Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2007
TDIFest 2007 Discussion about TDIFest 2007 that happened in Montréal, Canada.
Old September 7th, 2007, 13:17   #31
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Actually the pressure plate failed. One of the flat srings somehow sheared(?) and machined a nice hole through the case of my hard won DRW. Now I can inspect the diff without takng the transmission apart. I dont even need a light. Very odd as it made no sound or any indication that the evil aluminum machining gnomes were at work. At any rate. I have to decide if I am going to weld it shut, (lots of welding) buy a new bell housing (ouch!) or perhaps a used one. Or.......perhaps find an american 6 speed and swap internals (what a drag!). This however would be a good time for an LSD. If I could afford it. Oy!
The supplier who sold me the clutch just sent me another one. With any luck, this one is good. BUt my transmission......what to do what to do.......
By the way, thanks guys for towing me back. That would have been REALLY pricey and would have taken much longer had you not helped me out. Driving from Mtl to Ottawa and back, only t drive south of Boston was wayyyyyyy out of your way. MUCH appreciated.
I'm glad the car stopped running. Otherwise there would be no hope of saving the trans at all. By the by, what happened was I was driving around aimlessly and decided to go back to the hotel about 2:00 a.m. monday. I stopped at a fuel station to pick up a drink my wife asked for and came out. The car went "clunk" when starting. It drove in fine. No noise, no drama. I got it to turn over a couple of time after I removed the injectors(more on that later). I then put it together and 'clunk"! ?????? That was around 3:30 a.m.. I then called Lai who called Tom who came with tools. (how did I get the injectors out without tools? MUahahahahahahah!)
I then took off the cam cover to inspect what I thought may be carnage. Nope. Just fine. fortunately the engine was near tdc. I line up the marks and all was well. Hmmmmmmm. Then I turned the engine by hand again (it only goes 90 degrees). I heard scraping in the bell housing. I decided that I could not fix it propery in Mtl and still get back before tuesday, so I elected to tow it home. Fortunately, a couple of extremely kind club members lent me aid in that respect.
Now, why did I remove the injectors? For three weeks, it has been intermittently starting as if it were running on pooled diesel or engine oil. It would start and run rough and uncontrolled for several seconds and smooth out. Once a day or 5 times a day. Never know. I didnt have time to deal with it as I was under the gun already so I ignored it till later. Later came when I went to my Bosch shop for some parts and the car was smokey (whitish) at idle and puffed heavy on takeoff but was fine driving. It never did this before and as I almost never drive in daylight for long (no vampire jokes), I wouldnt have noticed anyway. I reasoned that the injectors could be streaming.
I ran some diesel purge through it and by the end of the can, the car smoked very little. I drove it and it was much better. In fact, I got black smoke now. I suspect it was lean for a long time. This is why I removed the injectors. The weird startup came back in Mtl. 3 times (different). The last time was when I started at the fuel station. It did the weird startup ( way longer than it ever did (2 minutes))and I decided this time to press the accelerator to clear it. It stalled and would not restart. I thought it was fuel lock.
After the original fuel system clean, I then installed the 6 speed. Except for a few parts snafus, it went ok.....till that fateful monday morning........
Stay tooned.........
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old September 7th, 2007, 14:09   #32
mr.mindless
mr.mindless's Avatar
Fuel Economy: 44mpg
amazing that it could be wearing away like that with little enough noise to go unnoticed.
Personally if everything is still in alignment (not having yet had my transmission off I'm not sure where this hole would have been worn and if there are any bearings or seals that would have been disconnected from the main housing) I'd patch it up and run it if there is clearance to do so, and you have a TiG or at least an aluminum welding hookup.
Thanks for the details, and good luck in the repairs.
by the way....
nonono, *how* you removed the injectors "without tools" is the question... you use wingnuts on the holdowns or what?
Michael Maskalans - '07 Ram 3500 CTD, '98 Jetta TDI, '94 Mitsubishi Mighty Mits
Gone but not forgotten: '97 Ram 3500 CTD P-pumped '01 24v, Eaton 13sp, 19.5s, '87 AMC Eagle
SOLD: '02 Galactic Blue Jetta TDI 5sp Class III hitch, 205/75r15 Grabber AT2s & 225/60r16 Blizzaks and much much more
mr.mindless is offline   Reply With Quote
Old September 7th, 2007, 15:46   #33
Justler
You should be able to get an 02m case cheap. I'm somehow doubt your case is in any shape to be aluminum welded... it sounds pretty torn apart. You've got the important parts of the DRW (R&P+Gears), just get a new case =)
At least you got home ok! Having to stay with the car in mtl to get it fixed, or leaving the car in mtl could have been even more expensive!
Justler is offline   Reply With Quote
Old September 7th, 2007, 17:58   #34
mrchill
mrchill's Avatar
Default Ouch!
Here they are:
Old September 7th, 2007, 18:08   #35
mr.mindless
Fuel Economy: 44mpg
with links:
if the case did not get too thin where it wore aside from where it holed, I'd weld that up and call it a day. Maybe add some material back in where the gussets were damaged if it was bad. Tough to see that evel of detail from the pics.
Last edited by mr.mindless; September 7th, 2007 at 18:15. Reason: I did everything out of order the first time....
Old September 7th, 2007, 20:53   #36
mrchill
mrchill's Avatar
Planning on a trip to Dentsport for welding. I still havent replaced my tig.
Old September 8th, 2007, 17:18   #37
Alex will fix you up. Too bad about this, and just when I was finally thinking about a six speed.
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old September 8th, 2007, 17:29   #38
mr.mindless
Fuel Economy: 44mpg
Aw, c'mon Peter... I'm already jealous of your wagon, you can't go throwing a 6 speed in there yet! :-)
Old September 8th, 2007, 17:50   #39
Actually I was thinking of the A5. I want to make it a GLI/TDI. I'm picking up the wheels tomorrow. Valences next. A 6 speed would be the icing on the cake.
Old September 8th, 2007, 17:52   #40
mr.mindless
Fuel Economy: 44mpg
ooh, nice....
Old September 8th, 2007, 17:56   #41
BrianCT
TDI(s): TDI
Durafix aluminum welding with a propane torch. The case is not critical to either sustaining heat or needed strength with that size hole. Couple hours and you're back on the road.
Sorry about the bad luck. WHen you had it in sixth, did you hear less engine noise and more wind around the windows with a lower rpm? Nothing like 1,780 rpms at 70 mph. Quiet. Smooth. Way it should be.
BrianCT
BrianCT is offline   Reply With Quote
Old September 8th, 2007, 18:08   #42
Aren't they already in Europe? Talk to me about your six-speed tomorrow. I may be interested.
Old September 8th, 2007, 18:29   #43
mr.mindless
Fuel Economy: 44mpg
if it was for race day I'd definitely stay with the 5sp and save the 70+ pounds... I don't think the A5 is a race car though (?)
Old September 8th, 2007, 18:39   #44
VWTDIBeetle
BANNED, Frank M alias
TDI(s): Beetle
Originally Posted by BrianCT
Durafix aluminum welding with a propane torch. The case is not critical to either sustaining heat or needed strength with that size hole. Couple hours and you're back on the road.BrianCT
I agree, that stuff works great.
He will have to take the trans apart to get any metal debris out.
VWTDIBeetle is offline   Reply With Quote
Old September 10th, 2007, 20:12   #45
ittrad
Yowch! Well, looks like you made the right decision to tow it back... that wouldn't have been something that could have been fixed in a day.
Passed along the thanks to my cousin (who owns the Vista Cruiser) as well. It was truly our pleasure.... any excuse for a road trip!
Jamie
ittrad is offline   Reply With Quote
Page generated in 0.16977 seconds with 9 queries
[Output: 133.66 Kb. compressed to 111.78 Kb. by saving 21.88 Kb. (16.37%)]
