Old August 3rd, 2007, 07:56   #1
s20130
Default how do I reset "defective bulb" warning light?
Hi,
My tail light was replaced due to an "incident" with a pole. The Defective bulb light is still on. Do I need a vag com to reset it?
Hall County, GA
2010 Jetta TDI DSG "Rudolph"
2006 Jetta TDI DSG pkg #1 "Lebchien" RIP1/25/12
1973 Toyota Land Cruiser FJ40 (gasser) "Nayla"
s20130 is offline   Reply With Quote
Old August 3rd, 2007, 17:27   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
I don't think there is need to reset it, I think you still have a light problem and don't realize it. (yet)
Check all your lights and see which one is the culprit.
Good luck!
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old August 4th, 2007, 14:42   #3
2004STARWARSTDI
2004STARWARSTDI's Avatar
Post bulb warning light
No you don't need VagCom to reset it> It will go out once you correct the problem. Suggestionh-the brake light contains 2 bulbs. Check there-happened on friend of mine -hooked up VAGCOM -said defective brake light!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old August 5th, 2007, 12:53   #4
HatefulMechanic
HatefulMechanic's Avatar
make certain you have the right bulb in it, and also make certain that the wiring isnt damaged. it will look for a voltage drop change in the circuit, so either will cause the lamp out indicator to come on.
HatefulMechanic is offline   Reply With Quote
Old March 9th, 2015, 10:55   #5
Joe_Diesel
Fuel Economy: 38/43
So just ran across this thread... I have a 2010 Jetta and replaced the license plate bulbs with LED's. Since it's looking for a voltage change... the LEDs don't provide quite enough and it throws the error.
Joe_Diesel is offline   Reply With Quote
Page generated in 0.12955 seconds with 9 queries
[Output: 64.62 Kb. compressed to 56.77 Kb. by saving 7.86 Kb. (12.16%)]
