validius
Lacking in ZDDP
Attn TDI newbs. Even if a K&N DIDNT destroy your MAF here is why they are worthles.
The ECU takes 2 readings regarding airflow. The first is Mass air flow. It is based on this that the ECU can calculate how much fuel it can give to the motor and not smoke. The second reading is boost. The ECU measures and controls boost so a specific level of mass airflow can be obtained.
When one claims that a K&N helps to develop more power it can only mean one thing. some property of the K&N must cause more airflow and because of it more fuel is being injected.
Wait now and once again picture the intake system of a TDI. To pack more air in means you must be running more boost! If the turbo can maintain the specified level of boost it doesnt matter how much or how little restriction there is before the turbo.
So lets say that the K&N flows better and the turbo develops more boost. The ECU will see that and use the VNT to reduce the boost and put the airflow right back to where you were with the paper filter.
Cliffs: Unless you are unable to maintain the desired boost level with your current intake system a higher flow airfilter WILL NOT HELP YOU.
On a side note: There are only 2 ways to make a filter flow better, increase the amount of paper (or other filtering substance) or increase the diameter of the holes in the paper. Next time you replace your air filter compare the filters at autozone and find the one with the most paper. It will most likely flow the best while maintaining a proper level of filtration.
