john-e-deer
Pela vs. MityVac?
Bang for the buck.. which one should I consider going with? ..& why?
..was this the little ball 6000 or the stand up cyclinder 650?scurvy said:I've seen the Pela in action and used one. It often takes 3 hands to use - one to pump, one to hold the pump onto the reservior and one to move the oil suction tube around..
The little ball Pela 6000. I have not used the stand-up cylinder 650, although it looks to be nearly the same as the Mityvac 7400 but with a smaller capacity. I got my Mityvac 7400 at a local Farm & Fleet (or was it Fleet Farm...) for about $45 on sale.john-e-deer said:..was this the little ball 6000 or the stand up cyclinder 650?
$FREE.99 is always the right priceLightflyer1 said:Mine was free so I deal with it.
..me tooJB05 said:..I hope you have better luck with yours..
..that's a good idea.visionlogic said:..it's best to disassemble it every so often and clean out the 'gook' to avoid any suction problems.
I give mine a shot of brake cleaner once in a while through the suction hole with the rubber stopper/evacuation tube removed. Seems to work just fine and no disassembly necessary.visionlogic said:...I've found that it's best to disassemble it every so often and clean out the 'gook' to avoid any suction problems.
Ditto!visionlogic said:I have a MOELLER 33330 from West Marine that's essentially the same as the MityVac unit. Does a good job. But I've found that it's best to disassemble it every so often and clean out the 'gook' to avoid any suction problems.
I have this one, works really well'Dante said:I know I'm resurecting a dead thread, but a more recent poll referred to this one.
I started out with the Pela 6000, and it died too soon, IMO. First the hose developed leaks (I emailed Pela about a new hose, but they couldn't be bothered to respond). Then the rubber deal the pump attaches to started to leak, too. Initial quality was fine, but within six or seven uses, it had problems. I just ordered a Mityvac 7201.
Once you get it primed,it takes about 3-4 minutes to get the oil outNocky said:Does the 12v one pull a good vacuum?
