Old September 19th, 2007, 11:33   #1
PD_Passat
PD_Passat's Avatar
Fuel Economy: 32/33 MPG mixed average
Default Monsoon Error Code
Have searched but cannot find any info on error codes for the Monsoon CD player. Have an "Error 2" and it ejects the cd. Even new cd's are ejected. Anyone have a source as to what the error codes mean. Any help is appreciated.
Thanks.
Ed
Altitude + Speed = Life!
PD_Passat is offline   Reply With Quote
Old September 19th, 2007, 21:20   #2
MOGolf
MOGolf's Avatar
If your car has under 50K miles on it, get it replaced under the bumper-to-bumper warranty.
MOGolf is offline   Reply With Quote
Old September 20th, 2007, 13:43   #3
PD_Passat
PD_Passat's Avatar
Thanks. Will be taking it in for the break light recall. May as well get it done then.
Ed
Old September 20th, 2007, 13:57   #4
treefidget
treefidget's Avatar
Fuel Economy: 40+ mpg b-99(+/-)
That's great IF the car is under warranty BUT if it's not, what might the reason for the code be?
Our 05 golf has also done this lately, sometimes error 1 or error 2, but later in the day it seems to work fine, it does not have multiple cds.
treefidget is offline   Reply With Quote
Old September 20th, 2007, 17:21   #5
MOGolf
MOGolf's Avatar
There's a service bulletin for CD*ERR 1.
"CD player displays CD * ERR 1. Mainly occurs when a newly purchased disc fails to play after initial loading into the player. Failure to play after loading may be caused by small bumps or flashing around the center hole and outside edge of disc. Do Not replace the CD player. Remove bumps or flashing by using a plastic instrument around these areas. Do Not enlarge the center hole.
* Fingerprints, dust or soil on the disc may cause skipping.
* Do Not use a circular motion to clean a disc, clean from center of disc to outer edge using a lint free soft cloth.
* Never attempt to play a cracked, warped, or damaged disc. This could severely damage the playback mechanism.
* Hard Frost: During cold weather, if the inside of the vehicle is suddenly warmed, a condition known as "Hard Frost" can occur (when condensation forms on the pick up lens inside the CD player).
Condensation can cause the laser beam to diffract and cause the CD player to generate an ERR code. During extreme cold temperatures, allow the CD player ample time to warm up prior to use."
Old September 21st, 2007, 09:06   #6
treefidget
treefidget's Avatar
Thanks Mo.
I think the cds giving us the problem were dirty.
Old October 4th, 2007, 10:53   #7
YBZ
YBZ's Avatar
TDI(s): 2002 Jetta
I've seen both those error codes now on my cd player. The cd's are clean and scratch free. They play fine for awhile then the skipping starts an progressively gets worse until the cd fails to play at all then it spits out the cd. First time it said error 1 then next time, a few weeks later, it said error 2.
Even running a cd lens cleaner didn't seem to solve anything.
Then again, after 276,000KM's, I'm expecting things to go on the fritz!
Some people never go crazy. What truly boring lives they must lead.
YBZ is offline   Reply With Quote
Old October 7th, 2007, 12:35   #8
treefidget
treefidget's Avatar
We found a way to kinda trick the cd player.
Put the cd in then before it gets a chance to scan the cd hit the FM button to turn on the radio, then hit the cd button, it works most of the time.
Old November 10th, 2007, 17:46   #9
moonlite
moonlite's Avatar
TDI(s): 2003 Golf
My 03 Golf with the Monsoon just started to display "ERROR 1" while trying to load the CD. After trying several different scratchless clean CD with no luck I looked here. Is there a way to reset the player? I'll try pulling the battery cable for 20 minutesnd see if that resets things.
Charlie
03 Golf MT, 270k Miles, she's getting tired
15 Golf DSG, SE w/ Lighting Package, 23k Miles
moonlite is offline   Reply With Quote
Old November 10th, 2007, 17:55   #10
lost1wing
lost1wing's Avatar
Fuel Economy: n/a
I used to get cd error on my 03 Jetta. This started when I installed a factory CD changer. After several repeated unplugging and pluggings, the error msg has never come back. The cd player in the car would not work either with the error msg.
lost1wing
2003 Jetta TDI X2 43mpg city
47mpg Highway
lost1wing is offline   Reply With Quote
Old November 11th, 2007, 16:33   #11
moonlite
moonlite's Avatar
TDI(s): 2003 Golf
After having the battery disconnected overnihjt, I still got the error 1.
I'm at a lose... maybe I can do something with my VAG-COM.
Charlie
Old November 11th, 2007, 18:46   #12
lost1wing
lost1wing's Avatar
Fuel Economy: n/a
I don't think my problem was a power reset issue, but more like a bad connection at the plug-in. It can't hurt to try.
lost1wing
47mpg Highway
Old November 12th, 2007, 21:42   #13
moonlite
moonlite's Avatar
TDI(s): 2003 Golf
Did you get it to work again?
I found this post at VWvortex
http://forums.vwvortex.com/zerothread?id=2645043
Now I'm thinking it is a CD stuck in the unit.
I'll I have to do is get some radio removal keys and start pulling it apart. Since it is already broken... it can't hurt.
Charlie
Old November 13th, 2007, 04:50   #14
lost1wing
lost1wing's Avatar
Fuel Economy: n/a
Mine has worked since I unplugged it serveral times. It's been working for two years with out the error msg.
lost1wing
47mpg Highway
Old November 13th, 2007, 17:48   #15
PD_Passat
PD_Passat's Avatar
Update: Went to the dealer yesterday with the recall for the break light. Had him look at the stereo and told him about the error 2 code. They ordered a new stereo for me. All covered under the warranty.
PS: The break light switch took less than 45 minutes - not bad services for around here.
Ed
Page generated in 0.18861 seconds with 9 queries
[Output: 121.74 Kb. compressed to 100.23 Kb. by saving 21.50 Kb. (17.67%)]
