| OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs |
January 13th, 2008, 17:49
#1
HELP OBD2 code PO673
 Any help would be appreciated. My 03 TDI engine light is on. I checked for the code using my cheap OBD2 scanner from Walmart! Its worked by referencing problem code P0673. I tried to cross reference this code with my VW workshop manual but this code is not listed. Can anyone help?
Thank you,
Mark.
January 13th, 2008, 18:03
#2
When ever you can't find a code, try Google.
The code refers to "glow plug number 3 circuit" according to Google and seconded by Bentley.
1999.5 New Beetle TDI Bosio 1019's, Malone Stage 3, Evo Skid Plate, Neuspeed Front and Rear Sway Bar, Turbo S Susp, 19's, HID's, EGR Delete, VF Mounts, South Bend Stage 2 Clutch, B&M Shift Kit
1997 Eurovan 2.4 NA Diesel, Panel Van
January 13th, 2008, 18:36
#3
January 17th, 2008, 16:51
#4
?? Thank You
WOW Thank you for all the help. That light has been bugging me for months. Do you think its the #3 glow plug or something more challenging?
Maybe I am not that smart but I tried to google the code with a search VW OBD2 code PO673 but all it pulled up was this post and one other none related item. What it the best way to seach in google? I am a pretty good mechanic but codes are new to me.
Cheers, Thank's again.
January 17th, 2008, 17:31
#5
Did you follow the link to the TDI glow plugs 101? They give you great help there. Yes something is wrong with either the #3 glow plug or the wiring to it.
January 18th, 2008, 09:39
#6
Fuel Economy: 54/50/44 (usually running B100)
More likely a dirty connection at the harness. Some DeOxit will help this. However, you can check out the glowplug with a multimeter to see if it is fried. If you live near a HarborFreight, you can usually pick up a digital multimeter for less than $5.
-McBrew
2011 Subaru Outback 2.5i Premium. Lineartronic CVT trans.
Still have 3 TDIs in the family fleet.
January 18th, 2008, 18:52
#7
I never had a car new enough for a code reader. I am a gear head but this stuff makes my head hurt. I hate to let anyone work on my cars and bikes so I am sticking with it until it starts getting fun. I know what I need to do.
Thanks for all the help. As always I always you find great people connected with cars and bikes.
January 20th, 2008, 09:57
#8
Fixed
Its fixed. The plugs tested OK. DEOXIT did the trick. CHEERS .
