Old May 3rd, 2007, 21:03   #1
mxcale
Default EGT gauge question? NEED FAST ANSWER please
just a 2 1/2" turbo back straight pipe exhaust from GHL and i need to know where to put the bung thingamabobber for the egt gauge. i'd like to know the exact location of where to have that thing welded in on the down pipe. as in aproximatly how far down and if it should be (in acordance to the car) on the front side or maybe back side or left or right? thanks for any help!!!!!!!
mxcale is offline   Reply With Quote
Old May 3rd, 2007, 21:11   #2
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Most people prefer the EGT on the turbo side - many options here. Search for EGT placement.
I have mine on the downpipe (been too lazy to drill/tap my turbo). I have it on the outside corner at ~45 degrees 'round the bend' from the turbo flange. It points up and to the left (as if you were sitting in the drivers seat). Generally - closer to the tubo is better (both pre and post turbo)
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP110 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, VNT 17/22, 3 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/50/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ASV Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, Gauges
Fix_Until_Broke is offline   Reply With Quote
Old May 3rd, 2007, 21:12   #3
jetta-girl
TDI(s): 06 Jetta TDI
In the down pipe, as close to the turbo as possible, positioned so that it won't hit the firewall or anything else.
Good luck, with it.
jetta-girl is offline   Reply With Quote
Old May 3rd, 2007, 21:13   #4
Locosmotion
Fuel Economy: LOTS
Dont put the bung in the downpipe. The egt will not read correctly. You have to put it in the turbo neck or down the EGR port with an adapter.
Locosmotion is offline   Reply With Quote
Old May 3rd, 2007, 21:21   #5
Monkey1
Monkey1's Avatar
Fuel Economy: 64mpg, 60mpg, 56 mpg
All depends on what the egt gauge instructions say. Mine was a autometer and was specific to put it post turbo as it was calibrated for that type of installation.
Also if the probe ever broke, bye bye turbo
Monkey1 is offline   Reply With Quote
Old May 3rd, 2007, 21:22   #6
jetta-girl
Yeah, if it's possible that would be ideal. However, I guess it depends on his set up. On my car, we initially planned on installing the bung in the exhaust manifold, but it was way too much work to get to it.
Old May 3rd, 2007, 21:34   #7
Fix_Until_Broke
What makes it read incorrectly in the downpipe? The temp will be lower, but not incorrect I believe.
Old May 3rd, 2007, 21:40   #8
Matthew_S
Matthew_S's Avatar
Fuel Economy: 41-46
You can put it in your glove compartment and it will read correctly it just won't give you any useful information.
Matthew_S is offline   Reply With Quote
Old May 3rd, 2007, 21:53   #9
DbLog
DbLog's Avatar
Fuel Economy: 50.5 mpg best, 34 mpg worst
It's not that the reading will be wrong. Pointless would be more accurate. Installing it in the downpipe won't let you know when engine parts start melting. Does anyone know of benefeits having the dung installed in the downpipe as apposed to in the manifold?
DbLog is offline   Reply With Quote
Old May 3rd, 2007, 21:56   #10
Fix_Until_Broke
Unless you calibrate it for your application against a known reference, it won't be any more/less useful than anywhere else. Mine has been very useful in the downpipe. I plan to put a 2nd one in pre turbo as well to be able to compare the two. We're off topic arguing semantics here.
Old May 3rd, 2007, 21:56   #11
Locosmotion
Fuel Economy: LOTS
1 vote for the glove compartment.
Old May 3rd, 2007, 22:31   #12
mxcale
alright alright. if the thing needs to be put in the manifold i'l do it. i thought it was suppose to go after the turbo tho. so now the question is where on the manifold is it suppose to go? does it need to be welded into the manifold or wut is the proper method of installation? pardon me for all the "newb questions".
Old May 3rd, 2007, 22:53   #13
DbLog
DbLog's Avatar
http://forums.tdiclub.com/showthread...&highlight=egt
Old May 4th, 2007, 04:21   #14
mycruiseagent
mycruiseagent's Avatar
Fuel Economy: 56.4/45.1/36.0
I vote for this one:
Originally Posted by DbLog
MCA
'02 Jetta GL - not stock
Drill-less EGT probe solution
mycruiseagent is offline   Reply With Quote
Old May 4th, 2007, 04:23   #15
mycruiseagent
Maybe that's my new tag line: "It's better than the glove compartment."
MCA
Page generated in 0.16333 seconds with 9 queries
[Output: 129.46 Kb. compressed to 108.30 Kb. by saving 21.16 Kb. (16.35%)]
