Old April 4th, 2007, 14:24   #1
Peoria_TDI
Default Best method for EGR cleaning?
I will be cleaning my EGR soon, and plan on using carb cleaner and a tooth brush. If anyone has a better method, I would appreciate your suggestions.
2005 Passat TDI
Peoria_TDI is offline   Reply With Quote
Old April 4th, 2007, 14:25   #2
david_594
david_594's Avatar
Fuel Economy: 51.7/48.2/40.7
Just the egr or the egr and the intake manifold?
david_594 is offline   Reply With Quote
Old April 4th, 2007, 15:32   #3
Peoria_TDI
Just the EGR for now. Will look at the intake at 50k, at 27k now.
2005 Passat TDI
Old April 4th, 2007, 16:07   #4
TDI Believer
Responsible For Global Warming
TDI Believer's Avatar
TDI(s): No more TDIs
You'll be wasting your time.
TDI Believer is offline   Reply With Quote
Old April 4th, 2007, 16:13   #5
Peoria_TDI
Why is it a waste of time?
2005 Passat TDI
Old April 4th, 2007, 20:34   #6
Smokerr
Fuel Economy: 43.5/32/28
I plan on wasting my time when I get a nice warm weekend as well.
2005 Passat TDI Wagon
Smokerr is offline   Reply With Quote
Old April 4th, 2007, 23:02   #7
Peoria_TDI
Me too. I don't understand why cleaning/removing something that adversely affects mpg and performance is a waste of time.
2005 Passat TDI
Old April 5th, 2007, 18:21   #8
TDI Believer
I've got 73K on my car. Never cleaned the EGR. Car consistently gets 41-43 mpg on my 45 mile morning commute. Car has not suffered any performance degradation (other than losing RCII when the ECU was changed). Now explain to me why I would want to remove my EGR valve?
The EGR valve is dumping exhaust into your intake manifold...and you want to make sure it can dump in as much as possible?
These things don't need to be cleaned. If it will make you all feel better with some placebo effect...go for it. Certainly there's something more useful you could do for your car.
Has your mpg dropped? Is there some compelling reason to believe you need to do this to your car...other than the fact that others have posted pics of ugly, sooty EGR valves?
Did you know that one person here left some solvent on his EGR valve after cleaning it and the resulting backfire from the vapors in his manifold blew a turbo seal?
Don't get me wrong...I'm all for preventive maintenance. The EGR valve doesn't require it.
Old April 5th, 2007, 18:24   #9
david_594
david_594's Avatar
I dunno, i have seen some pretty ugly PD EGR's....
Old April 5th, 2007, 18:28   #10
jrock
Fuel Economy: 52.93 MPG MAX
TDI Believer,
Did you look at how restricted my EGR was?
http://forums.tdiclub.com/showthread.php?t=172724
2014 RAM Ecodiesel
2012 Passat SEL TDI
2005 Passat TDI (Sold)
2001 Jetta TDI
2000 Corvette (not a TDI but very fast)
jrock is offline   Reply With Quote
Old April 5th, 2007, 18:35   #11
TDI Believer
Originally Posted by jrock
TDI Believer,
Yep...another pic of a dirty EGR valve. Now that you've made it all spiffy, it can dump more soot into your intake manifold much more efficiently.
You'll probably enjoy cleaning that too.
Now...someone explain to me the benefits of "unrestricting" a valve that dumps soot into your intake manifold...
Old April 5th, 2007, 18:58   #12
TDI Believer
Originally Posted by bigEZ
well, i didn't think of it that way. i was getting ready to clean mine in a couple of weeks, but now i might reconsider.
believer, the egr delete that jeff does with his programing, does it affect this area, the egr valve? if so, then you're right, why would you clean the valve?
If you can get a chip tuner to do an EGR delete (essentially flattening the EGR map), the EGR valve will never open. That's probably the best thing you could do for your engine.
Old April 5th, 2007, 19:08   #13
TDI Believer
so, in theory, the egr valve should have no effect on mpg's?
I can easily get 42 mpg on my morning commute.
Old April 5th, 2007, 19:13   #14
bigEZ
TDI(s): sold
is it something that if it became totally clogged and provided no flow at all, it would throw a cel? obviously, all the air needed is coming from the intake; i'm just wondering if a physical disruption in the "circuit" would eventually cause some problems (cel, reduced mpg's, etc. etc.)?
bigEZ is offline   Reply With Quote
Old April 5th, 2007, 19:38   #15
jrock
Well then why change your air filter if air restriction is not an issue.
2014 RAM Ecodiesel
2012 Passat SEL TDI
2001 Jetta TDI
Page generated in 0.15801 seconds with 9 queries
[Output: 119.93 Kb. compressed to 98.61 Kb. by saving 21.32 Kb. (17.78%)]
