Old October 1st, 2007, 08:07   #1
kbryson
Default Battery Size?
I just purchased a 2000 Jetta and the maintenance receipts that came with it mentioned the car battery is too small, thus some problems starting in the cold. The lady I bought it from didn't seem to like their advice and never changed the battery.
What is the proper size battery for this car, so I know what size to get if this becomes a problem. How can you even tell what 'size' the battery is?
-k
kbryson is offline   Reply With Quote
Old October 1st, 2007, 08:10   #2
dieseldorf
top post dawg
dieseldorf's Avatar
search for the term 94R
Old October 1st, 2007, 08:35   #3
kbryson
Thanks, I had searched on battery size but that 94r is the key that I didn't have.
cheers,
kb
Old October 1st, 2007, 09:06   #4
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
cheers, kb
__. I'd add that you should be a little careful of what you read. Some service people (dealership and others) will invent some pretty fanciful stories to cover up their own incompetence. A TDI puts some pretty stressful demands on its battery but the stock battery is up to the task. If it has a stock battery in good condition and there's starting trouble (anywhere warmer than about -45F), then it's not the battery. But a number of battery types are the same size as the stock TDI battery but they don't have the capacity to perform as well. Be sure that you replace with a stock battery or a genuine equivalent.
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06) 130K mi in 4 1/2 years/~57 MPG lifetime; New car, '03 Jetta Wagon, CAT filter, .681 top gear, 270K mi. in 8 1/2 yr, ~52
mrGutWrench is offline   Reply With Quote
Old October 4th, 2007, 13:36   #5
otbBlaine
otbBlaine's Avatar
TDI(s): 2002 Golf
Fuel Economy: 44ish regularly
I just put an Interstate MTP-H7 in my car (no more than 5 min ago); $161.95, 30 mo. free replacement, 85 mo. pro-rated. Compares to OEM at $119.95 with 12 mo. free replacement, 60 mo. prorated.
The OEM battery I replaced was less than 30 months old.
A man who procrastinates in his choosing will inevitably have his choice made for him by circumstance.
otbBlaine is offline   Reply With Quote
Old October 4th, 2007, 13:38   #6
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
That is what I recommend, too. Although it won't fit in the NB
oilhammer
www.cardocautomotive.com
Old October 5th, 2007, 08:58   #7
scooperhsd
New Beetles (TDI) get Group 48 batteries.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old October 5th, 2007, 09:19   #8
mrGutWrench
__. The Interstate battery has some really nice warranty/service specs but is it up the job of cranking a TDI when the engine is cold? TDI's put some heavy loads of batteries. Batteries with "ordinary" CCA and Reserve capacity will work very well in a gasser but fail in a TDI.
__. The OEM battery in my '02 sedan went nearly 5 years before the car was totalled and it was fine then. Dunno about the battery in my '03 wagon but MzLauraLee is still on the original battery in her waggin (pushing 4 1/2 years old). All my batteries get the cells opened and distilled water to bring them up to level at least twice a year (it usually takes a good bit - these ARE NOT "sealed"/maintenance-free batteries).
Old October 5th, 2007, 09:36   #9
oilhammer
oilhammer's Avatar
The MTP-H7 is a wee bit more than the factory battery rating, actually, and has a 7 year warranty. We have never had one fail.
oilhammer
Old October 5th, 2007, 10:08   #10
weedeater
Fuel Economy: 54/43/38
Actually, there are two 'size' ratings you should consider. One is the physical size (and layout) specified as 'group' (48 or 94R). The other is CCA (cold cranking amps), which should be the largest you can attain in the physical size for your car.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old October 5th, 2007, 11:24   #11
weasel
Deactivated Member Account
TDI(s): None.
and the amp/hr rating. Need ~80a/hr.
weasel is offline   Reply With Quote
Old October 5th, 2007, 14:15   #12
scooperhsd
Reserve capacity of 120 as well
Old October 5th, 2007, 15:28   #13
mrGutWrench
__. No More Calls, Please -- We Have a Winner!!! The size of the battery is one of the least important parts of this decision. The battery you pick for a TDI *must* be up to the job. Typical gasser batteries don't have the power to start a TDI in cold weather -- at least not for very long. The battery must be up to the job.
Old October 7th, 2007, 21:20   #14
Chrismak
Chrismak's Avatar
My 05 Pasatt is experiencing battery issues. After short vacation late august (maybe 4 days) without pasatt I got clicking and dead battery.
I jumped it, actually let it charge for few minutes off wifes car and it started fine. it ran fine since until this morning and the same symptom.
Could be time for new battery.
I haven't checked the brand but I assume it original factory.
Is this average life span for OEM battery? I guess 36 months. Registered as 05 but manufactured date I believe is 11/04 so could be on last amps.
Chris
A man with an experience is NEVER at the mercy of the man with an argument.
B5 2005 Pasatt GLS. Chainless @128K TDI-Tuning 2.0, 5 speed swap, DUK gearbox, valeo clutch and flywheel imported 1.9TDI. VAG com available, Skid plate.
Chrismak is offline   Reply With Quote
Old October 8th, 2007, 08:31   #15
weasel
TDI(s): None.
A lot of battery manufacturers will tell you tat after three years, you are on borrowed time ( regardless of warranty period ). Go buy a new one.
One other little point. Not every battery has the amp/hr rating on its label. As I understand, reserve time is a direct comparison. I don't know how much reserve time we need, but it would seem the more the merrier is a good place to start.
Page generated in 0.14750 seconds with 9 queries
[Output: 121.60 Kb. compressed to 100.41 Kb. by saving 21.20 Kb. (17.43%)]
