Old June 30th, 2007, 17:48   #16
Pat Dolan
Fuel Economy: 800km/1100km/tank
Originally Posted by no-blue-screen
Anyone care to share their source for VW rims and discounted prices? A lot of the rims I see are way overpriced. Not too much on eBay from what I saw for the A5. Will any of the A4 rims fit the A5? I like the bbs style rims.
I hate to say it on this forum, but vwvortex classifieds has wheel/tire pages in both Canada and US and are quite useful for this purpose.
A4=2003 TDI Variant, A3=Golf CL, A2=2x1.6 Jetta TDs, Golf Syncro Country, A1=Scirocco Mk1 & 16v, Audi 5000TD, Porsche 924/M471 and a bunch of diesel trucks.
Pat Dolan is offline   Reply With Quote
Old August 24th, 2007, 21:39   #17
penclnck
Got off my lazy butt and added some wheels I spied over the last couple of months... 126 wheels up there now.
Pencilneck blah blah blah
penclnck is offline   Reply With Quote
Old September 10th, 2007, 18:53   #18
penclnck
127th wheel!
Old September 23rd, 2007, 17:31   #19
penclnck
128th wheel... the Mugello.
Old December 9th, 2007, 09:05   #20
ogrice
Fuel Economy: hi 40's, lo 50's
Default does this count.?
Are you also counting oem audi manafactured rims that bolts straight across.? I run 18's from the TT top end model. 7spoke 18"x7.5", 5x100 lugs made by Ronal in Italy for oem audi/VW.
see my example:
http://images2.auction123.com/sizequ...g?webimage001m
Just put those rims on a red 2001 jetta and lower it 2" all around, that one would be mine.
ogrice is offline   Reply With Quote
Old December 9th, 2007, 18:52   #21
penclnck
Just VW rims. There are some older rims that VW and Audi both used. I have enough problems in life already and don't want to add more issues to my plate by trying to keep up with Audi wheels. I wish some one would do it, I'd like to link to such a site.
Old December 19th, 2007, 04:48   #22
G60ING
G60ING's Avatar
This is a canadian Corrado Wheel:
It also came on some Mk3 VR6s in Europe.
SLC Corrado BBS RZ
Here are the G60 corrado BBS RZ, note that the VR6 version's webbing pokes out:
G60ING is offline   Reply With Quote
Old December 19th, 2007, 04:58   #23
G60ING
G60ING's Avatar
Corrado Storm BBS Solitude Wheel
Old December 19th, 2007, 06:40   #24
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
"Picture 052" (in the A3 section) is an Audi 80 FWD wheel, minus the center cover, but with an owner added VW center cap plugged in. I don't think this Audi wheel was ever used as an OEM VW wheel.
"100-0042" (in the B4 section) is called simply "BBS wheel" in the VW electronic parts catalog.
<edit> Audi 4000 FWD, not the Audi 80 FWD <end edit>
Svante Arrhenius 1896
Old January 3rd, 2008, 20:11   #25
penclnck
Just added those 2 wheels, no data on them yet. I think the IMG_0766.JPG one is called Las Vegas, which would fall into the city naming theme.
Old January 11th, 2008, 15:01   #26
mk4gasm
TDI(s): 01 Golf
im going to start off by saying i have no clue about tires/rims, bolt patterns etc etc.
with that said, i really like the detroits for the mk5. both my 01 golf tdi (mk4) and the mk5 have 5 lugs, but i dont know if they are both 100 o 112. would they work? and do you guys think it would look good? its either those or the bbs'. oh by the way im going to 17s, any rubbing issues? i dont want alot of gap in the fender.
mk4gasm is offline   Reply With Quote
Old January 11th, 2008, 15:24   #27
G60ING
G60ING's Avatar
MK5 OEM wheels will not work on Mk4s
Old January 11th, 2008, 21:18   #28
penclnck
As noted, mk5 wheels won't fit the mk4s. As for running 17", not an issue, the mk4 platform came with several different 17" rims. As you go bigger on the rims, the sidewall on the tires gets small, so the overall tire tread diameter stays the same. Gap is caused more by the ride height of the car, thus a lowered car has less gap.
Old January 11th, 2008, 21:55   #29
compu_85
Gadget Guy
compu_85's Avatar
I have B3 alloys on my ECO, would you like pictures of them?
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old March 14th, 2008, 16:05   #30
penclnck
Default 131 wheels now
Just added another rim and fixed a few screw ups that I had caused....
Page generated in 0.18085 seconds with 9 queries
[Output: 121.60 Kb. compressed to 100.29 Kb. by saving 21.30 Kb. (17.52%)]
