Old May 26th, 2007, 00:25   #1
xma55
Default overfill on passat pd 130bhp diesel
just got my car back from 49 k service,have ched the oil and it seems to go over the top crank on the dipstick how serious is this, i says in the hand book on bo account must it be overfilled?
xma55 is offline   Reply With Quote
Old May 26th, 2007, 00:53   #2
boraTDI04
boraTDI04's Avatar
Fuel Economy: 50+ and improving
damage to the cat COULD occur, whats the reading on the dipstick?
2002 vw jetta 1.8t (wifes)
2004 vw bora 1.9tdi (35k)-screenectomy, ventectomy/50 lifetime mpg
NEED WORK? ase certs. indy metro area/pm me
north side indy, inside loop-off michigan/421
How we ever gonna get up if all we want to do is get down?-go bills!
boraTDI04 is offline   Reply With Quote
Old May 26th, 2007, 01:28   #3
xma55
it is over the 2nd crank on the dipstick,
Old May 26th, 2007, 04:49   #4
Waldek Walrus
Fuel Economy: 54/47/42
How far over? If it is a millimeter or two you are probably OK. If it is like 5 millimeters you should get some extracted. If it is much over 5 millimeters you should get the bloke who flooded it to come and extract it for you - and not run the engine until he does.
With a measurement someone here can give you good advice.
Doug
'06 TDI NB (Julie Bug)
'11 GMC Acadia
'01 Buick Lesabre - boulevard ride
Waldek Walrus is offline   Reply With Quote
Old May 26th, 2007, 23:49   #5
xma55
ok thanks for the help with this , its about 2mm over so i guess its ok.
they did not use the 505.01 spec oil they used a 5/30 for vauuxhall diesel engines which they tell me is fine, i have read the threads on this forums and amd starting to panic
Old May 27th, 2007, 05:41   #6
Waldek Walrus
Exclamation Not 505.01 Oil
Who is they? Is this a VW specialist that knows the oil requirements for PDs? Reading in these threads can give you reason to panic. Not just any good diesel oil will work in the PD. Look at threads here about cams and lifters - 2004 BEW Cam lifter failure report . Some have gone to the point of having oil that doesn't meet the VW 505.01 specification removed and replaced with the right stuff. This is a controversial topic. Also look at the sticky (at the top of the forum - "What oil do I use?" READ FIRST BEFORE ASKING [If my links don't work these are both is this Fuels & Lubricants forum]
Good luck
Doug
'11 GMC Acadia
Old May 27th, 2007, 15:14   #7
xma55
ok thanks for the confirm i think i will get the oil changed again , with the cambelt i will need to replace this soon, should the water pump be done aswell or not i hear conflicting stories in this.
Old May 27th, 2007, 20:19   #8
Capture1
These links should shed some light on what need to be changed along with the TB:
Timing Belt replacement procedure
http://pics.tdiclub.com/pdf/a4timingbelt.pdf
http://pics.tdiclub.com/data/517/525...checkoff list)
Capture1 is offline   Reply With Quote
Old May 30th, 2007, 20:32   #9
TomB
Fuel Economy: 34 mpg on first tank
Summarizing from the Bentley eBahn manual.
As long as the oil mark is between the two bends in the metal of the dipstick you are within the limits.
There is a hash mark in that bent area. If below that you can add "not more than .5 L". If in the hash area you can add a little. If above the hash and below the top bend, do not add any oil.
VW states to run the engine up to temperature. Turn off the engine and let it sit for 3 minutes, then take the reading.
Hope that helps. If you are above the top bend in the metal you need to extract some of the oil out to get it below that mark.
Extra oil above that top bend WILL hurt your catalytic converter.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Page generated in 0.13961 seconds with 9 queries
[Output: 86.66 Kb. compressed to 73.80 Kb. by saving 12.86 Kb. (14.84%)]
