Old October 9th, 2007, 04:57   #1
Jesse_Boyer
Default fuel door won't pop open...
The trunk button works, but nothing happens when I hit the fuel door release. This is pretty much the last item I have to fix before this is 100%, but I'm not even sure where to start. Does anyone have any suggestions on how to get started?
'03 Nemo Blue S6, AirLift, Garage queen/spare.
'02 Black S6, 01e swap, muffler delete, permanent smile maker.
'00 A6 2.7t 6sp. Message me for parts requests
'01 allroad 6sp, parts car. Message me for parts requests
Jesse_Boyer is offline   Reply With Quote
Old October 9th, 2007, 05:09   #2
Phoenix42
Phoenix42's Avatar
Do you hear a noise when you operate the button?
On mine the spring that pushes out the door was busted, adn I'd hear the selonid operate but the door would not pop open.
Empeg, more tunes then you can shake a stick at.
Backup your 'My Documents' for free with Mozy.
I'm a loaner.
Phoenix42 is offline   Reply With Quote
Old October 10th, 2007, 05:49   #3
Jesse_Boyer
nope, no noise. i can hear the trunk pop, but nothing with the fuel door. Unless it's 'that' quiet compared to the trunk. Regardless, I don't hear anything
Old January 15th, 2009, 23:39   #4
dknytech
I am having this exact same issue. I can hear a noise when I pull on the trunk release switch but nothing when I try to open the fuel door. Is it the fuel door switch? If so, do I have to take the whole door apart to get at it? Does any one have the part #? Thanks in advance.
dknytech is offline   Reply With Quote
Old January 16th, 2009, 02:45   #5
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Fuel door
There is a TB on this. Do a search- it has been covered in the past.Volkswagen Technical Service Bulletins
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old January 16th, 2009, 05:14   #6
dknytech
I fail to see anything regarding my issue listed here.Volkswagen Technical Service Bulletins. After searching for some time I managed to find that the door does have to been taken apart, but I still cannot find a part # for the OEM replacement fuel door switch.
Old January 16th, 2009, 05:36   #7
puter
Fuel Economy: 57 mpg
Ahh, search **** strikes again!
puter is offline   Reply With Quote
Old January 16th, 2009, 05:48   #8
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
__. DK, it may not be the switch in the driver's door (in fact, I'm pretty sure that it usually is not). The system has the driver's door switch, wiring, and the operating mechanism at the fuel filler. You could have a disconnected connector at the driver's door button or at the operating mechanism. And, as noted, the filler flap won't open if the spring doesn't work properly -- in that case, the mechanism will retract just fine but then it relocks when you release the button and the filler flap stays closed.
__. The only way to handle this is to get some help. Put your ear to the filler flap and have your helper pull the button on the driver's door. If the mechanism is working, you will hear it. If you hear it working, then the problem is the spring -- you deal with that by getting something soft and smooth (a rubber or soft plastic strip, for instance, so you don't scratch the paint) and lever the flap open while your helper pulls the switch; that will work fine.
__. I've never actually dealt with this situation before, but listening to people talk on this forum, it appears that here's the order of priority:
1) Bad spring
2) Bad mechanism at filler flap
3) Loose connector at switch in driver's door
4) Bad switch in driver's door
__. Perhaps someone who's done it recently will comment on whether there's a combined connector at the switch for the trunk latch and the filler. If so, then the fact that the trunk latch works means the connector is in place -- but you need to confirm that there is a combined connector.
__. Since this is a "non TDI specific" problem, I'd do a search at VWVortex, too. There's often good info there.
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06) 130K mi in 4 1/2 years/~57 MPG lifetime; New car, '03 Jetta Wagon, CAT filter, .681 top gear, 270K mi. in 8 1/2 yr, ~52
mrGutWrench is offline   Reply With Quote
Old January 16th, 2009, 05:55   #9
2004STARWARSTDI
Default TSB for fuel door!
Look here, it is in 2006 section:2006 VOLKSWAGEN JETTA TSB 0501 Details
Old January 17th, 2009, 22:38   #10
dknytech
Update:
Took the door apart today to clean and check the harness connections. No luck. Went to the dealership and purchased new switch $41, ouch. FYI Part # 1J0 959 833 A. Installed new switch and tested about 20 times, works great. I was about to throw the old switch away when I decided to take it apart. Very easy to do just be careful. Upon inspecting the inside of the switch the contact points that touch when the switch is pulled seemed to be dirty, cleaned them with contact cleaner and wiped with a Q-tip, looks like new again. Seeing as it only takes 5 minutes to remove door panel I decided to install the newly cleaned switch and wouldn't you know it, it works. Wish I would have thought of trying this first. I ended up installing the new switch that I bought today because I cannot return it, but I will keep the old just in case. So I recommend to anyone having this same problem to try this first, it might save a guy a few bucks.
Old January 25th, 2009, 04:24   #11
MCathcart
TDI(s): 2003 Jetta
Exclamation
Yep you are Correct... Most all VW switches are Repairable. After owning 8 VW's since 1998 I repair window switches when the Pivot breaks off. I've said before I'd do a HOW TO on them but just never took time.
MCathcart is offline   Reply With Quote
Old January 25th, 2009, 10:17   #12
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Anyone know of a way to get a new spring for the fuel door? I actually lost mine when doing the vent mod. Now I have to stick a credit card in the fuel door then go and pull the switch. My door is starting to get chingered up from the card sliding in and out.
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old January 25th, 2009, 10:34   #13
whitedog
The original poster has a 2001, so why would you direct him to a TSB for a 2006?
Also, this is the only information I found there:
Fuel tank lid does not close, unlock motor -v155 - does not return properly. *tt
Not real helpful in fixing the problem. Maybe I'm missing a step in finding what this TSB has to say?
Can fold paper in half eight times.
Old April 4th, 2015, 21:39   #14
Dans4
Dans4's Avatar
TDI(s): 2010 JSW
Necro bump -
I hear no sound when using the trunk release or fuel door.
Any one have wiring schematics for the door?
I can manually open fuel door.
thansk,
Dan
2010 JSW
Dans4 is offline   Reply With Quote
Old May 25th, 2015, 14:47   #15
alex_tdi
I too have a 2001 Golf and I can hear the sound of the solenoid but the fuel door won't open sometimes. I would have to do it a few times before it pops.
Any idea on what could be wrong?
--UPDATE--
I think I found all the related instructions:
http://workshop-manuals.com/volkswag...over/removing/>
http://workshop-manuals.com/volkswag...trim/removing/
I'm going to try this and see if I can access the actuator in the c-frame.
Alex
alex_tdi is offline   Reply With Quote
Page generated in 0.17495 seconds with 9 queries
[Output: 127.71 Kb. compressed to 106.06 Kb. by saving 21.65 Kb. (16.95%)]
