Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old November 21st, 2015, 13:48   #901
the beave
Fuel Economy: @ 2 Months: 45.53 combined. 04-02-2017 Vancouver Wa. Trip After Flash: 54.8 mpg Hiway 38.6 City
Originally Posted by BleachedBora View Post
I've thought about doing a list like this for a long time. I remember when I first started driving my 1997 Jetta TDI I saw people claiming 50+ MPG. I figured they were off their rocker because I was only getting 36 if I was lucky. I fueled at Flying J (Now Loves) in Troutdale, Oregon, ran my tire pressure at 32, and drove like I stole the thing. Over the course of over 11 years and 500,000 miles of driving TDIs later I consider myself by no means an expert, but I'd like to consider myself a very well informed driver. The following is a list that people are welcome to add to. Rules and my top 10 list might be added to and changed as well as time goes on. The point is to get a discussion going so that those that are new to our community aren't intimidated with the fuel economy numbers they are getting, as well as meaningful ways on how to get better economy.
Some rules of thumb:
Rule #1: Never trust the computer--not even a $80,000+ avionics package in an aircraft is 100% accurate with regards to the computer. (For what it's worth, general aviation fuel gauges are required by law to be accurate at only one time--empty).
Rule #2: If you want to know your mileage, fill up completely to the top every time, this is after letting all the foam settle. Take miles driven and divide by x.xxx gallons (in the US) to get MPG. If you want to be very anal you must realize that if your wheels/tires are different than stock then your calculation can be off by 1-8%+. From the factory your speedo is off by ~3 MPH but your odometer is spot on. Remember that when putting on new tires, oversize tires will make your speedo more accurate, but your odometer will start to under report. My MK3 Jetta with 195/65/15 tires was perfect on the speedo, but the odometer was low by 6%.
I've been married since 29 Sept 2007. When I first met my wife she stated that her previous car got "X" MPG, which she always got off the computer display. She had a car without a computer and I had to teach her how to do MPG. She kept resetting the trip odometer when she went places to "see how far she goes." Point is that with her car which was supposed to get 28 MPG, she's had some tanks as low as 19.6 MPG. Since I first wrote this thread 6-years ago (update Oct 2014) she's had a Jetta Wagon and a Passat Wagon, she has become quite adept at calculating mileage too .
This all brings us to:
BB's tips for higher mileage*, more or less in my order of easiness and cost effectiveness, and according to my own experience--I have multiple tanks in a row with over 60 MPG. I'm also one of the very few members to get 900 miles in a tank WITH A MK3 (15 gallon tank when dry). Driving for mileage is hard to do unless you know what to do--again YMMV:
1) Run tire pressure at 90% of recommended max pressure as stated on side of tire. (Free)
2) Run a good quality fresh fuel with a high cetane number (see bottom of post for some stations cetane numbers). In the west Chevron seems to by far bring the best numbers. A poor quality fuel with low cetane will lower MPG by up to 5. Just because it's a truck stop it usually means you are putting crap in your tank (especially Flying J). In the Midwest BP/Amoco are great--both BP and Chevron have stated that they won't have Cetane under 49, which is what our cars need. If you're filling with crappy fuel run an additive. I personally like Lubromoly Super Diesel Additive. There are lots of writeups online of differing qualities of additives. Biodiesel up to B20 won't really have an effect on your mileage. B100 will lower it by ~5 MPG. Note that these numbers are taken with over 750,000 miles of careful calculations over the course of many years, different cars, and different seasons.
Example: If you get 40 MPG from Flying J at $4.25/gallon, and 45 MPG from Chevron/BP at $4.49/gallon, you are paying $.10625/mile with the J, and $.09978/mile with the higher quality fuel. (And if you find a quality station next to a truck stop often the difference in price is less than $.05/gallon!) You actually save $64 just in fuel over the course of 10,000 miles by buying the more expensive fuel. This says nothing for what you might save in maintenance (injection pump and the rest of the fuel system) over the course of time. Just because it's expensive doesn't mean it's good. I've called lots of corporate offices and have numbers on the following cetane levels*** (See end of post)
Most truck stops are going to be low numbers because most semi's run the same regardless of cetane number.
3) Have a good working Mass Air Flow sensor and clean filters/snow screen & non-restrictive intake. (Air filter ~$14-20 for cold region filter--run it regardless of location. $20-30 for a good fuel filter. A poorly working MAF will give you 5+ less MPG. If you are in doubt to if yours is working, unplug it and see if you have more power. If you do, your MAF is bad. If you are running a cone filter (like K&N) you don't even have to check it, it's probably bad already. A stock air filter flows better than a K&N and it won't kill your sensor. A new Bosch revision "C" MAF will run about $100 for a 1999-2003 car, and about $160 for a 2004+ car.
4) Go easy on the accelerator. Drive like you have an egg under your foot. Bear in mind that when you are coasting in gear you use no fuel until you decelerate to ~1200 RPM. You burn ~.5 quarts per HOUR with a warm engine at idle, turning your car off at lights to save fuel is generally ineffective. *I rented a BMW 520D in Germany in September of 2014. It had auto stop/start. My feelings are that when the computer controls the stop start it's going to be more effective in fuel savings then you will be doing it manually. Be gentle on acceleration--if you have a boost gauge limit your boost to 5 lbs. while speeding up. There is a lot of talk about city vs highway driving. A lot of people seem to confuse city driving with slow driving - what they fail to realize is the effects on your MPG are totally different between the two. The reason city MPG is low is because you have lots of stop and go; when you are accelerating you are using a lot of fuel. A cold engine also is less efficient than a warm engine. Furthermore every time you hit the brakes you waste precious kinetic energy (speed) which cost you fuel to build up...unless you are an expert at timing lights. This cycle continues to repeat itself from stopping point to stopping point. Because of this you see low MPG. Slow (constant/rural road) driving is optimal, since you can cruise for a long time in a high gear (low RPM) without much throttle at all due to the lower amount of wind resistance (aerodynamic drag) from trying to slice through the air at a lower speed. The result is excellent MPG. Highway driving is the median MPG; you can cruise at a constant speed in the highest gear, but you are traveling faster so there is more aerodynamic drag, reducing your fuel mileage. (Free)
4a) Those in REALLY cold places (Canada and parts of US where sub-freezing temps are common) often get a bra/cover to limit air intake and/or get a Frostheater. These will help the car warm up faster and therefore be more efficient. That said, don't start the car and let it idle to warm up--it won't warm much without load on the engine and you blow any mileage improvement from a warmer engine by the fuel lost idling (and it's bad for the environment).
5) Don't go oversize on tires or wheels. If you do get larger wheels make sure they weigh the same or less than stock. I run the ENKEI RPF1 wheels which weigh 13.5 lbs (16"). The cost isn't worth it for fuel savings, but I like how they look! 18" R32 wheels are around 27 lbs and will kill your economy.
6) Get a performance chip--Malone tunes as well as TDTuning & Rocketchip are all great choices. They will give you performance when you want it, and fuel economy when you drive nicely. My experience was that Malone gave me a bit more economy over RC. You'll be happy with any that's for sure! (~$300-550 depending on car)
7) Nozzles! ('96-03) Bosch nozzles (the genuine VW T4's are excellent, not to be confused with "DLC 1019's" which are not Bosch) ~($300)
8) Downpipe --- Breathes better, gave me ~2 MPG, but it helped. (~$250-400 again depending on model). On the common rail 2009+ cars, as long as you are an off roader only (or decide to run for testing purposes) you'll find a DPF delete (roughly $550) and stage 2 tune will average a 5-8 MPG improvement.
9) Larger turbo--again better breathing leads to better economy. Hybrid turbos appear to do the best for economy. ($850-3,000+)
10) Have fun, you can be frugal and finesse the car without being a worry wart. It's great to get your first 50 MPG tank, and amazing to get your first 60 MPG tank. Be honest with yourself and others, and realistic as well. When a member goes from a 38 MPG average and then reports a 72 MPG tank no one will believe them. My gains were from 38-42, 42-48, 48-54, a ton of tanks in the 53-58 range, and then a few breaking 60. My personal record is 62.48 MPG. Not bad, especially in an MK3. Probably won't happen in an MK5 or MK6 though!
*Following this guide won't guarantee the same results, but it will guarantee better results than what you have now. I reserve the right to change this guide at any time .
Cheers, and happy TDI'ing!
-BB
***Cetane levels by fuel company. To ensure accuracy if you have a level to add to the list please forward an email from a corporate office to me, and I will add it to the list. Please bear in mind that the current minimum from refiners in North America is 40. Depending on the quality of the oil used as well as refining processes you'll find 40-42 from refiners in the US and Canada. Anything above that has to do with specific companies additive packages. When companies give a minimum value then it will be listed as a single number. When a company gives a range of numbers bear in mind that more often than not you'll probably find the lower number rather than the higher number. If 40 is listed then it generally means that fuel is bought as is from the refiner--if someone messes up and doesn't put in enough additive at the refinery then that can cause major problems for your fuel system. It's recommended therefore that if you get the inexpensive fuel with low cetane you use a cetane booster (PowerService, Lubromoly Cetane booster or Stanadyne are all great choices), or run a little biodiesel in the tank. If something higher than 42 is listed then the retailer adds their own additive package in addition to the standard refinery additive package. Generally speaking as long as 49 or higher is listed you do not need to worry about adding any additives yourself.
All California Diesel: Minimum 53 Cetane
Propel HPR, 75
Syndiesel, 60
BP (Amoco branded), 51;
Countrymark fuels Diesel-R, 50
Chevron, 49; or 51 with Techron D labels in select markets
ConocoPhillips through the 76 stations (California) 47-53
PetroCanada, 47-51
BP (Powerblend 47, otherwise 40-42)
Shell, 46;
Sinclair, 46;
Sunoco Gold, 45 (often +1-5) Sunoco regular is usually 40.
Exxon/Mobile, 43-46
Holiday Stations, 40-43
HESS, 40-42, can be up to 45.
Husky, 40 + diesel Max additives raise another 1-3 from there (41-45 max)
Pilot/Love's/Flying J/Valero/Sheetz/Walmart/Wawa: 40
for those in Washington State Cenex seems to have very high quality Diesel:
http://www.cenex.com/fuels/cenex-roadmaster-xl
I've been using it in our new 2015 Jetta S and the car just runs right!
the beave
the beave is offline   Reply With Quote
Old December 7th, 2015, 06:31   #902
MikeRoepassatTDI
Smile What kind of additives do People recommend for TDIs?
I have a 1996 Passat TDI 1.9
It has around 130k Miles, new timing belt, accessary belts, water pump, etc. I just revived Her from a 5 year slumber (non running, bought it from a Friend). It seems to run well, but doesn't want to rev much past 3500 RPM's.....
Could this be clogged injectors? Does anyone recommend "Seafoam" or some other additive to my car?
Tx
MikeRoepassatTDI is offline   Reply With Quote
Old December 7th, 2015, 10:22   #903
1998TDIMonster
Fuel Economy: 44 AVG. 48 Hwy best
Tx
Is it going into limp mode? Or can you feel the power throughout the power band? Was the timing verified using VCDS after everything was reinstalled? Clogged injectors could always be a possibility due to gunk getting in the I.P. after fueling and starting the car for the first time in many years. Not saying it is or isn't your problem in this case, but, if you plan on cleaning the injectors, i wouldnt use seafoam. I would use a bottle of diesel purge and make a setup where you bypass the fuel filter and run the car on the diesel purge only. It will not work nearly as well if you just dump it in the fuel tank. A quick search on the forum will reveal all the information you need to build yourself a setup to run the car on diesel purge.
I have used seafoam before and diesel purge. The seafoam (on a gasser) just smoked a lot. The diesel purge made the car run noticeably better. (Steering wheel used to vibrate from the rough diesel vibration. After the purge, idle smothed out so much that the steering wheel no longer vibrates.) if you want more scientific proof, my injector balance from group 13 went from +- 1.9 down to about +-.7. At 130k miles, it certainly will not hurt the car. Just remember, it is highly suggested you CHANGE YOUR OIL within about 1 week of doing the purge as it will deteriorate the oil. Love my 1.9l, lets just hope you dont mind getting your hands dirty! It is definitely a motor for people who are willing to do some of the work themselves! Good luck and let us know if you find anything else out.
1998TDIMonster is offline   Reply With Quote
Old April 8th, 2016, 14:44   #904
xcmer
xcmer's Avatar
TDI(s): Jetta MK4
Fuel Economy: 49
I've been following the tips here for a year or so and gotten tanks in the low 50s, but recently I've seen a bunch of advice of the perils of babying the engine such as liquid in the intercooler, soot buildup, and all that jazz. Is it an understood tradeoff, or is there a middle ground?
I'm hearing that going under 1800rpm is lugging the engine, and previously I was driving at 1500 most of the time, so...
xcmer is offline   Reply With Quote
Old April 8th, 2016, 20:42   #905
mr_y82
MK4? Pretty sure there's no intercooler issue to worry about like the CJAA... I only let it go below 1750 or so when I am rolling downhill or slowing... seems like little to no benefit running the MK6 below that... not worth it in my opinion.
EDIT. Thanks deejaaa, for clearing that up (below)
Malone Stage 2 Econo-Tune!;BuzzKen downpipe w/ cat!
2MicronTech Contain Flow and Pure flow Adapter FROSTHEATER
Appalachian Diesel Works, NC!(TRUSTED TDI MECHANICS)
Pre-tune: ~10k-70k mi = 40.5 mpgs; mpgs since tune_f_u_e_l_l_y_ ^
mr_y82 is offline   Reply With Quote
Old April 9th, 2016, 17:21   #906
deejaaa
deejaaa's Avatar
Fuel Economy: JETTA IS FOR SALE!
he's talking about oil pooling in the IC. it's a known issue. revving it up between shifts should take care of it.
THE 2002 jetta IS for sale. PM FOR DETAILS.
deejaaa is offline   Reply With Quote
Old April 10th, 2016, 07:58   #907
xcmer
xcmer's Avatar
TDI(s): Jetta MK4
Fuel Economy: 49
Thanks, will do!
Old June 21st, 2016, 22:21   #908
03arm
TDI(s): 2003 GLS
Fuel Economy: 54-55mpg
Default TDI Fuel Economy
Advisable - yes; depending on your driving destination. It would make a long trip quite tedious. I've practiced this with a gas engine as a pizza delivery driver & it makes a nice increase. Diesel is heavier than gas; so the practice makes more sense. Don't go below 1/4 tank however, to prevent crud in the bottom of the tank from getting into the fuel system. Hope this helps.
Originally Posted by sadi gaddi View Post
With due respect, I thank all of you for your tips. Its always a good learning process. Never forget - its a hobby.
Secondly, a simple question. Having less weight helps increase average. Would it be advisable to fill up only up to half tank and drive....rather than full tank. Condisering 7-8 gallons weight up to 60+ pounds.
thanks. Appreciate advise/constructive criticism.
03arm is offline   Reply With Quote
Old June 21st, 2016, 22:27   #909
03arm
TDI(s): 2003 GLS
Hi, I'm new to TDI's & diesel cars. You seem vary knowledgeable, so I ask; what is a PD?
Old June 21st, 2016, 22:29   #910
03arm
TDI(s): 2003 GLS
Hi, I'm new to TDI's & diesel cars. You seem vary knowledgeable, so I ask; what is a PD engine?
Old June 22nd, 2016, 18:14   #911
deejaaa
deejaaa's Avatar
you can say that again!
Old December 11th, 2016, 20:31   #912
KiwiCanuck
"very"
PD refers to the type of fuel injector. (I'll probably spell it wrong because I don't want to bother looking it up, but..) Pompe Duse (with the two dots (umlaut) over the "u").
There's a little solenoid-activated pump system in each of the injectors. It's more complicated than that, but professor Google can probably help more.
KiwiCanuck is offline   Reply With Quote
Old December 11th, 2016, 21:59   #913
turbovan+tdi
turbovan+tdi's Avatar
Driving it hard helps but if its that bad, he needs to drain it, otherwise runaway.
Old January 23rd, 2017, 08:16   #914
DPrlyG8
TDI(s): 2004 Jetta
Fuel Economy: 42
Default Would replacing my O2 sensor help with mileage?
I had an extremely intermittent CEL, something to do with the intake/MAF, don't remember the code, that would show up every couple of months. Replaced the MAF with a Bosch unit from http://metalmanparts.com/. My mileage went from mid 30s to low 40s, usually 41, 42. The CEL hasn't made a reappearance since, but now my cruise control won't maintain speed. Posts elsewhere suggest my O2 sensor may be bad. I am considering going ahead and replacing the O2 sensor. Any suggestions?
'04 Jetta TDI, manual trans, replaced cam and lifters, replaced IC, no mods
DPrlyG8 is offline   Reply With Quote
Old May 31st, 2017, 13:52   #915
JohnWilder
Fuel Economy: Average 53.25 mpg (4.4 l/100 km) over the last six months.
Tx
It could be low cetane. My ALH wouldn't rev above 3200 on one occasion. A new load of fuel seemed to correct this. I now put 1/4 oz. of non-additive 10w motor oil in the fuel. That seems to have corrected this problem. It also seems to have improved the fuel economy by about 1 mpg. You can get the oil at Tractor Supply.
JohnWilder is offline   Reply With Quote
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
Page generated in 0.20980 seconds with 9 queries
[Output: 141.95 Kb. compressed to 120.71 Kb. by saving 21.24 Kb. (14.96%)]
