Old September 16th, 2007, 16:01   #1
MandyMandyTastesLikeCandy
Default Block Heaters
Hello, first time poster/member here at TDIClub.
Can anyone please help with my decision making process about block heaters.
I own a 2002 Jetta TDI 1.9
Last year in Rhode Island we had several days/nights were the temp was below zero. My car would not start, I would have to crank it till the battery ran out, then charge/boost the battery. After 15 mins of cranking, the engine would fire up. It was recommended that I get a block heater for my car.
This is where I am asking for your help. Does anyone know of a good type type of heater to get. Im looking for something inexpensive, but functional.
I plan on using the heater only when I know its going to get cold. and lso that is fairly easy to install. I am however open to any and all suggestions.
What do y'all use for your VW's?
MandyMandyTastesLikeCandy is offline   Reply With Quote
Old September 16th, 2007, 16:03   #2
doc_m
doc_m's Avatar
TDI(s): None
curious is everything ok with your car? seems like it could be something else, mind you the coolant heaters are a fantastic thing to have in the cooler climates, still not a needed thing, just nice to have. www.frostheater.com has a full line.
Do work on cars like intake cleanings, nozzle swaps, brakes etc.... Hex usb + can now
2009 Jetta TDI Comfortline with ESP and beige leather interior. Evolution Imports Osiris Skidplate.
So far just over 10,200 kms on it
doc_m is offline   Reply With Quote
Old September 16th, 2007, 16:06   #3
david_594
david_594's Avatar
Fuel Economy: 51.7/48.2/40.7
The ones from frostheater are really the best and essentially the only option.
Your car defenitely has a problem though. It never got cold enough last year in RI that you car should have been that hard to start. Come to a GTG or bring your car up to Chris Hill's shop (mrchill) up in Braintree, MA and get to the bottom of the issues. Its probabily something simple like a few dead glowplug or a bad harness.
david_594 is offline   Reply With Quote
Old September 16th, 2007, 16:09   #4
Thanks, dually noted
Old September 16th, 2007, 16:15   #5
scooperhsd
For sure - your car has other problems than not having a block heater. These cars when running correctly should have no issues starting at -30, -40 F (assumes proper 5w40 or 0w30 oil, timing correct, and good glowplugs / harness. Also assumes proper starting technique - turn ignition switch on, WAIT until pigtail light goes off, turn key to starter position). I second taking your car to somone who knows what he's doing to get your car checked out / problems corrected.
Now the frost heaters ARE nice so you will have heat when you turn on the car immediately, but they shouldn't be a requirement for Rhode Island - after, your GAS car doesn't require them ?
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old September 16th, 2007, 16:27   #6
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
None needed and there's no place in the engine block to install one.
The NE area normally doesn't get cold enough to need a block heater of any kind. A TDI in proper running condition will cold start without a block heater at temps well below zero (F). TDIs are popular in Canada in places that get way colder than it does in the NE area....those of us in the "balmy" Boston area have nothing to worry about.
My 2002 Golf TDI is parked outside year round in NH. The coldest I've ever started it at was -17F without any problem.
From what you described about it not starting in the cold, you've got other problems that need to be taken care of before considering any type of heater. You might need a set of glowplugs or somthing else may be going on.
Has the Check Engine Light (CEL) been on? (The ECU should be scanned for stored code(s)).
What oil are you using? It's supposed to be a 5W-40 diesel-rated synthetic oil.
How long did you wait before cranking it after you turned the key to ON? Wait for the GP light to go out then wait a few more seconds.
Does it still have the original battery? It might be getting time for a new battery if it was cranking too slow to start in the cold.
How does it start when cold in warm weather? It should fire right up on the first or second compression stroke, i.e., "crank-crank-VROOM..." is all it should take. If it takes several seconds to fire up, then something is definitely wrong.
I suggest you find a local TDIclub guru in your area who can take a look at your car figure out what's going on. A TDI in proper running condition will actually start better in subzero temps than most gassers do. I've occasionally had a couple of co-workers try to needle me, poking fun at my TDI, thinking it's not going to start in the bitter cold because it's a diesel. They have all the typical anti-diesel prejudices. I end up having the last laugh though. LOL.
Find a TDIclub guru in your area who can help (there are several). Whatever you do, DON'T take it to a VW dealer. By far the number one problem with VWs in general is incompetent dealer service. Finding a local TDIclub guru is the way to go.
Good luck and Welcome to TDIclub.
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
Old September 16th, 2007, 18:47   #7
B.L.T
Fuel Economy: 1100km
Had a couple -40* days out here where the tdi started without being plugged in. Took a bit, but she fired. That was when the timing was so retarded it wasnt even on the chart too!. I cant wait to see how it starts this winter with everything as it should be!
2003 Golf TDI...PP764 Nozzles, Hella smoked tails,ECS smoked markers/repeaters, Euroswitch, Depo smoked e-codes, Ventectomy, Mufflerectomy
B.L.T is offline   Reply With Quote
Old September 16th, 2007, 20:21   #8
Birdman
Fuel Economy: 55 summer 50 winter
I have started my 01 in -0 % temps WITHOUT using the glow plugs to prove to a friend that these cars when tuned right will start in cold weather. Make sure the Battery is good have it and your charging system tested. Most places will do it free. Have someone with a Vag-com check your timing and make sure it is set above the middle line. Both of these things effect how the car starts along with good Oil.
Birdman is offline   Reply With Quote
Old September 16th, 2007, 20:59   #9
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
As above...the most important thing is a good running car prior to the cold weather, and THE most important thing is a good battery with the proper rating. I prefer the OEM one. I've done the last two winters with no block heater and zero issues... but I broke down and ordered a zerostart from frostheater.com for this winter. Can't wait to install and give it a try...weather permitting.
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old September 17th, 2007, 03:24   #10
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
There is no need at all for a block heater there, to start your car. It might be useful for getting heat sooner after you start, but if your TDI is not starting under those conditions, you have other problems.
I have had no problems starting VW diesels to 27F below.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old September 17th, 2007, 03:45   #11
JettaTDIMKV
JettaTDIMKV's Avatar
TDI(s): 2003 Golf
Fuel Economy: Too early to tell
I had a coolant heater installed simply because I want to have heat as soon as I get in the car. It is a 1000w heater/pump to heat and circulate the coolant to peak operating temp. I don't have heated seats so I really don't care to freeze my *** off, I had to pick one up.
I ran a heavy duty extention outside and used a heavy-duty exterior timer in the house to set it the night before if I know I need to go out.
I just put mine in, so I will see how it works as soon as it starts getting really cold out.
No TDI's for the moment, currently driving a 2008 Audi A4 Quattro 2.0T 6-speed auto
AKA: 07SalsaGLI on VWvortex
JettaTDIMKV is offline   Reply With Quote
Old September 17th, 2007, 06:42   #12
david_594
david_594's Avatar
What model is it? The zerostarts dont have a built in pump.
Old September 17th, 2007, 07:17   #13
Canadian_Grizzly
true but the coolant still circulates.
Byron
Driver Found!
Old September 17th, 2007, 08:49   #14
RT1
RT1's Avatar
Fuel Economy: 43.3 mpg/10 Year Average - 80% HiWay
Have yet to have a hard start in winter even at 0 degrees. You might want to winterize by changing out your fuel filter in the fall, fuel up only at busy truck stops and add PowerService diesel additive Diesel Kleen at each fill to keep the fuel from gelling. Stay away from mom and pop stops that sell a tankful every week or so. They're probably still selling summer fuel at Christmas. I don't think there's enough appreciation for the fact that diesel fuel starts to precipitate out wax under forty degrees. That can clog the filter in a hurry. It doesn't go back into solution once it's wax (without a heavy dose of solvents) so keeping the fuel from getting in that condition is the key. Biodiesel is even more succeptable. And yes, the fuel can get so thick it doesn't pump properly. Additives keep it from turning into jelly. Pep Boys in my area has started carrying PowerService products and they're available online too.
Cranking and cranking your starter is likely to bring premature death to the starter and battery. Keep the fuel good and it will start.
RT1 is offline   Reply With Quote
Old September 17th, 2007, 13:02   #15
Curious Chris
Fuel Economy: 47/42/38
Oh I have Terry's coolant heater installed in my car and I used it when I lived in MN. I had it on a timer and 3 hours before I would leave for work it turned on the heater. The car starts very merrily and I have cabin heat right away. Of course at -25 F I did have to drive right away as the engine would start to cool off. Nothing quite like having heat right away in the winter.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Page generated in 0.19702 seconds with 9 queries
[Output: 130.44 Kb. compressed to 108.87 Kb. by saving 21.57 Kb. (16.53%)]
