christi
My B4 wagon now has 140,000 miles
I have been noticing for a while that if I accelerate at full power that the engine starts to cut out at just above 4000rpm.
If I rev the engine in neutral, or drive at high revs but not accelerating hard then the engine goes cleanly right up to the rev limiter as it should.
It seems then that the tank can supply enough diesel for almost full power, but at 4000rpm at full power I think that the pump starts to starve and so the engine cuts out.
I changed the fuel filter and it made no difference.
Then last night the car quit completely in the fast lane of the M25
Luckily I was doing 80mph and managed to coast across all three lanes and onto the hard shoulder.
The fuel gauge was shoing almost empty but not completely.
I had a 5 litre can of diesel so I put that in, and then the car restarted so I drove to a filling station and filled it.
I only got 65 litres into the tank, so when it quit there was still at least 5 litres still in there.
When I got home I changed all four rubber leak off pipes on the injectors because years ago an old Audi 80 TDI that we had did a sort of similar thing when they perished, but it hasn't made any difference.
Also I looked at the clear line from the filter to the pump and there are no bubbles.
What could cause the motor to quit with 5 litres still in the tank and also prevent full flow of fuel at full power?
Are there any extra filters on the tank or something?
