eats1963 said:
It's getting close to that time of year when the weather will be getting cold, and this is the first diesel car I have ever owned.
It's funny to hear you say this when it was almost 90 degrees yesterday.
eats1963 said:
I have heard that in real cold weather, the diesel will "gel" up. I live in Chicago, IL and sometimes the temperature drops below zero for quite a few days, and more often at night.
This is true.
However, most responsible, reliable diesel merchants will make sure their fuel is winterized appropriately for the upcoming cold. I have an uninsulated, unheated garage, and I keep a mason jar of untreated-by-me fuel in it. Even last winter when it was -11 F (-24 C) outside, the fuel was still bright, clear & completely liquid, and both cars fired up like it was 60 degrees out. Toss in a little bit of your favorite antigel - I've used Howes Diesel Treat and Power Service winter formula (white bottle) - and never gelled.
Buy fuel from a reputable, high-turnover station (truck stops are great), treat it with whatever fuel treatment you like and change your fuel filter before winter. Make sure your glow plugs & battery are in working order, and make DARN sure you have the correct oil in your car (5W-40 diesel-rated synthetic, your 01 will do fine with Shell Rotella T (blue bottle) or Mobil 1 Turbodiesel Truck) and you should have no problems.
Since you're in the Chicago area, you might consider coming up to the
GTG in Fond du Lac, Wisconsin at the end of the month. Meet some of the locals, learn a bit about your car, generally hang out & have a good time. Good time to do pre-winter maintenence, too.
Now it's time for me to drive to get lunch... with the air conditioning on.
Lousy Octember weather.
