Old February 24th, 2009, 20:36   #31
aNUT
aNUT's Avatar
Fuel Economy: Great.
This program is super clean and easy to use. Kerma showed this to me a few months back. Excellent work. Thank you Thank you.
www.dieselland.net
aNUT is offline   Reply With Quote
Old February 27th, 2009, 20:45   #32
jollyGreenGiant
jollyGreenGiant's Avatar
Thanks, glad that you folks dig it and are getting some use out of it.
jollyGreenGiant is offline   Reply With Quote
Old March 18th, 2009, 11:25   #33
Got Bearings?
Got Bearings?'s Avatar
Fuel Economy: 36 / 50
Is this not available anymore?
The New Commuter Car: 2009 Cadillac CTS-V 556 HP, 6.2L Supercharged V-8, 6 speed manual
The Old Commuter Car: 01 Golf GLS TDI WRECKED AND GONE!
The Slow Car: 95 Impala SS 383, 6 speed, 391HP , 440TQ
Looking for Battery Cables, better & cheaper than OEM? Click here for info
Got Bearings? is offline   Reply With Quote
Old March 18th, 2009, 12:29   #34
jollyGreenGiant
Eh, I guess the isp for that old domain finally caught on that I wasn't a customer... My neighbor who used to work there setup the account for me. Oh well.
I'll post up some new coordinates for the files in the near future...
Old March 21st, 2009, 14:52   #35
Sip'n Diesel
Veteran Newbie
Sip'n Diesel's Avatar
Fuel Economy: 900 miles on 16.9 gallons - Personal Endurance Record
Exclamation
if anyone would like the setup.exe file, I think I still have it and could send it as an e-mail attachment while we wait for new coordinates
2003 Jetta GL - 5 Speed Manual - Alaska Green - Dieselgeek Panzer Plate & Full Metal Jacket - DGRP - ScanGaugeII - WeatherTech Deflectors - Vent Delete - DRL Delete - Muffler Delete - KONI STR.T - Redneck Armrest - 5 Brake Lights - Otherwise all stock, for now
Sip'n Diesel is offline   Reply With Quote
Old March 27th, 2009, 09:27   #36
jollyGreenGiant
Same build as before, no updates... Busy, you know? New coordinates posted in the first post. We'll see how this works hosted here, let me know if anyone has problems with it.
Old March 28th, 2009, 21:43   #37
Sip'n Diesel
Veteran Newbie
Thumbs up
thanks! as it turned out, I had deleted the setup.exe file and e-mailing the program.exe does not work
Old March 29th, 2009, 09:18   #38
Growler
Got Soot Vendor
Growler's Avatar
downloaded the program, extracted it to a folder, and got this.
any ideas?
how do i check for the .net stuff?
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old March 29th, 2009, 10:16   #39
Growler
Got Soot Vendor
Growler's Avatar
nevermind, downloaded and installed .net 2.0 and it works great!
Thanks!
~Aaron~
Old April 27th, 2009, 13:21   #40
vwjettadsl
vwjettadsl's Avatar
Just stumbled across this, thought I say thanks! Nice to be able to quickly show a customer the logs of their car without having to use Excel.
Trusted TDI Mechanic
Mobile Timing Belt Replacement, I travel to you
Malone Tuning Dealer, I offer mobile tuning service for ALL TDI's
www.vwtdisales.com
vwjettadsl is offline   Reply With Quote
Old April 27th, 2009, 13:39   #41
Growler
Got Soot Vendor
Growler's Avatar
I agree. this software is awesome
~Aaron~
Old August 13th, 2009, 15:53   #42
90hpisntenough
90hpisntenough's Avatar
Fuel Economy: Average: City:40.1 Highway:47ish Best:50.5 at 65mph, A/C off
This should be a sticky! I couldn't believe how bad excel sucks with plotting the .csv file. Great work on your program, you just saved me a major headache.
--1999.5 Jetta 198K
Haves: RCII; Sprint 520; 2.5" Straight Pipe; McNally Boost/EGT Gauge; Boost Controller; SB Stage I Feramic Clutch w/ SMF; VCDS; Snow Screen Delete; Ventectomy; EGR Delete; TT LCA Bushings;
Wants: RC III;VNT 17/22; Upgraded intercooler pipes; Clean/Non-Sticky Vanes;
90hpisntenough is offline   Reply With Quote
Old August 20th, 2009, 13:56   #43
jollyGreenGiant
I made a few upgrades to this application.
The new current version is now 1.1.3519.25607
1. I had several logs open at times and figuring out which one was which got confusing, I solved this by now modifying the window title to display the filename so alt-tabbing ( or however you decide to choose the instance you want ) will be easier if you know what filename you're looking for.
2. The filename is also now displayed in each tabs text box for printing and archival sake when using the image.
3. I created a menu item to either enable or disable the plots "smoothing" feature, there's a lot going on under the hood there and rather than implement some crazy polynomial or logarithmic averaging on the data points, for those who can't stand averaging induced flaws, you can just disable that feature and enjoy the jagged raw appearance
Enjoy. If you find this application useful, make a donation to Fred's on my behalf
Old August 20th, 2009, 14:17   #44
Growler
Got Soot Vendor
Growler's Avatar
how about adding a zoom in function by % in the right click menu?
~Aaron~
Old August 20th, 2009, 14:35   #45
jollyGreenGiant
You do know that you can either (mouse equipped) use the scroll wheel or (touchpad) scroll zone to zoom in and out real-time, right?
Also, if you just draw a rectangle around what you want it will zoom to just that rectangle.
I think that if one were to choose a %, they would only be guessing what they wanted and then would have to fine tune it anyways...
Page generated in 0.17175 seconds with 9 queries
[Output: 128.51 Kb. compressed to 106.97 Kb. by saving 21.54 Kb. (16.76%)]
