 07:41   #10
Pat Dolan
Fuel Economy: 800km/1100km/tank
Yes, the TDI heater is what VW should have done in the first place. The mickey-mouse (sorry Walt) stick on oil warmer doesn't do the job. We start plugging in around zero or so. The TDI ALWAYS starts (even if unplugged) but a cold start is fairly hard on things. I think I have 1,100 watt element heater, and we use a timer so that it is running no more than an hour or so before first expected use in the day. Around here (about -30 something this morning) we also use a "winter front" - a vinyl grill opening cover to limit cold air blasting into the engine room all winter. Our local VW dealer has some very nice ones made up locally that simply clip in place and fit very well.
BTW: while the TDI is about the worst car since air cooled days for warming up and heating the interior, our older TDs are about the best. As usual, VW screws up something else good and never bothers to deal with the issue. I guess that's why we have an aftermarket and forums.
4L='14 Q7 TDI, B7='15TDI(buy back), B6='09 wagon gasser, A4=2003 TDI Variant, A3=Golf CL, A2=2x1.6 Jetta TDs, Golf Syncro Country, A1=Scirocco Mk1 & 16v, Audi 5000TD, 2014 I, Porsche 924/M471 and a bunch of diesel trucks.
Pat Dolan is offline   Reply With Quote
Page generated in 0.16193 seconds with 9 queries
[Output: 95.85 Kb. compressed to 81.13 Kb. by saving 14.72 Kb. (15.36%)]
