Old August 22nd, 2007, 13:33   #1
jayfrigginjones
jayfrigginjones's Avatar
Fuel Economy: 46 within the mountains of CO and 46 in the wind of New Mexico....don't know about flat sea-level windblocked areas.
Default what are "hubcentric" wheel spacers?
for pete's sake. $80 for a set of 10mm hubcentric wheel spacers; what's the difference between these and the ones you can get from PepBoys for $20?
2000 NB
Q-loaded
PP764's
No exhaust
Bring it on
jayfrigginjones is offline   Reply With Quote
Old August 22nd, 2007, 13:47   #2
DPM
Fuel Economy: 38.5- 47 Forester, 49-55 Peugeot
The hubcentric spigot and recess that have to be machined for the particular hole sze?
DPM is offline   Reply With Quote
Old August 22nd, 2007, 14:18   #3
VwPodRacer
VwPodRacer's Avatar
hubcentric wheel spacers are proper spacers that were machined for your hub on your car.... which you rim normally is seated on.... when you upgrade to different rims that are not OEM you normally have to by hubcentris rings to go into the wheels hubs to center the wheels on the cars hubs.... so hubcentric wheel spacers are machined to be centered correctly on the vehicles hubs... if you dont buy proper hubcentric rings or dont use centric rings when you upgrade your wheels or put spacers in you normally while throw out wheel bearings and ball joints alot faster due to the play that is now aloud in the wheels due to not being properly seated on the hubs
Evil Things To Come! .:RTDI
VwPodRacer is offline   Reply With Quote
Old August 22nd, 2007, 14:41   #4
jayfrigginjones
Seems like the wheel studs would align everything correctly...
2000 NB
Q-loaded
PP764's
No exhaust
Bring it on
Old August 22nd, 2007, 15:07   #5
VwPodRacer
VwPodRacer's Avatar
vw doesnt use wheel studs they use bolts.... and even when the bolts are in there and seated on the seats for the bolts in the rim the wheels still move up and down a bit... even if you dont see it... it is still there and that is what the centric rings stop
Old August 22nd, 2007, 15:23   #6
jayfrigginjones
Makes since. At $80/pair, maybe i should get into the wheel spacer business!
2000 NB
Q-loaded
PP764's
No exhaust
Bring it on
Old August 22nd, 2007, 16:56   #7
thermopylaetech
thermopylaetech's Avatar
Wow thats a pounding. The set I got from the tire rack for the BMW's snow rims were all of 15 for the set. Granted they were precession plastic and not machine billet but I only needed to take up a few mm.
Who is it thats trying to take you out for a walk on this one?
Francis Taracido
Owner/President
Thermopylae Technologies Incorporated
28 Main Street
Accord NY 12404
845.626.2898
Unlimited Thinking
Unlimited Thoughts
Custom CAD-E & Fabrication Solutions for Road & Race
Unimog Sales & Equipment
Road & Race Lighting Equipment
OBDII ECU/PCM Programing
thermopylaetech is offline   Reply With Quote
Old August 22nd, 2007, 18:21   #8
codeblue
codeblue's Avatar
I think you are getting confused with "Spacers" and "Hubcentric rings"
Spacers are for spacing your wheels out for a flush look in the wheel well. They are usually CNC machined and thats why they cost more. Think of it as another way of lowering offset. $80 is not a bad price for that.
Hubcentric rings don't space out your wheels. They are just for centering the wheel on the hub for your wheel bolts. And those are the ones that are $20 at pepboys. They are just plastic rings.
codeblue is offline   Reply With Quote
Old August 23rd, 2007, 11:42   #9
jayfrigginjones
This is from the H&Rsprings website:
TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. Hub centric for the highest level of accuracy, TRAK+ wheel spacers are 100% made in Germany under ISO 9001 Quality Assurance standards, and meet the rigid safety criteria of the German TÜV.
and here is the 10mm hubcentric spacers (2). Edit: The spacer in the photo looks thicker than 1cm....
2000 NB
Q-loaded
PP764's
No exhaust
Bring it on
Old August 23rd, 2007, 16:26   #10
thermopylaetech
Yeah the spacers should be hubcentric as well but there is a big difference between what we're talking about. A hub spacer or "giant shim" is designed to carry all the torsional and axial loads that the hub normaly would but becasue it is located further way from the intended moment of inertia, the forces are much higher and as such the spacer often times must be able to handle these better than the stock hub. Making them from aluminum or some various alloy is so they have low rotational mass.
Personaly I don't like them becasue far too many of them are pure crap and can lead to bad trouble but a select few are highly well made. The TUV cert is an important thing.
Francis Taracido
Owner/President
28 Main Street
Accord NY 12404
845.626.2898
Unlimited Thinking
Unlimited Thoughts
Page generated in 0.12549 seconds with 9 queries
[Output: 95.08 Kb. compressed to 80.04 Kb. by saving 15.04 Kb. (15.82%)]
