Old February 8th, 2008, 07:26   #16
Jonathan showed me this the other night: It's really great, especially for those of us who are excel-challenged.
Old February 9th, 2008, 12:43   #17
SBAtdijetta
SBAtdijetta's Avatar
Fuel Economy: Best 51.4mpg, AVG 38+ and climbing
Wow! That is cool, thanks for sharing this!
10 Jetta TDI 6spd Cup - Tune, Turbo back Exh, BBS, etc
02 Jetta TDI Auto beater - Stock - Soon to be for sale
06 Jetta TDI 5spd - VNT2556,PD150 Injectors,3"TB,Pelq.,etc., Never dynoed in final config. - Sold
Need help? I have VAG-COM
SBAtdijetta is offline   Reply With Quote
Old February 9th, 2008, 14:27   #18
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
I'm going to have to try this out, when I get home. I have used Excel and frankly I feel it is a pain with Vag-Com.
sounds like a good product!
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old February 13th, 2008, 09:41   #19
milehighassassin
Fuel Economy: 43
I have some VAG logs and I can't get this to work.
I do have .net 2.0 installed. The program and you sample plot work fine.
Any suggestions?
Old February 13th, 2008, 11:52   #20
jollyGreenGiant
jollyGreenGiant's Avatar
Send me the log(s) and I'll check them out...
jvhess at comcast dot net
jollyGreenGiant is offline   Reply With Quote
Old May 19th, 2008, 19:34   #21
SheeB
Wow, just what I was looking for as I am no good with Excel what so ever! I have the logs already saved so hopefully this will graph them all nice for me! Thanks for the utility!
SheeB is offline   Reply With Quote
Old January 8th, 2009, 12:01   #22
kooyajerms
grocery getter
kooyajerms's Avatar
bumping this, people need to use this.
Jon, how do I make the graph show 3 different logs at the same time? When I open the file it makes 3 different plots (group a b and c).
kooyajerms is online now   Reply With Quote
Old January 14th, 2009, 10:33   #23
jollyGreenGiant
Not too sure what you are asking... If you want to view the three groups at the same time, you could open three instances of the app all viewing the same log and re-size accordingly then set the viewable tab to a, b and c accordingly. Not ideal I know. Another thing I was thinking about adding is a synchronize x axis option where you could zoom in on one groups x axis ( time ) and then have the other two groups scale to the same x axis also.
Just haven't had much time for adding anything to this lately, thanks for the bump though. Your comment/request is noted though. It could be something that I might be able to add at a later date. I suppose I could also share this code and make it an open source project or something.
Old January 14th, 2009, 18:41   #24
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Plotting different groups from VagCom data is a little tricky by the way the data is organized.
Each group has it's own time stamp so there is no data from group 1 or group 4 at the same time as data from group 11 for example.
0.25 sec = Group 1 data
0.50 sec = Group 4 data
0.75 sec = Group 11 data
1.00 sec = Group 1 data
1.25 sec = Group 4 data
1.50 sec = Group 11 data
1.75 sec = Group 1 data
2.00 sec = Group 4 data
2.25 sec = Group 11 data
etc
etc
Is how it's actually taken
0.25 sec = Group 1 data..........0.50 sec = Group 4 data..........0.75 sec = Group 11 data
1.00 sec = Group 1 data..........1.25 sec = Group 4 data..........1.50 sec = Group 11 data
1.75 sec = Group 1 data..........2.00 sec = Group 4 data..........2.25 sec = Group 11 data
and so on is how it's displayed in groups.
So even though there is data taken every 0.25 seconds (for example), the data is for different groups each time.
If you plot it on a common X axis (the left most one typically) the data will look like it's synchronous between groups, but will actually be off by 1 or two sample times (which when you're taking data on 3 groups, the sample rate is pretty slow - just a little faster than once/second).
If you only record one group, then you can get the full time resolution.
If you could have the application evaluate the first column of each group and sort that data (keeping all the data together for that time stamp) into a table like the first example I posted above, then you can plot it all against the same X axis of time and get an accurate graph.
Hope that helps some?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old January 14th, 2009, 19:00   #26
Sip'n Diesel
Veteran Newbie
Sip'n Diesel's Avatar
Fuel Economy: 900 miles on 16.9 gallons - Personal Endurance Record
this thread should be a sticky
2003 Jetta GL - 5 Speed Manual - Alaska Green - Dieselgeek Panzer Plate & Full Metal Jacket - DGRP - ScanGaugeII - WeatherTech Deflectors - Vent Delete - DRL Delete - Muffler Delete - KONI STR.T - Redneck Armrest - 5 Brake Lights - Otherwise all stock, for now
Sip'n Diesel is offline   Reply With Quote
Old February 13th, 2009, 17:06   #27
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
I have possible issue!
On my computer (.net 2.0 install and after upgrade to 3.5) i see only one trace of 4.
Dieseleux
p.s.: I test on 5 machine... 3 not work good, 2 are ok!
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old February 14th, 2009, 21:35   #28
dieseleux
dieseleux's Avatar
I found the trouble....
My machine is set for "," and not fot "."
Dieseleux
Old February 14th, 2009, 21:43   #29
Torque_Delight
Modded
Torque_Delight's Avatar
Fuel Economy: ~5 l/100km
Nice you found the problem, Yeah it's always good to verify the regional settings to be sure the separator is really to ",".
BTW, Very nice tool ! Good work here !
Jetta TDI 2001 GL (~680 000 km) : GT-1749VB, EGT/O2/Boost Gauges, Scangauge II, Sachs VR6 Clutch kit, OEM G60 Flywheel, 502 Nozzles, MRTuning, Euroswitch, Hella Micro-DE w/ yellow bulb, Rear fog, Wolfsburg's Heated Seats, Koni STR.T Shocks, H&R OE Sport Springs, TT Control Arm Bushings, 17" Santa Monica (GTI VR6) Wheels, DieselGeek Skid Plate, FX35 HID Projectors Retrofit, GLI Tail Lights, 2004 Trunk lid.
Torque_Delight is offline   Reply With Quote
Old February 15th, 2009, 06:21   #30
WVU TDI
WVU TDI's Avatar
This is a nice little application. I know my way around excel rather well, but for a quick check, this is really nice.
1997 Passat TDI (sold)
2001 Golf TDI (sold)
2010 4dr Golf TDI, 6M (sold)
2013 Passat TDI SE, 6M -- turbo failed at 9500 miles.
WVU TDI is offline   Reply With Quote
Page generated in 0.17486 seconds with 9 queries
[Output: 133.28 Kb. compressed to 111.27 Kb. by saving 22.01 Kb. (16.52%)]
