I assume the GT30 you are referencing is the GT30R ball bearing waste-gated turbo. Though ball bearing turbos spool faster, it still wouldn't spool as quickly as a Variable vane turbo.
Some have made comments that polished intake/exhaust ports would be more likely to collect soot, but may result in better performance. However, as a result, you'll have to clean your head.
My recipe:
4340 rods (swaintech coatings) (Carillo, Pauter, Kerma, Red Rotors, Eagle, Crower)
Forged pistons (swaintech coatings) (JE, Wiseco, Arias)
Knife edged and coated crank + windage tray (maybe crank scraper... undecided on this)
Main Bearing Girdle (Eurospec Sport)
A turbo larger than VNT22 (Kermatdi could probably get you what you need).
ARP studs
Larger injectors than R520s (These are not available yet for VE but I know KERMA is working on something).
12mm pumps don't like to rev high, but if you can shift before 4200rpm you could use it. Failure rate seemed high for high rpm use. Could be a result of people using chinese 12mm pump heads.
You can keep the 5-speed and just regear it, cryo treat the internals and add a differential. (NathanMSL did some cool things to his ERF 6-speed)
Front mount intercooler (I would custom make this, it'd be cheaper if you can weld)
Lift pump (in tank or external)
For the amount of power you'll put down, i'd recommend a Stage 3 or 3+ clutch from Spec clutches and some 100mm+ axles. You can get custom made axles from raxles if you really want to.
Of course, custom tuning. At that amount of power and spending money, I would either book Jeff from RC for a couple days to make sure that he gets an awesome tune, or get someone from europe to come over and tune the car on a dyno (Airfare, hotel/place to stay, travel to/from and their hourly rate). Either way, DYNO tune it... Accept nothing less.
This is the basic plan I had when I started building my car, including having aligator come to the U.S. or some other euro tuner to dyno tune my car.
Everything I listed as far as parts are available to purchase today, you would just have to make contact with the companies and spec them the parts that you want. Pauter, Carillo, Eagle and Crower can all make you forged rods... I called them all. Arias can custom make pistons as I talked with them. Get with StingrayRT, he's got custom bowls that have been tested and proven to be more efficient.
300hp reliable will cost you $20k+. I priced it all including machine shop fees, misc supplies, bolts, nuts etc. you'll also need gauges but i'm pretty sure that doesn't even need to be mentioned at this point.
