Yes, I meant that 229.1 IN ADDITION with B3/B4 was good because it adds piston cleanliness, cam wear and sludge to the ACEA tests. But 229.3 is far better, look:
</font><ul type="square">[*]<font size="2" face="Verdana, Helvetica, sans-serif">TEST--------------//--229.1---//--229.3</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Chlorine, ppm--------100 max-------100 max</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">111E Sludge----------RL140 +2------RL140 +2/+3</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">111E Cam wear--------5µm max-------3 µm max</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">602A:</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Piston clean.--------20 min--------24 min</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Bore polish.---------7% max--------4.5% max</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Cyl wear µm----------20 max--------15 max </font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Cam wear µm----------50 max--------45 max</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Oil cons. kg---------10 max--------10 max</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Visc. increase %-----90 max--------70 max</font>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Engine sludge--------8.8 min-------8.9 min
</font>[/list]<font size="2" face="Verdana, Helvetica, sans-serif">If you check the ACEA B3/B4 limits regarding the MO602A, you'll see that they roughly match 229.1 . That's why I seek oils that are 229.3 and B3/B4 compliant.
In conclusion, I think we agree
