Old July 19th, 2007, 11:36   #1
mopractice
Default Smellin anti freeze
I have been lurking for months and finally found a Passat wagon that I purchased a few day ago. I have read posts about heater cores having to be replaced.
I smell coolant after getting out of the car, not in the car and not when I turn the heater on. Only when I leave the car running and I walk behind the vehicle. Another thing that may or may not be related: I swear that I sometimes hear water running behind the glovebox.
Any suggestions? I have an extended warranty, I haven't checked to see if that will cover changing the heater core.
Mike in Minnesota
mopractice is offline   Reply With Quote
Old July 19th, 2007, 13:34   #2
tomo366
TDI Lifer, Member #131
tomo366's Avatar
Early on there were quite a few of these with bad heater cores
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2015 Jeep Grand Cherokee Overland EcoDiesel
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old July 20th, 2007, 05:16   #3
TDI_Jeffster
Fuel Economy: avg 38-40
Yeah, I had the same noises and smells until one day I started noticing fluid in my passenger floor area. Leaking Heater core that was leaking inside my cabin. You can also check the fluid level of your anti-freeze, after I refilled mine is when the real bad leaks started. What finally did it for me though was that it would fog up the interior of my windshield so bad I couldn't drive - and the defogger wouldn't do anything to remove it.
Hopefully it will be covered by your extended warrantee as the dealer wants an arm and a leg to replace it. I ended up having a buddy replace mine for a couple of ice cold 6 packs.
2004 Passat TDI w/ RC stage 2 & boostvalve
TDI_Jeffster is offline   Reply With Quote
Old July 25th, 2007, 08:28   #4
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
You have a great friend. Treat him well! That is one huge job.
2015 Golf SE TDI with DSG, 88k.
and formerly a 2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old July 25th, 2007, 10:00   #5
TDI_Jeffster
Well, my radio and a/c haven't worked the same since - but the heater core is fixed. So, yes he is a friend, but I got what I payed for too. LOL
I think the radio is a busted antenae clip 'cause sometimes I get reception and sometimes I don't. The a/c had to be discharged to remove some lines and I don't think he recharged it properly. I just haven't had the time or money to have the a/c looked at since it does work, but it certainly doesn't cool as well as it used to.
Old July 26th, 2007, 13:51   #6
mopractice
Default Still have coolant issues
I'm smelling coolant because it is being pushed out the overflow. Took it to the dealer and they diagnosed a bad cap (day and half later). I'm still adding a quart every 150 miles.
Something is causing the system to be over pressurized and allowing coolant out the drain when the cap reaches pressure. Maybe there is a large air bubble in the system that is not getting out - just expands when hot causing coolant overflow??
Another symptom is a gurgling sound from behind the dash when you start moving - like water running.
Is there a specific way to bleed air from the system?? Do you really have to use G12 or can the system be flushed and then use dex cool etc.
Thanks for any advice.
Old July 27th, 2007, 14:20   #7
mparker326
The gurgling sound is a red herring. I've got that and no coolant leak. Others have talked about that as well and it appears to normal.
2002 Golf GLS TDI
mparker326 is offline   Reply With Quote
Old July 27th, 2007, 17:28   #8
mopractice
Default Narrowing the cause
After reading other threads (with no conclusions) I installed a pressure guage on the coolant return line to the plastic tank. After driving a short distance I hit the accelerator hard and watched the cooling system pressure jump to 25 psi. Anytime the turbo kicked in the pressure in the cooling system jumped immediately. Now I see why the coolant is getting pushed out the overflow even though the system temperature never goes above 190.
Somehow the turbo is pressurizing the cooling system
Old July 27th, 2007, 18:52   #9
MOGolf
MOGolf's Avatar
The way to bleed air out of the system is to loosen the clamp on the hose going to the heater core connecting piece (the hose on the left as you stand in front of the car looking at it) and pull it back away from installed position. You'll see a bleed hole in the hose. Now pull the hose off the core connecting piece so that the hole is off the connecting piece, but don't pull the entire hose off the connecting piece. Fill the system with coolant until the coolant comes out of the hole. Push the hose back on and install the clamp.
Unlikely that the turbo is pressurizing the system unless you've got a bad head gasket. Your coolant would not remain pink if that happened. Pressure build up could just be caused by the faster turning water pump.
Have you got a collapsing hose some where (to/from the radiator?) when the engine is revved up? It seems a bit young for a clogged radiator.
I recommend that you use only G12 or G12plus.
MOGolf is offline   Reply With Quote
Old July 30th, 2007, 11:47   #10
mopractice
Default high pressures
There is an oily or soot looking particles that has started to show up in the coolant. There is no coolant in the oil.
My experience with head gaskets and cracked head is a slow build up of pressure in the system - a stream of tiny bubbles. With the pressure gauge installed and the car going down the road I can make the pressure jump to 25 psi almost instantly when I hit the accelerator.
With car up to temp, in drive, and foot on the brake, I can run the rpms up to 2500 - 3000 but the pressure holds steady at about 15 psi.
I haven't studied how the coolant system is interconnected with the turbo but there sure seems to be a correlation. If I drive like grandma my coolant level stays within range.
I drove the car over 1000 miles this weekend with temperatures above 100F. The car does not overheat and it only uses coolant when I put my foot in it.
MIKE
Old July 31st, 2007, 19:31   #11
MOGolf
MOGolf's Avatar
There is no connection between the turbo and cooling system. Only pressure in the cylinders could blow into the cooling system via a bad head gasket seal.
To illustrate the bleed hole I mentioned above, below is a picture of the bleed hole in the hose. It is outlined in white on the hose to the left in the picture. The hoses are between the battery and brake fluid reservoir under the plenum cover. Pull the hose back (towards engine) so that this hole is open through to the coolant.
To make it easy to know if the air is out (as out as you're going to get it), I unscrew the expansion tank, disconnect the level sensor electrical connector on the bottom, prop the tank up so that the level of coolant is above the level of the hose and loosen the tank cap. The normal installed position actually has the fluid level below the hose. The result is that the coolant will come out of the bleed hole when the air is out.
Do this on a cold engine. Put towels/rags under the hose to absorb coolant that comes out of the hole.
Old August 1st, 2007, 07:41   #12
dhuddleson
Excellent posting and photos! This would make a great "HOW-TO INSTRUCTIONS" posting if we had such a category....
The light (white?) color of this vehicle allow easy identification of the work to be performed. Thank you!
Ottawa, Ontario, Canada
2012 Jetta Highline TDI sedan
2005 Passat GLS TDI sedan (sold)
2003 Jetta GLS 1.8T wagon (sold)
dhuddleson is offline   Reply With Quote
Old August 1st, 2007, 10:28   #13
mopractice
Thanks for the pictures!
I guess that I will be getting a new head gasket. I have an appointment this afternoon. We'll see if the extended warranty is any good.
If the gasket is not covered ... Is this a project that an adept DIY can do? Are there special tools needed -beyond standard things like torx etc.
Thanks Again MIKE
Old August 24th, 2007, 14:44   #14
mopractice
Default Bad head gasket causes damage
Removed the head and found that the leaking head gasket apparently caused damage to the piston.
I know the right way is to replace the piston. What are the ramifications if I just put a new gasket in and drive? Once there is damage will it continue?
Can I buy just one piston and rings?
If you are loosing coolant - continuing to drive may damage the piston and head.
Mike in Minnesota
Old August 24th, 2007, 14:58   #15
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You DO NOT want to leave that piston in there. Once you get it out and see the ring lands you will see why.
oilhammer
www.cardocautomotive.com
Page generated in 0.16170 seconds with 9 queries
[Output: 122.69 Kb. compressed to 101.81 Kb. by saving 20.89 Kb. (17.02%)]
