Stealth TDI
Pre-Forum Veteran Member
Hi,
I installed a new USB radio today and figured I'd shoot some photos and write a "how-to" while I was at it. First, a preface: There's no need to remove the AC controls if you're just swapping out stock radios. However, doing so makes the job a bit easier when you're dealing with aftermarket radios with wiring adapters.
Okay, the photos:
First, use a tiny screwdriver to pry open the cover for the AC controls...
Once you can get a finger in there, use the screwdriver to pry up the other side and it will pop off...
This will expose four screws. Remove the ashtray to see the other two. Remove the screws...
Gently pull the AC button panel...
To move the fan/heat control knob panel, press the whole assembly inward/forward, then rotate the rear upward, then slide it all down and out of the way...
Using the applicable removal keys, slide your radio out toward you...
If you encounter resistance, you may need to reach under the radio to help fish the cables through to remove some tension...
Here's everything removed. If you're removing a stock radio and installing an aftermarket radio, you'll likely need to cut out a plastic crossmember that will interfere with installing a larger aftermarket radio. I don't have a photo of this; but you'll know it when you see it. A hacksaw blade works great on this...
Use an appropriate wiring adapter to connect your new radio to the factory harness. I got my first aftermarket radio from Crutchfield... everything was included...
Once your wiring is done, connect the plugs and slide the radio to this position and test it. Once you're happy, slide it the rest of the way in. This is another point at which you may need to reach under the radio to help feed the wiring through so the radio will go in without binding up the wires...
Finishing up in the next post...
Okay, the photos:
