Old August 28th, 2007, 16:13   #1
dfusconi
TDI(s): jetta
Cool Hissing Sound
i AM EXPEIRENCING A HISSING NOISE AFTER APPLIYING FULLTHROTTLE AFTER 3 SECONDS ESPECIALY UP HILLS UNDER LOAD. SOUNDS LIKE AIR BEING LET OUT OF A TIRE.
2003 JETTA TDI 1.9 TURBO.
dfusconi is offline   Reply With Quote
Old August 28th, 2007, 16:30   #2
Wook660
Wook660's Avatar
Fuel Economy: 48 mpg
Normal turbo noise?
2002 Jetta TDI AT Sold.
2001 Jetta TDI MT going the distance! - 350K...
1988 Samurai, soon to be diesel?
Mahindra 4530 Diesel!
Wook660 is offline   Reply With Quote
Old August 28th, 2007, 16:36   #3
KS97Passat
Fuel Economy: 57 mpg max. (at 60-65mph)
I guess that the turbochargers can be heard, but I've never heard mine. Start by inspecting your air path from the turbocharger to the intake manifold for splits. A leaky place would probably be oily too.
'97 B4: 195k mi., .658 5th, 57/63 mpg "best tank" before/after trans. mod. (hwy, 60-65 mph), new stock nozzles @ 148k, Upsolute, "mufflerectomy", add'l exh. flex-pipe, B'stone B381 low-rolling-res. tires, Cat filter, ScanGaugeII
KS97Passat is offline   Reply With Quote
Old August 28th, 2007, 16:38   #4
Nico3d3
Nico3d3's Avatar
TDI(s): Golf 2001
Are you a new owner of a TDI? Cause, as Wook660 said what you described seem to be the normal noise of the turbo. When you give load to the engine, the turbo adjust itself to give more boost pressure and that's why you hear the hissing noise of air being compressed and blowned into the intake.
2001 Golf TDI ALH, .205 injectors, custom chip: maf & egr delete, G60/ Sachs VR6 clutch, frostheater, 1.8T brakes
Nico3d3 is offline   Reply With Quote
Old August 28th, 2007, 16:47   #5
Fourdiesel
Fuel Economy: ~53 mpg on Golf (sold)
Check carefully for any place air can leak out 'downstream' of the turbo compressor. If band clamps were ever not properly installed, air can leak there or through any cracks in the plastic "plumbing". The fact that your car continues to run with power (it does, doesn't it?) and not go into 'limp home' mode indicates a leak and not a popped off hose.
2004 Touareg V10 TDI Colorado Red
Blk 2000 Golf 5spd 2-dr (now grandsons)
Sand Biege 2008 Mercedes GL320 CDI (wife's)
'83 Mitsubishi 4X4 PU(2.3L turbodiesel)
'85 U1700 UNIMOG ["I DO understand - its a UNIMOG thing"]
Fourdiesel is offline   Reply With Quote
Old August 28th, 2007, 16:52   #6
larithmos
TDI(s): 2002 Golf
Bump.
larithmos is offline   Reply With Quote
Old August 28th, 2007, 16:52   #7
Gilty_one
Gilty_one's Avatar
Normally I cannot hear the turbo whine until my window is open and I'm passing an object that will reflect the sound into the car... but I always smile when I hear it.
~~I'd get better mileage if I would just drive slower...
Gilty_one is offline   Reply With Quote
Old August 28th, 2007, 16:59   #8
KS97Passat
Thumbs up
Yeah! I haven't had the satisfaction of that, but maybe I haven't had the right conditions with the window down. I can hear my Dodge's (Cummins) easily, but the TDI is pretty quiet.
Back to the topic at hand. What is the history of this car? Is this noise something new?
Old August 28th, 2007, 17:03   #9
chrisfiat
TDI(s): 97 jetta
Fuel Economy: 48
pluged cat??
third diesel, 97 tdi jetta 210000 50mpg avg
vag-com, ase master
i am the diesel tech at duponts service center
1976 Fiat 124(you know the top goes down)
chrisfiat is offline   Reply With Quote
Old August 28th, 2007, 17:09   #10
KS97Passat
Well, we're having a conversation here, but not with the owner of the patient! Maybe he'll check in soon.
Old August 28th, 2007, 18:18   #11
dfusconi
TDI(s): jetta
Default Hissing Sound
This is the fifth year owning my 2003 TDI. After having my timing belt replaced....I have noticed the HISSING sound
Old August 28th, 2007, 18:32   #12
Wook660
Wook660's Avatar
Ahh, the plot thickens. So the belt was just replaced, some of the plumbing has been removed and reinstalled. As stated in the above replies, check the entire air flow for loose ends.
Old August 28th, 2007, 18:32   #13
dfusconi
TDI(s): jetta
94000 mls. 2003 jetta tdi
Old August 28th, 2007, 18:35   #14
KS97Passat
I don't think that a properly done timing belt job could explain the noise, but maybe something wasn't put back correctly or was damaged in the process and now you have a leak.
Old August 28th, 2007, 18:45   #15
paramedick
paramedick's Avatar
Clamp at intercooler or turbo not correct. Check for oily residue in the area.
Page generated in 0.15014 seconds with 9 queries
[Output: 120.27 Kb. compressed to 98.77 Kb. by saving 21.50 Kb. (17.88%)]
