Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old September 10th, 2007, 15:20   #1
JimBo_KW
Default Where can I buy Deoxit D5
Hi Guys. Well my CEL is back on and I suspect its the glow plug harness the dealer advised me of the last time. Before replacing I would like to try cleaning it. I went looking in Mississauga today to a few stores listed in one of the links but they never heard of it. Any ideas where I can buy some close by? Thanks
JimBo_KW is offline   Reply With Quote
Old September 10th, 2007, 15:48   #2
Fourdiesel
Fuel Economy: ~53 mpg on Golf (sold)
I don't know which home improvement type stores are available to you in Ontario, but any store which sells 'do it yourself' electrical panels (for home use) etc should have an equivalent product. It is designed for use when installing/clamping aluminum wiring [think 'from the meter'] into the main circuit breakers. It is usually a grayish paste. It prevents oxidation of the aluminum conductors where they contact the circuit breakers. Prevents overheating and fires which can occur when high amperage loads are carried.
It is usually REQUIRED by the national electrical codes for house wiring where aluminum contacts another metal and must conduct current. If you can't find a store meeting these criteria - get in touch with an electrical contractor - he may give you a little bit. You only need a very small amount (a few grams).
2004 Touareg V10 TDI Colorado Red
Blk 2000 Golf 5spd 2-dr (now grandsons)
Sand Biege 2008 Mercedes GL320 CDI (wife's)
'83 Mitsubishi 4X4 PU(2.3L turbodiesel)
'85 U1700 UNIMOG ["I DO understand - its a UNIMOG thing"]
Fourdiesel is offline   Reply With Quote
Old September 10th, 2007, 19:21   #3
decan
Fuel Economy: less than 6L/100km avg
bought it at Crappy Tire.
cp
00 Jetta TDI,
5th brake light, evo skid plate, ccv filter, snow screen delete
94 Jetta td, 87 Jetta td, 83 Jetta td, 74 Westfalia camper
decan is offline   Reply With Quote
Old September 10th, 2007, 19:24   #4
JimBo_KW
Which one? or where abouts in the store? automotive? I have looked at the one I go to on a regular basis and didn't see it
2011 TDI Highline Grey with Black Leather, DSG & Nav.
Old September 10th, 2007, 19:31   #5
Jeff Heyerman
Default Here: (Oakville)
http://www.partsconnexion.com/catalo...lscleaner.html (see CAIG link at very bottom of page). I need some too, so will be calling tomorrow.
Cheers,
Jeff
Jeff Heyerman is offline   Reply With Quote
Old September 10th, 2007, 19:36   #6
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
Don't use a paste as it will dry out in the harness. It is an ANTI oxidising product, not a DEoxidising one. It won't do an already oxidised harness any good.
I also don't recommend using dielectric grease. For the same reason, it will not remove the oxidation causing the problem. In fact, it will seal it in which will make it even harder to clean it properly.
Deoxit D5 is available in Mississauga at Audio Operations at 600 Orwell Street (near Cawthra & The Queensway) Unit 29. It is also available online at www.rpelectronics.com
http://www.rpelectronics.com/English...tems/D5S-6.asp
Moving? Need boxes?
Go green and check out www.FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old September 11th, 2007, 02:26   #7
JimBo_KW
Thanks Everyone. I should be able to get it at one of the suggested locations.
Old September 11th, 2007, 04:58   #8
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
Nigel, might want to mention that rpelectronics is in BC.
-- John K
Wingnut's HOW TO's thread
"The commuting system is so badly broken that it will take decades just to bring it up to a level where it is merely malfunctioning." - Globe Drive
Toronto_Vento is offline   Reply With Quote
Old September 11th, 2007, 05:24   #9
LNXGUY
LNXGUY's Avatar
I am sure a local Sayal will have it...
Bill
'05 Jetta TDI Wagon
Custom tuned by Mike @ TDTuning.com
LNXGUY is offline   Reply With Quote
Old September 11th, 2007, 06:24   #10
Wingnut
Wingnut's Avatar
Ah hem...RP electronics is in BC
But I did say it was an online source, suggesting mail-order.
Moving? Need boxes?
Old September 11th, 2007, 07:52   #11
VDubbing
VDubbing's Avatar
great product. worth the 20 something dollars a can!!
2003 Jetta TDI Galactic Blue
235,000 K PP764 injectors, RC stage 3 VR6 clutch kit. Aluminum skid plate, GTI fogs .658 gear
VDubbing is offline   Reply With Quote
Old September 11th, 2007, 14:45   #12
JimBo_KW
Well its all done. As I don't have a vagcom (yet) will the CEL reset its self or I read that there is someting I can do with the ignition to trick it. Does it work?
Old September 11th, 2007, 18:03   #13
Wingnut
Wingnut's Avatar
Unfortunately, there is no trickery to get the light to go off by itself. You need a vag-com. I'm sure there are folks in your area that have them though.
Moving? Need boxes?
Old September 11th, 2007, 18:07   #14
ic_ou812
ScanguageII will also clear the code.
2002 Jetta TDI GLS Reflex Silver - Sprint 520's, EVO Skidplate, Scangauge II, NewSouth Indigo Boost Gauge, Dawes Device
1979 Rabbit Diesel L - went to the boneyard long ago
1971 Super Beetle - a fun summer car, sold to some high school kid
ic_ou812 is offline   Reply With Quote
Old September 12th, 2007, 08:52   #15
Toronto_Vento
I've looked in the past, and no. I got a contact cleaner from them in the past, but it is no substitue for Deoxit. I gotta pick up a can for myself soon.
-- John K
Page generated in 0.19846 seconds with 9 queries
[Output: 123.32 Kb. compressed to 102.00 Kb. by saving 21.32 Kb. (17.29%)]
