Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old October 24th, 2007, 21:52   #1
Efrain
Default Can I run my 1998 Jetta Tdi run on Biodiesel?
Hi there,
I just bought a 1998 Jetta TDI with the intention of using Biofuels. I want to start using Biodiesel right away but I am not sure if I have to change some of the hoses. I have heard different opionions about this. Some people say it is ok to use biodiesel with out any changes to a 1998 jetta, others say is better to replace the hoses. I know that older models use rubber hoses which eventually corrode and start leaking, and newer models come with sintetic hoses which resit the use of biodiesel.
Any advice would be appreciated.
Thank you,
Efrain
Efrain is offline   Reply With Quote
Old October 24th, 2007, 22:28   #2
compu_85
Gadget Guy
compu_85's Avatar
You can use biodiesel in that vehicle just fine. The only rubber lines are the small return lines between the injectors. All the other fuel lines are plastic.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old October 25th, 2007, 02:20   #3
RC
RC's Avatar
Welcome, you'll be just fine. Might want to keep an eye on the inter-injector lines. If they are original they are due for a changeout but the B100 might just push them over the line.
Two 96 TDI Passat Wagons, Bypass Filters, Chipped
87 MB 300TD, 97 Ram2500, Kubota Tractor
24 cylinders sipping the sweet sauce of the soy bean
RC is offline   Reply With Quote
Old October 25th, 2007, 06:40   #4
BioDiesel
TDI(s): '98 Jetta
"Might want to keep an eye on the inter-injector lines. "
When you do replace these, use the stock lines. They'll last for years.
BioDiesel is offline   Reply With Quote
Old October 25th, 2007, 06:45   #5
RC
RC's Avatar
I'd go with Viton myself.
Old October 25th, 2007, 06:51   #6
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
The other thing to look for is the solvent effect of the biodiesel; it may dissolve all the crap in your fuel tank, lines etc and move it to your fuel filter.
Have a spare on hand and change your existing filter soon.
bluesmoker is offline   Reply With Quote
Old October 25th, 2007, 12:15   #7
BioDiesel
TDI(s): '98 Jetta
"'d go with Viton myself."
Hi RC,
iirc, someone who tried this found the squishy Viton slipped off and made a mess. Is there a way to avoid this?
Old October 25th, 2007, 12:17   #8
bayshorecs
bayshorecs's Avatar
TDI(s): 06 Golf
Fuel Economy: 40
A small zip tie on each injector fuel tip IIRC.
bayshorecs is offline   Reply With Quote
Old October 25th, 2007, 12:17   #9
tdiengine
tdiengine's Avatar
TDI(s): 2006.5tdi
Default Dont forget a spare fuel filter
Originally Posted by Efrain
Hi there,
Thank you,
Efrain
Please dont forget to have a spare fuel filter.
Jetta 2006.5 27k plus(on vacation in the garage)
Jeep Grand Cherokee 2008 9/21/2007 3.0LCRD
Isuzu npr diesel
GL320 cdi2006 17kmiles(I gave the vehicle to my mother)
E320 cdi 2007 8kmiles
Ford F350 powerstroke 2001 46kmiles(use it to collect used vegie oil)
mensa member
2007 Maserati QUATTROPORTE, a gift as promised by my mother when I graduated from residency.
tdiengine is offline   Reply With Quote
Old October 25th, 2007, 18:29   #10
RC
RC's Avatar
Hi RC,
I've installed more viton than I'd care to imagine and never had a hose slip off. Did the guy have the correct hose and size?
Old October 25th, 2007, 18:30   #11
RC
RC's Avatar
Originally Posted by tdiengine
Please don't forget to have a spare fuel filter.
As one who drives a diesel should... no matter what type of fuel they burn.
The clogged filter thing is way overblown, a rarity.
Old October 26th, 2007, 11:57   #12
ikendu
ikendu's Avatar
Fuel Economy: 46 mpg
You might want to stop by my website and browse the biodiesel question and answer page.
www.itsgood4.us
One week to save the Earth: Simple actions for culture change
ikendu is offline   Reply With Quote
Old October 29th, 2007, 14:18   #13
McBrew
McBrew's Avatar
Fuel Economy: 54/50/44 (usually running B100)
I cannot agree with RC enough -- Drive a diesel? Carry a fuel filter!
This is even more true with the newest generation of diesels. The local Dodge dealership is seeing a LOT of Sprinters coming in with clogged fuel filters. They say it is because the filtration is so fine that they clog more easily than those of the past. I have had my Sprinter fuel filter clog on my twice. Due to the scarcity of that filter, I always keep a plare and the tools in the van. Same with my TDI and my motorhome.
-McBrew
2015 Fiat 500 Abarth cabriolet.
2016 Kia Sedona - the wife's car, but I secretly like it.
Still have 3 TDIs in the family fleet.
McBrew is offline   Reply With Quote
Old October 29th, 2007, 17:02   #14
xbillyx
Definitely good advice. Carry one in your truck always.
1999 VW Jetta TDI 5-spd (A3) 209k
xbillyx is offline   Reply With Quote
Page generated in 0.16016 seconds with 9 queries
[Output: 117.39 Kb. compressed to 97.34 Kb. by saving 20.05 Kb. (17.08%)]
