Old August 20th, 2007, 12:49   #1
k45's Avatar
TDI(s): 02 Jetta
Fuel Economy: 39
Default Automatic shifter question
My 02 jetta has been acting up lately when starting it up and puting it into gear. I put my foot on the brake and press the button but it will not release and i can see the indicator lights still on as iff I have not press the brake. I was told this is a switch in my center console going out. Has anyone messed with this before. thanks
k45 is offline   Reply With Quote
Old August 20th, 2007, 14:24   #2
BeeselDietle's Avatar
TDI(s): 01 beetle
Fuel Economy: 42mpg
Nope it is your brake switch on the brake pedal. There is a recall on the switch. Your brake lights are also not working when this happens, get it replaced. If you don't want to go to the dealer, you can buy one on tdi parts for about ten bucks I think.
Vag-com-USB+HEX+CAN, Metalnerd t.b. tools,scanguage II
'98 beetle 5sp
'00 beetle auto (soon 2b 5sp)
'04 Jetta PD 5sp (hers)
'05 Jetta PD DSG (mine)
'98 Dodge Cummins 3/4 ton
The only substitute for good manners is fast reflexes.
BeeselDietle is offline   Reply With Quote
Page generated in 0.11422 seconds with 9 queries
[Output: 47.86 Kb. compressed to 43.84 Kb. by saving 4.02 Kb. (8.40%)]
