Old July 9th, 2007, 14:36   #1
grtn316
TDI(s): 01 Beetle
Default CEL: P1248 Help!
CEL: P1248
Injection Start Control Deviation
I'm new to these cars/motors so the more info the better. I cannot find a definite answer on what the problem is/what I need to fix.
I just got this car yeterday so I'm not really sure how a good running beetle should perform. It starts good, kinda loud...not quite as loud as a diesel truck though. Seems like there may be a little power loss in the higher rpms. This may all be normal...I'm just shooting out information.
Also, when I was driving the car home yeterday I saw the CEL on but it was VERY dim. Today the light is gone. Went to Autozone today and got the code above. I'm kinda thinking that the light was tampered with so that the car would appear in good condition but I'm unsure. Anyone heard of this before?
David
grtn316 is offline   Reply With Quote
Old July 9th, 2007, 15:35   #2
2004STARWARSTDI
2004STARWARSTDI's Avatar
Post P1248
17656/P1248/004680
From Ross-Tech Wiki
Contents
[hide]if (window.showTocToggle) { var tocShowText = "show"; var tocHideText = "hide"; showTocToggle(); }
[edit]
17656/P1248/004680 - Start of Injection Timing Regulation: Control Deviation
[edit]
Possible Symptoms
  • Loss of Power at high Engine Speeds
  • Engine difficult to Start
[edit]
Possible Causes
  • Start of Injection Timing Regulation not OK
  • Injection Pump Control Range blocked/dirty (e.g. by Metal Particles)
  • Engine has stalled / ran out of Fuel recently
  • Wiring/Connectors from/to Injection Valve (N108) faulty
[edit]
Possible Solutions
  • Check/Adjust Injection Start
  • Check Fuel Supply
  • Check/Replace Fuse(s)
  • Check/Repair Wiring/Connectors from/to Injection Valve (N108)
[edit]
Special Notes
Retrieved from "http://wiki.ross-tech.com/index.php/17656/P1248/004680"
Categories: Fault Codes
Views
Personal tools
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old July 9th, 2007, 15:47   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Please do yourself a favor and quit taking the car to Autozone for their generic scan tool's uselessness.
You need to get a GOOD Volkswagen-specific scantool. Ross-tech's VAG-COM is an excellent one that works on any PC.
oilhammer
www.cardocautomotive.com
Old July 10th, 2007, 07:31   #4
grtn316
TDI(s): 01 Beetle
I'm thinking about it but...what benefit does this tool have over autozones? I got the correct code and theres plenty of information on this website to reference it...so what makes it so much better (serious question...debating on buying it).
Also, can I adjust my injection timing with this software or am I confused?
David
Old July 10th, 2007, 07:58   #5
oilhammer
oilhammer's Avatar
Generic scan tools often to not retrieve ALL the stored DTCs. On any make of car, not just Volkswagens. There may be 3 or 4 more DTCs stored, and when looked at together may reveal clues as to the true nature of the problem.
I work on cars for a living, and have seen and used all kinds of scan tools on all kinds of cars. The generic ones just are not that great. They miss things, and are very limited on overall capabilities. Try asking Autozone to access any one of the other 10+ modules in your car!
The VAG-COM works just as well, in some cases actually better [easier] than the official VAG scan tools that the dealers use. In fact some dealer techs even use the VAG-COM! It will do far more than anything any generic scan tool can do, and it is not all that expensive.
Autozone and places like them cause so much stupid problems with half-assed "code reading" for DIY's and all they are really concerned about is selling you a bunch of parts.
And yes, you can use the VAG-COM software to check and adjust your injection timing.
oilhammer
Old July 10th, 2007, 08:08   #6
grtn316
TDI(s): 01 Beetle
Anyone know where this vacuum line goes? Maybe the source of my problem...
Anyone know why this would be replaced?
Old July 10th, 2007, 08:14   #7
oilhammer
oilhammer's Avatar
That might be the vacuum vent to the air cleaner, which will not cause any driveability problems. There is a vac diagram on a sticker under the hood of the car.
oilhammer
Old July 10th, 2007, 08:17   #8
grtn316
TDI(s): 01 Beetle
My sticker isn't there.
David
Old July 10th, 2007, 11:34   #9
Dave_D
David
To the best of my knowledge only VAG specific software can reach the other controllers, such as the airbag and ABS controllers. I found this out when a airbag light came on shortly after I bought my Jetta and a generic OBD saw no problems and could not reset it. I purchased a cable from lubrication specialist and downloaded the shareware VAG COM to work with it. This enabled me to read and clear codes on all controllers in the car.
I should note that this cable is not compatible with the newest cars that use the CAN bus, so this option may not be available to you if you have an A5 or a B6 vehicle.
1999.5 (A4) Tornado Red Jetta GL TDI,5 speed,4 door, RC 2+, Old Navy CCV mod, ventectomy, CAT filter
Dave_D is offline   Reply With Quote
Old July 10th, 2007, 13:11   #10
grtn316
TDI(s): 01 Beetle
Anyone have a vacuum wiring diagram?
Old July 11th, 2007, 04:39   #11
oilhammer
oilhammer's Avatar
http://www.bentleypublishers.com/
oilhammer
Old July 16th, 2007, 14:24   #12
grtn316
TDI(s): 01 Beetle
Changing injection pump timing solved my problem.
Old July 16th, 2007, 15:01   #13
PDJetta
PDJetta's Avatar
Its on a label under the hood, near the hood latch.
--Nate
Old July 17th, 2007, 06:03   #14
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
Pretty sure that the hose goes to the bottom of the aircleaner box... its hard to spot but if you reach down with your hand you should feel it.
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old May 27th, 2010, 07:18   #15
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy:
Bumping this thread from the dead, in the hopes that it helps someone else out. Our NB had the same code & problem last year. VCDS said '17656 - Injection Start Regulation: Control Deviation P1248 - 35-10 - - - Intermittent', the car was smokey, noisy & down on power. Timing in VCDS was pegged full advance (255) and statically retarding the timing gained a bit of power back.
Pulled the pump and sent it to DFIS, who corroborated my guess that the advance solenoid was broken & wedged full advance. One rebuild later, the pump was back in (and after figuring out the flywheel had two TDC marks) it fired up and has worked perfectly since.
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Page generated in 0.18230 seconds with 9 queries
[Output: 129.43 Kb. compressed to 108.07 Kb. by saving 21.36 Kb. (16.50%)]
