Old July 29th, 1999, 10:52   #1
dparnell
Default Kreen---internal engine cleaner
I put a hole in my oil pan @4000Mi( rough dirt roads). I put a new one on and filled up with 15-40 reqular oil. I also added 16oz of Kreen which is supposed to keep your engine clean. The oil was dark @ 4000 mi but not pitch black. I figured the engine couldn't be very dirty inside @ 4000 mi but since I was adding a thicker oil than I wanted, I'd add the Kreen also. Checked the oil a couple of times after that to make sure of level and the oil was the only very slightly darker. After about 650 miles, the oil is darker than it was at 4000 miles.
There was more crap in the engine than I thought.
Conclusion:
It works.
Also put some in the fuel and noticed increased power.
dparnell is offline   Reply With Quote
Old July 29th, 1999, 15:04   #2
dparnell
Default Re: Kreen---internal engine cleaner
Kreen is made by Kano Labs @ www.kanolabs.com I've been using it for about 6-7 months now. It's not like any other cleaner I have used. It's a dirivative of one of their other products, Kroil---which is the best nut/bolt loosener I've used. I've had many customers use WD40 as a lubricant. While it has some lubricating properties, it's really a solvent---if you get reral greasy, spray WD40 on your hands before using any cleaner---it will dissolve most of the grease.
The consistency of Kreen is that of WD40. The way I think it works is that it gets into all the nooks and crannies the the detergents in the oil miss and gets the crapola suspended in the oil before it evaporates in a short time. I have used it in all my cars, trucks and generators. You also put it in your fuel and it decarbonizes and cleans it. After running 50 gallons of treated fuel thru my Onan generator, I had a TREMENDOUS amount of soot at the exhaust point. The engine was more quiet and ran better.
The same time I put it in the oil of my Golf I also put it in the fuel---I noticed more power. The current tank is treated with DEE-ZOL and I have noticed a decrease in power. I have noticed increses power in the gas vehicles as well. Mileage is tough to calculate since my fuel comes from my own tanks(the local gas stations' cheapest gas is $2.12.9). I like it so much, I went thru 2 five gallon pails in the first 6-7 months and just received a 55 gallon drum.
Old August 3rd, 1999, 16:09   #3
lundgrji
Engines do get dirty inside, even with regular oil changes and more so with dino oil. I've taken apart high mileage engines which appeared clean inside, except for the varnish coating the parts. No sludge, just a nice even carmel color painted over all the surfaces. Hot oil breaks down into carbon and varnish. The varnish restricts oil passageways and insulates internal engine parts, reducing the heat transfer to the oil, which increases oil temps and causes even more oil break-down and varnish formation. The condensation within the engine combines with the varnish and carbon, creating sludge. Additionally, condensation mixes with combustion by-products, including sulphur, to create acids which attack engine metals.
Once I became convinced that regular oil changes were not enough I started flushing my engine perodically. In fact, my VW dlr has a Bilstein engine flushing machine. I choose to add 8 oz of Gunk engine flush and let the engine idle 5 minutes. I drain the oil and then add 4 qts of cheapo, on sale, rebated, can barely give it away dino oil and agressively drive the car for 10-15 minutes. Afterwords I drain the oil again and replace the filter. The oil in my TDI does not get black for seveal thousand miles after flushing it. Without the flush it was black almost immediately.
I'd be concerned about leaving a strong solvent in the crankcase for extended periods, however.
lundgrji is offline   Reply With Quote
Old August 1st, 2016, 09:15   #4
RedTDIowner
RedTDIowner's Avatar
Fuel Economy: 46/41
I hate bumping a thread after this many years but I have always heard that you should only use synthetic oil in our TDI's and never use an oil additive to it. Do you all agree or do you suggest adding things like Kreen, Marvel Mystery Oil or Auto-RX to clean out the inside of your diesel engine?
We're all here 'cause we ain't all there!" - Gold Rush
RedTDIowner is offline   Reply With Quote
Old August 1st, 2016, 20:04   #5
patbob
patbob's Avatar
I wouldn't bother, certainly for the newer cars. The oil gets black from the soot in the blowby, and no amount of engine flush is going to fix that. If you want clean-looking out, install a bypass oil filter that filters the soot out.
"Oh, so those stickers on the back of peoples cars are for their families? I thought they were ace drivers or something."
patbob is offline   Reply With Quote
Old August 2nd, 2016, 00:48   #6
MichaelB
I agree that Kroil works very well as a penetrating oil for rusty bolts or any other stuck fastener. Now that is were I will stop agreeing. All these additives to the oil including Kreen are just making your wallet thinner. If you ran the correct synthetic in your engine and changed your oil at appropriate times you don't need any of that stuff. Following these forums how many oil related damages can you count being reported here?
MichaelB is offline   Reply With Quote
Old August 2nd, 2016, 04:06   #7
RedTDIowner
Fuel Economy: 46/41
Thanks guys. That is what I thought. I have always used synthetic 5w40 oil and changed it at 5,000 miles so even though I am almost at 300,000 miles I won't worry about it.
Old August 2nd, 2016, 04:26   #8
MichaelB
You never had anything to worry about
Old August 2nd, 2016, 11:53   #9
Ol'Rattler
Ol'Rattler's Avatar
Kroll, good stuff. Kreen, probably snake oil. Don't use it. Using the correct oil for your engine is all you will ever need to do.
Changing oil at 5K miles is a waste of resources. Look at your maintenance schedule. I believe it says 10K miles for oil changes. If nothing else on your engine breaks, you could easily go 400K miles without oil change issues at 10K intervals.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old August 2nd, 2016, 13:16   #10
belome
Fuel Economy: 47'ish
It blows me away that people just can't shake the 3k mile oil change that has been pushed on the public for decades.
Especially when they are blowing sometimes $10 a liter on the stuff.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is online now   Reply With Quote
Old August 3rd, 2016, 14:01   #11
Ol'Rattler
Ol'Rattler's Avatar
Yup. I remember 3K oil changes and 10K tune-ups. The past is what it is, the past. Time to move on to modern times..............
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Page generated in 0.14026 seconds with 9 queries
[Output: 101.64 Kb. compressed to 85.60 Kb. by saving 16.04 Kb. (15.78%)]
