Old August 30th, 2007, 05:56   #1
troutguy
troutguy's Avatar
Default Help Replacing struts and shocks
I was wondering if anyone knows of a post which explains the procedure for replacing the shocks and struts on a 99.5 Jetta.
I have looked in the "How To" thread and there does not seem to be anything there which would cover what I need. I am going to put in some Bilstein TC's and would love to make sure that I am doing it correctly.
thanks, Pete
'00 GLS, Dark Green, Cleaned Intake and EGR and RC2
161,000 miles and counting
'75 Mercedes 300D, 180,000 miles and very happy
troutguy is offline   Reply With Quote
Old August 30th, 2007, 07:14   #2
Honeydew
This link from the vortex helped me. These guys used their impact wrench more than is really neccessary, they must have just got it.
http://fortuneman.tripod.com/suspension/install.htm
Napa "rented" me a spring compressor for no cost, just deposit.
Honeydew is offline   Reply With Quote
Old August 30th, 2007, 12:18   #3
weasel
Deactivated Member Account
TDI(s): None.
I used this link ( found in the how-to ). It documents installing coilovers, but that doesn't matter. Everything was dead on. http://www.noahlh.com/car/coilover_howto/
weasel is offline   Reply With Quote
Old August 30th, 2007, 12:40   #4
cattlerepairman
cattlerepairman's Avatar
Fuel Economy: 8.4 l/100 km at 60/40 hwy/city
All good advice; I'd add, get the spreader bit for where the lower end of the front struts is clamped. A large screwdriver works, but the spreader bit is sweet.
Also, I never mess with lowering the sub frame or removing axles. I use a good set of spring clamps and that works like a charm, especially on the passenger side.
Once you have the front end up in the air on jack stands and the wheels removed, use the jack to lift the lower control arm up a bit, THEN but the spring clamps onto the now slightly compressed springs. That is all you need. Remove the bolt and use the spreader bit, lower the jack and the strut will slide out and clear the control arm easily.
Here is the thread from when I did mine: http://forums.tdiclub.com/showthread...ht=bilstein+HD
2012 Touareg TDI Lux, Campanella white
1974 AM General M35A2C w/w (for the 6x6 moments in life)
1999 New Beetle TDI, 1999, dark blue ("Batik Blue"), 5spd (SOLD)
cattlerepairman is offline   Reply With Quote
Old August 30th, 2007, 16:10   #5
troutguy
troutguy's Avatar
Default Thank You
You guys are great. I have the tools (spreader tool, spring clamps, and the proper wrench from Metalnerd) that are needed for the job and I have the Bentley Manual and if you believe it the Haynes Manual (Herm mentioned at the HO5G get together a few weeks ago that the Haynes Manual is better for doing this procedure).
But the information that you all provided is just what I needed.
Thanks a lot.
Pete
edited to include tool list
Old August 30th, 2007, 19:50   #6
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
Pete:
Gimmie a call if you need a hand over the phone... I just did that job on the Jetta a year ago... PM sent.
-Rich
574,500 miles now and counting...25,500 until cluster swap!
'00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Old September 2nd, 2007, 13:24   #7
weasel
TDI(s): None.
Still fresh in my mind too. Did it about 2 months ago. Be patient with the passenger side. You do not have to drop the sub-frame or remove the axle. It may not seem like it at install time, but it will go, trust me.
Page generated in 0.14450 seconds with 9 queries
[Output: 75.63 Kb. compressed to 64.79 Kb. by saving 10.84 Kb. (14.33%)]
