cattlerepairman
...the one that houses the three auxiliary glow plugs (if you have a manual transmission) and sits on the driver's side of the cylinder head:
Use the exact torque values ...they are fairly low - 10Nm/7ft-lbs! If you tighten the bolts to what you THINK should give a good seal, the thing WILL leak because you destroyed the O-ring.
Yes, I may be stating the obvious. It may be some help towards avoiding an annoying coolant leak. Ask me, how I know.
