| TDI 101 Got a simple/basic TDI question? Are you a newbie (new to the forums). Feel free to post your question here. |
December 4th, 2007, 09:36
#1
Lifespan of the VW TDI engines
Greetings all. I am considering a TDI VW Jetta or Beetle 99-2004. I was curious what is the expected lifespan of a properly maintained VW TDI? I know the Benz is touted at several hundred thousand miles, but I have not been able to find any posts regarding the VW. Thanks in advance.
December 4th, 2007, 09:40
#2
Oil Wanker
300,000 + miles.
Even then the motor isn't dead, just some wore out parts need replaced, then keep on motoring.
December 4th, 2007, 10:21
#3
Mega-Miler
Fuel Economy: 46 mixed/51 highway
There are dozens of threads on here concerning high-mileage VW TDI's. Mine is going strong with no major parts replaced (including the clutch, turbo, injection pump) at 338,000+ miles. Many more here with even more miles.
How long it (and the rest of the car) will last depends on how you drive it, and what kind of driving you do. Short story is city driving=short life, highway driving=long life.
December 4th, 2007, 10:28
#4
Pre-Forum Veteran Member
Fuel Economy: Which VW diesel? There have been Twelve of them!
The expected lifespan of a TDI shouldn't be any different than any other engine, gasoline or diesel, which has been properly maintained.
Why do diesel or M-B engines last so long? Because owners expect them to last that long. It's a self-fulfilling prophesy.
Better maintenance practices are used on engines that have the expectation of lasting longer, less maintenance is expended on 'disposable' engines. Treat a TDI like a disposable and it will BE disposable.
Svante Arrhenius 1896
December 4th, 2007, 12:08
#5
Fuel Economy: 13.7 c, 12-18 towing hwy
Couldn't have said it better myself!
December 4th, 2007, 13:13
#6
on hiatus
Quaker State conventional 5w30 = 130,000 miles before the engine is shot
vs
VW505.01/VW507.00 = 1,500,000 miles before it lacks enough compression to continue proper operation
There is a difference between "proper" servicing and "overmaintaining".
People that replace air filters every 5,000 miles instead of every 40,000 (or based on actual restriction) end up with more damage to the engine due to lower filtering efficiency.
People that change oil every 5,000 miles have 4 times the wear due to the oil additives never becoming stabilized/activated where as the engine would have benefited from 10,000 mile intervals with all around better protection.
Keeping the fuel system operating at peak efficiency, fuel filters replaced by the book (20K), If you see soot or smoke...get it fixed! Excess smoke is your first indication something is not right, soot will kill these engines in short order not to mention put at risk the high pressure regions of the motor (cam and lifters).
The best thing any owner can do is COMPLETELY read the owners manual and the maintenance manual that came with the car.
DB
December 4th, 2007, 14:01
#7
DB
...and then FOLLOW the instructions.
I've read the bible. That doesn't mean I'm bound for glory....
December 4th, 2007, 14:26
#8
My 2 cents:
Diesels generally last longer than comparable gas engines because they are built stronger for higher compression, run at lower rpms, and where gasoline destroys lubrication in engines, diesel fuel doesn't. Cold start-ups are also a negative for gasoline engines because of all that extra gasoline needed to start.
On the other hand, GMC "attempted" to convert gasoline engines to run diesel which weren't worth a sh#%, they were the old ToroFlow engines. Other than these engineering embarassments, diesels do last longer in general.
2000 Jetta GLS TDI
5spd Silver/Black 220k miles
Sprint 520
December 4th, 2007, 14:27
#9
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Except for the times that the owners' manual contains gross errors: such as the early 2004 VW manuals that specified the use of 505.00 oil... there were quite a number of those reported...
Yuri.
December 4th, 2007, 15:10
#10
Ive got 215,000 miles on a '04 PD motored wagon the only thing i've had to replace is an alt. pulley, intake hose and a MAP sensor and of course 2 timing belts. The thing still has it's original brakes, clutch and shocks(they are going away soon). Though someone stole my EGR valve a few months ago I guess they sell well at the flea market at least they blocked off the manifold holds....
Make sure the car your looking at has had the belts replaced per the service book and oil and filters changes. Use the search function on this forum. It's saved me alot of money on my car.
'04 PDWagon, RC3, VNT17,PD150 inj's,FO6S2 cam = 3rd gear wheel spin
356,000 miles
Respect, protect, and maintain complex systems - whether natural or of German design, to benefit from their full potential.
December 4th, 2007, 16:28
#11
Fuel Economy: Who cares? It's a DIESEL!
With "only" 259k miles currently on my 02 Golf TDI, it's still way too early to tell what its projected "lifespan" will be.
I plan on logging at least another quarter million miles on top of the quarter million miles already on it.
David Sterrett, N1DAS
2005 ATD PD Jetta Wagen TDI, Weapons-Grade TORQUE, 150k miles
2008 Ford F350 SuperDuty 6.4 PSD, 650 ft-lbs Torque Monster, 70k miles, bone stock (for now)
December 4th, 2007, 16:30
#12
R. T. F. M. !
December 4th, 2007, 21:33
#13
PAK-FA flies !!
http://www.youtube.com/watch?v=7YCQsN8O_Q4
Fools are cut from the fabric of ignorance, and the American citizens make the cloth.
Do we blame others for robbing the bank when we hand them the keys to the vault and turn out the lights?
Goldman Sachs says they paid us back with interest. What about the $ 13 billion they stole out of our pockets thru AIG ?
2001 Golf TDi 134K
2004 Golf TDi 205K
1987 Scirocco16V 185K
1998 Camry 125K
December 5th, 2007, 09:25
#14
I have a simpler formula calculating the life of a TDI engine.
300k
O1m = 2.2/3.7, easy enough. (Translation: 2.2 to 3.7 O1M automatic transmissions/300,000 miles)
December 5th, 2007, 11:00
#15
persona non grata
vs
DB
With all due respect half of this is bs. Show me proof that my engine will wear faster if I change oil every 5,000. These statement are your opinion and nothing more. My first engine lasted 285,000 miles and still looks good inside. No unusual bearing wear,cylinder walls in great shape.
