Left Coast Resident
Ubẽr Clubbie
Without warning Sunday night the original battery blew a gasket, so to speak. I replaced it with an Odyssey PC1700MJT exactly like this:
http://www.batterymart.com/p-odyssey-pc1700mjt-battery.html
I've bought from these people before and I wouldn't hesitate to recommend them (NAYYY), or you can do what I did, need it right now, buy it locally, and pay through the nose. But I digress.
I got smart after the forth or fifth time the battery box and my cheapo 'work table' went skidding across the garage like something out of a bad Abbott and Costello or Three Stooges movie each time I tried to put the battery in it to do test fitting. So I took a large wood screw and screwed it down to the work bench. What a great idea -- by the time I got to the car, everything worked, and it was easy-peasy. Here is a shot during test fitting:
The install requires the following modifications:
Grind the corners in one of the two Mercedes hold down brackets that you'll need to ask for special order when you order the battery. I have no idea how much they were as the store threw them in, but don't you worry about it, I paid plenty for them, if you know what I mean:
There is another one inserted into the other side of the battery that you can't see. No modification required on that one.
The sides of the case need to be marked and ground about like this. Yes, I know the cut-out you are seeing is irregular -- that's because the VW mount will deform slightly when you put the cover on, and not be quite centered or vertical with respect to the battery.
In the event that this is not clear, I'm cutting into the exterior metal jacket (not the battery case itself), which is an addendum to the battery, I.E. you can purchase the battery without the metal jacket (although in this instance, the jacket was needed to anchor the Mercedes clips).
With those two mods done, the battery will fit nicely where it's supposed to go. Here are two views. Since Odyssey provided two short 3/8" x 16 bolts and washers to go into the tops of the terminals, I added them after tightening the VW terminals down. The battery terminal leads make full contact, and aren't going anywhere.
The top goes on, no problem, and the battery cranks like crazy.
Al
Al
