Old May 17th, 2007, 07:16   #1
bondtimbond
Default A5 Jetta alignment specs? Alignment warranty??
My 06 TDI with 10K miles needs an alignment check. I believe my toe adjustment is off based on driveway checks I have performed as measured with a homemade tool I have used successfully on other cars (I believe it is actually toe'd out slightly). The symptom is my car tends to wander at hi-way speeds.
I have contacted two Houston area dealers and they both tell me that VW doesn't cover alignment unless the car pulls dramatically (which mine does not). One dealer said that VW doesn't cover alignment at all after you take delivery of the car!! I think this is ridiculous, but rather than make an issue of it I think I will just take the car to a shop I trust and work with often and have them check it. I will call them and make sure they have the adapters for the bead-less rims that my VW has. I want to make sure they use the right specs for the alignment. I have a copy of the Bentley paper manual, and I have attached a copy of the page of specs to this thread. It appears to show 10 deg +/- 10 minutes for total toe (which converts to 10 deg +/- 0.17 deg). I assume this is toe "in" that is specified. That seems like an huge amount of total toe! Also, there is a comment that says "wheels not pressed". Anyone know what that is referring to? By referring to the text in the manual, the "base" column would apply to my car.
Maybe someone has had their car aligned and knows the specs used? Also, if someone has the full Bentley CD who can verify that the specs listed here are correct? Any comments or experience would also be appreciated. Thanks.
bondtimbond is offline   Reply With Quote
Old May 17th, 2007, 07:51   #2
buckeye96
TDI(s): 2005 Jetta ?
I have never known any dealer to warranty an alignment. Go get it fixed at a place you trust and not the dealer. Just be glad that you don't have an AWD car like the Subaru, that takes a 4 wheel alignment machine that not a lot of places have or are aware of.
buckeye96 is offline   Reply With Quote
Old May 17th, 2007, 08:07   #3
bondtimbond
Well, in my experience (with Hondas and Toyotas) the dealer would generally warrant the alignment for 1 year 12K miles. I have been able to go in and they would check it without complaining. The attitude of VW not being willing to even check it was a surprise to me - but this is my first VW. I however agree that I will just go to my own shop, but I want to confirm the specs before I do....
Old May 17th, 2007, 08:31   #4
Jason D
Jason D's Avatar
Keep us posted. Have you changed the "adaptive steering" setting in VAG-COM or whatever VW calls it? Mine has been changed but the car still wanders a bit on grooved or uneven roads, which leads me to believe its a toe problem also.
2006 TDI-5 speed
1990 Mustang GT-Vortech @ 11 PSI
Jason D is offline   Reply With Quote
Old May 17th, 2007, 08:55   #5
bondtimbond
Yes, I have reset that setting to "4" from the initial setting of "5" from the factory. That did make an improvement for sure, but only on what I call "driver induced wandering". When set at 5 any slight input to the wheel results in the car turning slightly. This made it hard to keep the car going straight. With it at 4 that type of wandering is no longer an issue. I also tried 3 but have settled on 4. But, I still have wandering due to road and wind that seem too pronounced, and that can easily be due to alignment settings.
Old May 17th, 2007, 09:14   #6
Andrewh
They checked mine for free a couple of times. I didn't think the steering wheel was tracking straight, so they claimed to have checked it.
Andrewh is offline   Reply With Quote
Old May 20th, 2007, 19:11   #7
f1wanabe
f1wanabe's Avatar
My dealer service manager told me the wandering is caused by the steering sensitivity setting. I had my steering sensitivity changed and it pretty much solved the wandering problem. I had it on "4" for a while, changed it to "3", but will ask them to put it back to "4". Be prepared for some dealers not to know anything about it, or not wanting to do it based on liability concerns. A member with a VAG COM may help as well. But, I am sure your alignment is just fine.
f1wanabe is offline   Reply With Quote
Old May 21st, 2007, 00:52   #8
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
I thought that front wheel drive were toed out, because as they start to drive the tires the suspension wants to pull "in".
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old May 21st, 2007, 11:48   #9
bondtimbond
As discussed earlier in the thread, the steering sensitivity setting does effect the feel of the steering, and I have a VAG-COM and did try different settings also settling on 4. It does not however eliminate the tendency of the car to be heavily effected by wind and road textures, which is my current problem.
Old May 21st, 2007, 11:53   #10
bondtimbond
That could be, but the specs that I posted from the Bentley paper manual above do not clearly state which it is. I would think that the manual would state whether it was toe in or out. Some (but not all) front drive cars do have toe out, but that is not always the case.
Is there anyone out there with the full Bentley manual on CD who can check the alignment specs and confirm what they are?? What is the toe supposed to be, and does it state toe in or out??
Old May 23rd, 2007, 03:17   #11
Mach1
From the specs above 10 degrees...which would be 10 degrees toe out(as toe in would be negative)..
Most front wheel drives are toed positive(toe-out).
2004 6L 89000 19MPG
Old May 24th, 2007, 14:05   #12
bondtimbond
OK, assuming the Jetta is supposed to be toed out, I really doubt the listed spec of 10 deg total toe is correct. 10 deg would be an ENORMOUS amount of toe. Doing some quick trigonometry, that would be 5 deg per side. Assuming the diameter of each wheel and tire is about 24 inches tread to tread, then that would be result in about 2" of toe out per side!!! Most cars have about 1/16" - 1/8" toe in or out. There must be a misprint in the specs that I posted in the first post of this thread from the paperback Bentley manual.
Can someone with the full CD version of the Bentley manual check to see what the toe specs are for an 06 Jetta?
Old May 24th, 2007, 23:45   #13
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
"wheels not pressed" does that imply toe is to be measured with the wheels off the ground?
DPM is offline   Reply With Quote
Old June 7th, 2007, 08:18   #14
bondtimbond
Default Results of alignment
Well, I finally got my car into the alignment shop as I discussed that I would and the results are posted in this thread below. I am very happy with the results. The car now drives noticeable better at highway speeds. There is much less "twitchiness" than existed before. The car is also less affected by crosswind. Slight inputs to the steering wheel now do not result in the car darting off left or right like it did before. Overall, much improved. I recommend to anyone who isn't happy with the feel of their Jetta on the highway that you have your alignment checked, as your toe setting might be off also.
Regarding the specs that were used, the shops alignment computer system had a set of specs that the tech pulled up, and I compared them to those that I posted at the beginning of this thread which came from the Bentley hard copy manual. All the specs were exactly the same except that the front toe settings in the shops alignment computer were shown to be +0.17 deg toe in (basically the same as the rear) where the Bentley manual listed a confusing number that didn't make sense (10 deg toe!).
As you can see from the posted results which shows before and after (actual), my car was initially toed out in the front, not in. According to the experienced tech at this shop who is highly respected around here and also in another reference that I reviewed, positive toe represents toe in, not toe out. I questioned the tech on this since I have heard (in this thread for example) that front drive cars should be toed out. His response was that some, but certainly not all front drive cars call for toe out. The spec sheets list all toe settings as positive, front and rear. The rear toe on my car was initially not too far off, just not equal left to right but at least it was positive. My rear camber was only slightly off, but the tech reset it anyway. Front camber and caster is not adjustable but were OK anyway.
Finally I enjoy long drives in my Jetta! :-)
____________________________________
2006 Jetta Mk5 June build Package 2 Auto
Old July 16th, 2011, 11:05   #15
Henrick
Sorry to reply to an old thread, but...
Any ideas on how to recover/repair/align an out-of-spec Caster and Camber?
My car's right side Caster and Camber are out of spec:
-Caster: Should be in range of 7*04' - 8*04' but mine's at 6*52'
-Camber: Should be in range of -1*00' - 0*00' but mine's at -1*10'
Henrick is offline   Reply With Quote
Page generated in 0.17979 seconds with 9 queries
[Output: 123.00 Kb. compressed to 102.59 Kb. by saving 20.40 Kb. (16.59%)]
