Old June 21st, 2007, 17:00   #1
jwm9289
Fuel Economy: 40 to 50 mpg (90% highway)
Default Speedometer,tachometer & fuel gauge INOP
Hello All,
I have a 2001 Beetle TDI, Speed,Tach & Fuel gauge quit working? Any ideas or Troubleshooting?
Thanks,Jim
jwm9289 is offline   Reply With Quote
Old June 21st, 2007, 20:10   #2
jwm9289
I double checked-Speedometer is staying at 110mph, Tachometer stays at 5000rpm's & fuel gauge stays full.
(odometer & tripometer both register mileage.)
Old June 21st, 2007, 20:13   #3
alphaseinor
can you scan the cluster with a VAG-COM?
alphaseinor is offline   Reply With Quote
Old June 22nd, 2007, 11:34   #4
jwm9289
no, i dont have access to vag-com!
Old June 27th, 2007, 17:49   #5
jwm9289
i did hook up to a matco scanner and was able to read speed,rpm's and all engine info.
Btw- the CEL stays on and also the air bag light. i'm thinking cluster!
will one work out of a gas beetle or do i need a tdi?
Old June 27th, 2007, 19:47   #6
ablair12
I just replaced the instrument cluster in my '96 Passat. I tried repairing it myself after reading about the voltage regulators buring out inside the units. After giving up on that I sent it away to a company that specializes in speedometer repair and they told me it was unrepairable. I've heard a lot of people say that weak batterys can kill the cluster. I would throw a new battery in asap if you haven't already.
Search for dead instrument clusters in the forums, you should find a lot.
ablair12 is offline   Reply With Quote
Page generated in 0.11494 seconds with 9 queries
[Output: 67.13 Kb. compressed to 58.35 Kb. by saving 8.78 Kb. (13.08%)]
