Old October 23rd, 2010, 16:01   #61
xubio
This app is awesome. I noticed that my plots also plot the time column as a separate series in the plot, instead of using the time for the x-axis of the column, like this:
Is it possible to modify the application to use the time column for the x axis? If the source code was available, I'd be happy to have a go at making the changes.
xubio is offline   Reply With Quote
Old October 24th, 2010, 17:41   #62
jollyGreenGiant
jollyGreenGiant's Avatar
I can't see any of the details in terms of what ECM, measuring blocks and values are feeding into the plot above.
Not all measuring blocks are created equal. It would seem odd that a measuring block would have it's own time value as a channel but I guess it wouldn't surprise me, I just haven't seen that before. What would you want it to do with this channel's data then?
jollyGreenGiant is offline   Reply With Quote
Old October 26th, 2010, 20:42   #63
xubio
Sorry, I should've included a better image. This one should be better. Also here's the first lines of my log file:
Code:
 Tuesday,26,October,2010,19:59:04:54607,VCDS Version: Release 10.6.1 (x64),Data version: 20100831
028 906 021 JB,ADVMB,1.9l R4 EDC  G00SG  1457,
,,G003,F1,G003,F2,G004,F0,G011,F1,G011,F2,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Group 3 - Field 1,TIME,Group 3 - Field 2,TIME,Group 4 - Field 0,TIME,Group 11 - Field 1,TIME,Group 11 - Field 2,,,,,,,,,,,,,,,
,STAMP,MAF (specified) - 240-340,STAMP,MAF (actual) - 240-340,STAMP,Engine speed - 861-945,STAMP,Specified MAP,STAMP,Actual MAP,,,,,,,,,,,,,,,
,, mg/str,, mg/str,, /min,, mbar,, mbar,,,,,,,,,,,,,,,
,0.36,250.0,0.36,282.6,0.72,903,0.01,948.6,0.01,989.4,,,,,,,,,,,,,,,
,1.44,250.0,1.44,282.6,1.81,903,1.08,948.6,1.08,989.4,,,,,,,,,,,,,,,
,2.52,245.0,2.52,266.0,2.88,1134,2.16,948.6,2.16,989.4,,,,,,,,,,,,,,,
,3.61,220.0,3.61,339.2,3.96,1365,3.24,948.6,3.24,989.4,,,,,,,,,,,,,,,
Also note in the image that the field headings are not using the field names from line 6; makes me wonder if my data logs have a different format. (They are Canadian:-)
Old October 26th, 2010, 23:04   #64
xubio
I figured out the problem. I was using Advanced Measuring Values, in which case the log file format is different. If I use Measuring Blocks, the results are much better.
Old March 2nd, 2011, 14:34   #65
DonNiger
TDI(s): A6C5 AVF
Hmm, strange. It shows just first reading (Engine speed,MAF (specified),MAF (actual),EGR duty cycle - just engine speed is displayed).
And I can not see your .csv file with the v-scope installed. Strange but I can not figure out what is the problem.
DonNiger is offline   Reply With Quote
Old March 3rd, 2011, 17:50   #66
KERMA
KERMA's Avatar
nominate for sticky status
HP is for show, TQ is for go.
celebrating 15 years of: http://www.kermatdi.com
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old June 6th, 2011, 12:01   #67
CopaMundial
Bump for a thread that deserves sticky status or at the very least a mention in the TDI 101: How To thread.
Now, for my question.
Can anyone make some suggestions of what would make good groups of measuring blocks to graph against one another?
I'm looking to just check on general health of my car, plus I'm troubleshooting what might be the very slightest of hesitations under acceleration. It almost feels like a vibration, but I don't think it's mechanical or rotational drive train type of thing... it could be a fueling hesitation, but it's only under heavy acceleration (say ~3k rpm).
If possible I'd like to use JollyGreen's application to lay out some graphs to help me seek advice from the community, so any suggestions of good values to graph together would be appreciated.
CopaMundial is offline   Reply With Quote
Old June 24th, 2011, 21:24   #68
bart3298
Default how to use
So, being computer stupid, once I have logs saved on my laptop how do I view them with this application. I need some step by step directions on how to use it. I have a Dell laptop with windows 7 home version on it. Will this work? Thanks!!!!1
bart3298 is offline   Reply With Quote
Old June 26th, 2011, 21:20   #69
CopaMundial
Just click (and hold down mouse button) on the log you want and drag it on top of the LogPlottingApplication.
Last edited by CopaMundial; June 27th, 2011 at 06:09. Reason: Correction: I originally said 'right click and drag'... but it's just the regular 'left click and drag'
Old June 29th, 2011, 13:16   #70
bart3298
Thanks for the info!!!! I'll give it a try.
Old October 3rd, 2011, 12:58   #72
T0M_NASTY
T0M_NASTY's Avatar
sticky this!!! also added a link to TDI 101 HOW TO thread
2004 Jetta BEW 5 spd
T0M_NASTY is offline   Reply With Quote
Old March 17th, 2013, 08:38   #73
CopaMundial
Just bumping this thread up for newer users who may not be aware of JollyGreenGiant's excellent graphing tool.
Old March 21st, 2013, 09:50   #74
compu_85
Gadget Guy
compu_85's Avatar
Support for Adv Measuring blocks would be fantastic as that's all some of the newer cars have.
Thread is now a sticky.
-J
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
compu_85 is online now   Reply With Quote
Old July 24th, 2014, 19:44   #75
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
Default Does this program still work?
I have the current VCDS program, and the CSV output does not seem to work with this program. Can anyone shed some light on what changes to the current CSV file outputs might allow it to work?
sptsailing is offline   Reply With Quote
Page generated in 0.16907 seconds with 9 queries
[Output: 124.75 Kb. compressed to 103.56 Kb. by saving 21.18 Kb. (16.98%)]
