Old June 19th, 2007, 20:48   #1
iceman31
TDI(s): 2006 TDI
Default Does my Jetta have a block heater?
How could I tell if my Jetta has a block heater. I can not find a cord anywhere. It is a Canadian car so you would think it would have a block heater as standard issue. If it does not have one any idea ho much it will cost me to get one installed?
iceman31 is offline   Reply With Quote
Old June 20th, 2007, 02:24   #2
Lightflyer1
Lightflyer1's Avatar
From my understanding you don't really want a block heater. Search here for a Frost heater. There is a company listed here that will sell you a very nice little kit and it does an excellent job from what I have read.
Here it is. This is the one you want:
http://www.frostheater.com/
2015 Beetle TDI.
Old June 22nd, 2007, 23:41   #3
CAATS_Man
CAATS_Man's Avatar
"Does my Jetta have a block heater?"
My didn't and I don't believe it's even an option. Why don't you complete profile so we know where you live. The best bet is to check with members who live in your area to find out if it's worth worrying about.
2006 Jetta TDI, DSG, ESP, Pkg 2, Platinum Grey w Beige interior & 8 airbags. Evolution Skid Plate.
CAATS_Man is offline   Reply With Quote
Old June 23rd, 2007, 18:49   #4
Strider
TDI(s): 2006 Jetta
At least here on the Wet Coast, they're not offered as features. :P Typically, from what I understand is unless you live in Sioux Lookout or Tuktoyuktuk, you don't really "need" one. However, on the other hand, a coolant heater (such as the aformentioned "Frost Heater" I believe) will make your car put out warm air even faster than the onboard electric air heater.
On the other hand, I don't know how much good it will do you. Even this past winter, on the few days when it hit -15 or so, I watched the temperature needle drop visibly while I sat at stop lights. The engine just doesn't put out much heat at all when idling.
Strider is offline   Reply With Quote
Old June 23rd, 2007, 19:41   #5
CADtechTDi
The Frost Heater is a "must have" mod for anyone in the snowbelt, IMHO. This tank heater will circulate warm coolant throughout the block by convection, including inside the cabin. I plug mine in for a few hours (using a timer) each morning during the winter.
While the modern diesel glowplugs do a bang-up job no matter what the temp, using a frost heater like this makes it easier on the engine during ultra cold weather starts. The engine turns over much easier, runs much smoother after initial start-up, and having a warm cabin first thing in the morning is an added bonus.
The things that come to those who wait are what's left behind by those who got there first.
CADtechTDi is offline   Reply With Quote
Old June 23rd, 2007, 21:31   #6
2footbraker
2footbraker's Avatar
Mine came with a heater but not a block heater, it's an oil pan heater. It came as standard equipment.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old June 23rd, 2007, 21:36   #7
compu_85
Gadget Guy
compu_85's Avatar
Standard dealer installed aftermarket equipment
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old October 17th, 2013, 19:54   #8
odezification
TDI(s): 2006 Jetta
Hmmm I have a cord coming from the bottom of my car, I initially thought it was a block heater cord, but from what I have read, VW TDi's do not have frost plugs in the engine block. I would be very lucky if it was a fost heater,I sure hope it's that, but I some how doubt that. I live near Edmonton, Alberta, Canada so one would assume that every car purchased would have a block heater.
odezification is offline   Reply With Quote
Old October 18th, 2013, 04:25   #9
SilverGhost
SilverGhost's Avatar
Newer TDIs don't have an accessible soft plug to put a heater. But they do sell a heater that appears to function very much like the Frost Heater everyone is familiar with. It goes in line and replaces one of the small hoses from the oil cooler. The last time I looked there was also a small ECM update when you installed it - but I have no idea what the update changed.
I believe I read something about the heater was either standard or only available on Canadian cars. And VW is very proud of the fact that their TDIs don't need a heater to start at -40C.
Jason
SilverGhost is offline   Reply With Quote
Old October 18th, 2013, 05:02   #10
tdiatlast
OEM heater is more than twice the cost of a FrostHeater, with 1/2 the wattage, IIRC.
They don't NEED a heater, but will benefit from one in colder climates.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old October 18th, 2013, 13:36   #11
Tim$2
Tim$2's Avatar
TDI(s): 2009 JSW
When I got my 2009 the heater was not available even though there is a grill piece that will hold the plug for it available. I bought the grill with the plug holder and a frostheater and it worked out well. As for the car starting at -40C... It will proabably start without a heater but the ruckus it makes and how rough it runs for the first bit will have you runnning to your computer to order the frostheater in a heartbeat.
Cup holder iPod dock, Frostheater
Tim$2 is offline   Reply With Quote
Page generated in 0.15151 seconds with 9 queries
[Output: 99.46 Kb. compressed to 83.67 Kb. by saving 15.80 Kb. (15.88%)]
