Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old December 24th, 2007, 16:01   #1
Or Turbo Diesel
Default Engine damage running on WVO... see pics...
I just removed the head on a car I bought- 96 Passat TDI, 300k, crank only turns about 30 degrees.
I have never seen a piston just dissapear!
(See pictures under members, OR turbo diesel)
I have only drained the water (coolant must be overrated); I am going to drain the oil and see if parts of the piston are there.
Anyone care to explain what may have happened? I bought it this way, prev. owner said he was coming back from a trip, overheated on the fwy., never would run again. He was running WVO, veggie.
Could an overfuel cause this (only 1 cyl. though), or a wvo problem?
Thanks...
Or Turbo Diesel is offline   Reply With Quote
Old December 24th, 2007, 16:08   #2
concours
concours's Avatar
Woooowwwwwwww... lot's of corrosion as well. Did it sit out in the weather?
2001.5 Jetta GLS TDI 5-spd, 345,000 miles, 1999 Jetta GL TDI, 165,000 miles, 1983 Jetta turbo diesel, 2-dr., 5-spd, A/C(RIP)
1980 Scout Traveller SD-33T
1986 Chev K10 6.2
concours is offline   Reply With Quote
Old December 24th, 2007, 18:33   #3
aNUT
aNUT's Avatar
TDI(s): '00 Golf
Fuel Economy: Good.
Thought putting the pictures in the thread would make things easier...
I cry for that poor TDI...
aNUT is offline   Reply With Quote
Old December 24th, 2007, 19:41   #4
whitedog
TDI Scholar
TDI(s): 2004 Jetta
Fuel Economy: 42
Holy Mother of God!
Time for a long block. since it's just one cylinder, the most likely cause would be the injector but it doens't look bad in this picture:
It could have been just dribbling fuel in with zero atomization.
How long did it sit?
Old December 24th, 2007, 20:03   #5
TurbineWhine
Fuel Economy: 56/50/39
I have a friend that was running WVO and his engine died after about 50K miles. The engine was trash and had to be replaced completely. His pistons were still there but the cylinder walls were so badly damaged it could not be repaired. I would suspect that engine is not repairable either. Hope you got the car real cheap.
TW
TDI Maintenace & Mods PM/Email me.
PP502's, RC5, 3 Bar MAP, R32 MAF housing with custome PTFE intake. 3" Downpipe, Open 3" exhaust, 25th Anniversary GLI springs, struts and shocks. 18 Inch wheels, AutoMeter Cobalt Boost & EGT in 47 DraftDesign's Pods, Custom TW Short Shifter. Custom Black & Tan leather interior (EuroJulien designed & installed).
TurbineWhine is offline   Reply With Quote
Old December 24th, 2007, 22:22   #6
Or Turbo Diesel
Is there such thing as a cheap TDI? It's ok, I have more parts to make a wagon swap happen. All the "corrosion" you see is actually metal left from the piston- it actually melted onto the cyl. wall, and I got a chunk out that was resting on the small end of the rod. Some tranferred to the head to, but it just fell off when I touched it. The rod scored the wall more than the piston!
Old December 24th, 2007, 22:24   #7
Dimitri16V
Dimitri16V's Avatar
can you say meltdown ?
PAK-FA flies !!
http://www.youtube.com/watch?v=7YCQsN8O_Q4
Fools are cut from the fabric of ignorance, and the American citizens make the cloth.
Do we blame others for robbing the bank when we hand them the keys to the vault and turn out the lights?
Goldman Sachs says they paid us back with interest. What about the $ 13 billion they stole out of our pockets thru AIG ?
2001 Golf TDi 134K
2004 Golf TDi 205K
1987 Scirocco16V 185K
1998 Camry 125K
Dimitri16V is offline   Reply With Quote
Old December 25th, 2007, 05:39   #8
Franko6
That appears to be an injector that wasn't ever shutting off. I've seen them like that. Instead of popping, they just spray and spray and spray.
But let's face it... that took determined driving to get that hole so completely cleaned out of aluminum.
The engine that turbowhine is talking about is DuluthRoosters. It's been bored out .5mm oversized and it's running quite happily in another car as we speak.
But where did the rod go? It doesn't hardly look like it touched the cylinder walls.
Also, despite the heating that the piston took, That cylinder head looks retrievable. I wouldn't use those two valves...
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old December 25th, 2007, 06:36   #9
mijbo11
mijbo11's Avatar
WOW.
im not surprised. The Injection components just cant handle the wvo.
Ive seen larger engines just cut holes through forged pistons and cut cylinder liners like you were using a plasma cutter.
02 Jetta Tdi 219000kms
99 jetta tdi mk3 430000kms
Journeymen Heavy equip mech.
Detroit diesel guild member(Former)
Volvo equipment guild member.
mijbo11 is offline   Reply With Quote
Old December 25th, 2007, 07:41   #10
Drivbiwire
Zehntes Jahr der Veteran Vendor
Drivbiwire's Avatar
The cause is referred to as "streaming" where the nozzles become plugged and are no longer able to atomize the fuel. This becomes a bigger issue with higher viscosity fuels which is why WVO is perhaps the stupidist thing anybody can do to a diesel.
Larger injector holes ie "Pintle" design are the ideal nozzle for WVO applications where more viscous fluids are used.
What occured was the fuel streamed, the jet of fuel rather than atomizing came in contact with the aluminum of the piston. In normal combustion the fuel NEVER comes in contact with the surface of the piston! The swirl within the chamber mixes the droplets of fuel during the "ignition Delay phase" then autoignition occurs without any contact with the piston bowl.
Streaming and use of WVO or thicker oils causes fuel to fail to mix with the "swirl" in the bowl, the slower mixing results in increased contact and burning of the piston as evidenced by the high levels of black soot on the surfaces.
DB
Digital Calibration and Flow Balancing www.drivbiwire.com
Get your injectors NOW without any downtime: Hot Swap Injector Program
*Check out our new Hot-Swap program, no downtime and injectors are shipped to you ready for install with the nozzle of your choice!
*Insist on Genuine Bosio nozzles, All of our nozzles come with Bosio issued Authentication ID#'s traceable directly back to the factory.
Old December 25th, 2007, 10:26   #11
Or Turbo Diesel
The rod appears fine- wrist pin scored the walls, but I see no rod contact. Sounds like that one injector has a big problem. They may not have been serviced in a long time (if ever).
I let a head rebuilder look at the head, and he said no problem. Of course the 2 valves are junk.
Perfect example of what can go wrong with "free" fuel!
Old December 25th, 2007, 19:09   #12
WB9K
WB9K's Avatar
Fuel Economy: 38.5-42.0 mpg depending on season.
Yeah....in the hands of an idiot. Like Franko6 said, it took some real effort to get to this point. Anyone who ignores the symptoms that had to be visible leading up to a failure like this deserves what they get. These people don't need experimental fuel to destroy what they touch, but it can sure help. Was that 300k miles or kilometers? How many on WVO? That poor engine....
dh
2002 Jetta GLS TDI
WB9K is offline   Reply With Quote
Old December 25th, 2007, 19:21   #13
WB9K
WB9K's Avatar
My first thought was major leakage from the injector. In either case, would the ultimate failure mode be hydrolock? What causes an injector to stick open like that (not pop off), other than total neglect?
Did the piston melt down or break apart, or both? What's with all that rust--blown head gasket?
dh
2002 Jetta GLS TDI
Old December 26th, 2007, 05:34   #14
ninedee_golf_tdi
A novel way to transform a 1.9 into a 1.4.
ninedee_golf_tdi is offline   Reply With Quote
Old December 26th, 2007, 06:13   #15
WB9K
WB9K's Avatar
And a 100% fuel savings! ZERO emissions!
dh
2002 Jetta GLS TDI
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.13351 seconds with 9 queries
[Output: 120.96 Kb. compressed to 99.54 Kb. by saving 21.42 Kb. (17.70%)]
