Old August 4th, 2007, 22:13   #1
Dumanehu
Dumanehu's Avatar
Fuel Economy: max 51/ 35avg
Question power windows, sunroof, door locks do not work
The power windows, sunroof, door locks do not work. Unable to open windows via switches or key in the door handle. The remote does not work to lock or unlock the doors. If you use the key in the door handle, it locks all 4 doors but immediately unlocks them. Unable to lock or unlock trunk. The trunk release switch in the door panel does not work. The fuel tank door does open via the door panel switch. This happened after unlocking the car with the key fob. All fuses are good. Any suggestions?
Happened once before, but a blown fuse fixed that. no such luck this time. all fuses are good.
2002 Jetta TDi
2008 Gli
Alex P
Dumanehu is offline   Reply With Quote
Old August 10th, 2007, 00:05   #2
ken.fresno-tdi
Default all fuses checked?
By 'all fuses are good' are you aware of the two additional 15A fuses *above* the relays tucked way up under the dash on the driver's side, to the left of the steering column.
http://pics.tdiclub.com/showphoto.ph...=37139&cat=516
These two control the central locking and the anti-theft alarm. To get to them you have to take off the plastic pieces above the driver's feet, and then take out the fuel pump relay (in relay postion #4-6 - remember which way you removed it so you can put it back more easily). The fuses themselves are covered with a soft plastic cover, which can be pried off to reveal the actual fuse.
If you don't have luck there, then I'd check out the 'comfort system central control module' tucked up on the dash near the relays, to the left of the steering column. I'm sure V.W. would like more than a few pennies to replace that. If you have access to a VAG-COM you could check out if it has thrown some codes for the comfort system. These would not necessarily make the check engine light go on. I doubt resetting the codes would make the locks work again, but I've seen stranger things happen.
Finally, I'd check the driver's side 'comfort system' control module, which is integrated into the power window motor (why!!?). I had a somewhat similar problem on a 01 Jetta I was working on. Right side window and lock did not work from driver's side switches; all the windows would jerk going up and down, passenger lock would not stay locked. Turned out on mine to the be the passenger side 'comfort system' electronics integrated into the power window motor. Bizarre, but oh too typical for VW electronics. Because the driver's side controls all the windows and doors it could be the culprit. But since your sunroof also doesn't work I would suspect the 'central comfort system control module.'
Good luck!
ken.fresno-tdi is offline   Reply With Quote
Page generated in 0.13037 seconds with 9 queries
[Output: 50.51 Kb. compressed to 46.37 Kb. by saving 4.14 Kb. (8.21%)]
