Old May 13th, 2007, 12:52   #31
rotarykid
rotarykid's Avatar
Fuel Economy: 64 .1city @ 30-60 mph/ 52-53 @ 70-85 mph hyway ( 52 to just under 60 normal around town)on LSD
Thumbs up
Originally Posted by BriGuySTL
Sorry about that I'm a crappy speller and copy everything into Word so I can spell check it lol
So filling up wouldn't really change. Stick the nozzle in and let it go, when it clicks keep manually adding more until it is toped off. Is that about right? You can't do that without doing the ventectomy?
Not sure if you are aware but look up in the top right corner and you will see a ABC/(check) . Just click on that and follow directions to download it . Then you will have a spell check that works quite well .
Once you have it down loaded you can ( right click on the mouse to access it ) and use it on anything that needs a spell check .
More diesels than I can list
rotarykid is offline   Reply With Quote
Old May 13th, 2007, 12:53   #32
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
ABC check works in Internet Explorer, while Firefox has built in spell check.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old May 13th, 2007, 14:01   #33
BriGuySTL
BriGuySTL's Avatar
I'll try using that from now on, its just some spell checks suck hard core so I got in the habit of using Word.
As far a the ventectomy, I'll probably end up doing it later, I just want to see what it is like to fill it up regular once. I'm at 135miles and just below 7/8 of a tank, in the RX8 I would be just below 1/2
2004 Jetta GLS TDI Silver 5-speed
"Never be afraid to try new things. Remember an amateur built the Ark, but a large group of experts built the Titanic" Unknown
BriGuySTL is offline   Reply With Quote
Old May 13th, 2007, 15:14   #34
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
By venting, 135 miles and you'd just be comming off the 1/1 mark
Old May 13th, 2007, 15:30   #35
rotarykid
rotarykid's Avatar
Thumbs up
A ventectomy makes it easier but you can get the same amount of fuel in the fuel tank by just holding/pushing on the vent button ( inside the fuel filler neck on the left ) open with the filler nozzel & bleeding in fuel until it fills to the stop & stays .
Old May 13th, 2007, 15:33   #36
BriGuySTL
BriGuySTL's Avatar
Ok I see how it works now, thanks
Old May 13th, 2007, 15:42   #37
2004STARWARSTDI
2004STARWARSTDI's Avatar
Lightbulb
Also you might want to do a Ventectomy. This way you can fill up the tank to its fullest level without having to vent.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old May 13th, 2007, 16:35   #38
BriGuySTL
BriGuySTL's Avatar
That is what we were talking about
Page generated in 0.16140 seconds with 9 queries
[Output: 88.53 Kb. compressed to 76.03 Kb. by saving 12.51 Kb. (14.13%)]
