Old November 27th, 2007, 14:08   #1
Dieselaya
TDI(s): 93 Jetta
Default Fuse panel diagram
Does anyone have a fuse panel diagram for A3 Jetta (98)?
Thank you!
Dieselaya is offline   Reply With Quote
Old November 27th, 2007, 15:26   #2
P2B
P2B's Avatar
Thank you!
Is this what you are looking for?
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Old November 28th, 2007, 04:56   #3
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
The "Glow plugs 2)" fuse is the coolant heater fuse. The cylinder glow plug fuse is in a holder snapped into the top of the relay and fuse block.
Also my 98 A3's lighter fuse is combined in fuse 21 with other items, not a separate, remotely mounted fuse.
Svante Arrhenius 1896
Old December 2nd, 2007, 16:02   #4
roni024
I'm pretty sure the glow plugs 2) fuse refers to the cylinder glow plugs, and is located on the top of the fuse/relay block. The coolant glow plug fuse is a strip fuse located in the engine compartment along the rear firewall.
roni024 is offline   Reply With Quote
Old December 3rd, 2007, 10:20   #5
Lug_Nut
Lug_Nut's Avatar
...which would be "in the engine compartment above the brake booster" now, wouldn't it?
The 80 amp fuse for the cylinder glow plugs is mounted inside, above the fuse and relay panel. The 50 amp fuse for the coolant heaters (which VW also calls "glow plugs") is outside, in the engine bay.
Old December 3rd, 2007, 16:48   #6
roni024
You are correct. My mistake.
Old December 22nd, 2007, 07:39   #7
hendomatic
hendomatic's Avatar
Where can one get the 50 amp strip fuse? My current fuse(pardon the pun) is looking rather stressed and the little box its sitting in has some heat damage as well.
I've been wasting my time looking for fusible links.... strip fuse.. whoda thunk.
Hendo
98 Jetta TDI 278K miles new TB at 267K
PP520 nozzles,pop tested and shimmed by DBW,RC3+, GT2056, FMIC with Euro Bumper,Disc Brake Upgrade,boost valve, Mufflerectomy, Boost/EGT gauge, New IP at 233K miles
hendomatic is offline   Reply With Quote
Old December 26th, 2007, 11:38   #8
roni024
That fuse is a dealer part, but it costs less than $2. The box is, from what I understand, pricy and difficult to R&R.
Page generated in 0.12297 seconds with 9 queries
[Output: 80.22 Kb. compressed to 68.41 Kb. by saving 11.80 Kb. (14.71%)]
